6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
Thanks, nice video. I also found the programming guide in the box that I didn’t notice at first…
Had to use one of these to read it!
lexel, is it possible to kill turbo mode so it can never be accessed? I happen to go to turbo all the time back from the lowest level and probably through some other sequence, and my LED would not survive that anymore.
It is possible to flash the turbo to be like amy % FET PWM you want to reduce average current, even if you go backwards or enter thermal calibration
Removing from reverse modes should be possible but that needs more investigation how the code has to be changed
Well, I never thought I would find spam in this kind of thread.
Spammers can target any thread. It’s usually the bigger ones, but small ones can also be hit.
Hey Lexel, how are the boost drivers coming along?
Has anyone helped you to modify NarsilM to run on them yet?
Interested in the boost driver as well.
Looking for Q8 type driver (with 2Series) to replace burned Convoy L6 driver (30mm) .
Help me to choose right options.
The main option is what you want it to do when power is first applied. Meaning what the tail switch does.
You can choose nothing, 2 short blinks, full turbo and I think moon.
I prefer that tail switch to be simply lock out ( do nothing ), it’s inconvenient to use anyways
Lexel should be PM you.
You want something like:
30mm, 2S, L6, NarsilM, PO=(NO)
I think you can choose 2 channel or 3 channel. 2 channel is something new so I’m not familiar with it other than its supposed to improve reliability.
Since he uses NarsilM v1.2. he might be able to set the ramp to 80% with dbl clk for turbo. That’s a good option to have.
You can use the spring from your old driver or order a new one. Shipping is cheaper if you solder the spring. It ships flatter. Anyway, I’m sure Lexel will get you sorted.
Hi Lexel, I’d like to but a 22mm 2S TA driver with NarsilM please
I have ordered today new board including 20-22mm as those are out of stock right now
so it will take about 2 weeks till I get new boards
Lexel, what size do you have ready to ship ?
I need a TA driver, 2S, NarsilM for a Mag 2D with MT-G2.
Hi, Lexel
How can I buy those drivers?
I am interested in 17 (for ZL h600) and 21mm (for H03) boost drivers. Where can I find options for those drivers?
Like I was saying in that other thread, his boost drivers are not for sale yet. I did hear that ToyKeeper has helped him to get NarsilM running on the Boost drivers, so hopefully they will be out pretty soon.
So for right now, everyone who wants a boost driver will just have to wait.
Not quite understand you previous message, now it is clear, thanks!
new boards are marked as my sideswitches
S-Switch
G-Ground
L-Lights MCU controlles
some drivers got LS for permanent LED light
*also most high current new drivers got filtering for better LVP, but this makes reflashing impossible
there is a solder bridge you can open next to small C3*
New generation of drivers releases now
replacing the at 2S unreliable AMC7135s
DD + small FET and resistors instead
MT03/09R XHP70.2
support of permanent switch LED plus MCU indicator with resistors
30mm for Convoy L6/ Thorfire S70S
20-22mm with 2 FETs and also 6+1 AMC
here with 1S configuration with 6+1 AMC
I had to drill out one via on the spring side partially that secures the switch pad from lifting if soldered too hot
17mm 2S with 2 FETs
17mm LX v1.0 FET+5+1
more filtering caps for very high drain builds
Very neat. So you’ve added a second smaller FET. How does that work with bigger FET?
have no idea what any of this means. 2 fets, filtering?
