[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
Specifications (partly tongue-in-cheek)
User Manual
Model:
  • Sofirn C01
Light source:
  • 1 Yuji 5 mm through hole LED (YJ-BC-F5-G01) (Datasheet)
  • 60 degrees LED for floody beam
LED life:
  • unbreakable bulb (encapsulant material epoxy resin)
  • over 100.000 hours on high setting
  • bulb never needs replacing
CCT (color temperature):
  • 3200K
  • 5600K
  • 4400K when combining 3200K and 5600K models
CRI (color rendering):
  • Ra > 93
  • R9 > 60
  • superior color rendering
  • highest CRI values in a traditional 5mm LED form factor
Driver:
  • 25 mA current at LED in order not to decrease LED lifetime by overdriving it
  • graceful degradation with empty battery, no sudden unexpected darkness
  • approximately 60 mA current at battery when it is full
  • no PWM; no visible flickering
  • no parasitic drain when flashlight is off
  • driver board potted with thermal epoxy for increased resilience and waterproofness
  • joule thief / battery vampire circuit will suck every last Joule out of a battery
Power source:
  • single 1.5 Volt AAA sized cell
  • alkaline primary (LR03)
  • zinc-carbon, zinc chloride primary (R03)
  • lithium-iron-disulfide (LiFeS2) primary (FR03)
  • nickel-metal hydride (NiMH) rechargeable (low self discharge version such as Eneloop recommended) (KR03)
  • nickel-cadmium (NiCd) rechargeable (sale banned in European Union) (HR03)
  • AAAA sized or cylindrical cells from alkaline 9 Volt (6LR61) batteries with do-it-yourself aluminum foil piece adapter
  • CAUTION: do NOT use 10440 Li-Ion (3.7 Volt) or 10440 LiFePO4 (3.2 Volt) cells; they will destroy the driver and LED of your flashlight
Battery-flashlight combination shelf life:
  • 20 years with 95 percent of original capacity (Energizer Lithium LiFeS2 AAA primaries)
  • 10 years with 70 percent of original capacity (Eneloop NiMH BK-4MCC A/E AAA rechargeables)
  • CAUTION: do NOT store alkaline cells in your flashlight; they will start leaking and destroy your flashlight
Runtime with full AAA alkaline cell:
  • low (3200K 6 lumens / 5600K 8 lumens): 20 hours (battery voltage > 1.0 Volt)
  • moonlight low (<1 lumen): 13+ hours (battery voltage < 1.0 Volt )
  • desired output setting can be selected by switching between full or empty battery
  • runtime depends on temperature; lower temperature means lower runtime
User interface:
  • twist head to left for on while holding battery tube
  • twist head to right for off while holding battery tube
Waterproofness:
  • IPX8 at 2 meter
Operation temperature range:
  • depends on battery chemistry
  • lithium primaries are rated for -40 to +60 degrees Celcius
Weight flashlight:
  • 13 g (0.21oz) without battery
Weight battery:
  • alkaline AAA primary: 11.5g (0.41oz)
  • lithium AAA primary: 7.6g (0.27oz)
  • NiMH AAA rechargeable: 14-15g (0.49-0.53oz)
  • alkaline AAAA primary: 6.5g (0.23oz)
Dimensions:
  • 71.1mm (length) by 14.5mm (head diameter)
Material:
  • T6061 aluminium
Color:
  • black
  • blue (limited edition)
  • red (limited edition)
Options:
  • center-hanging split ring (included)
  • reversable pocket clip for use as hat light (included)
  • user-installable tritium vial (diameter 1.5mm; length 6mm; available from e.g. mixglo.com, banggood.com, ebay, fishing supply stores)
  • user-installable magnet (diameter 5mm; height 3mm; N52 is highest magnetic strength; available from e.g. Convoy store at AliExpress; supermagnete.de; fasttech.com; banggood.com)
  • user-installable diffuser (create DIY-cap from small lip balm) or buy one from Sofirn.
CAUTION
  • The areas where the PCB comes in contact with the body tube are small, they might need some cleaning now and then. There might be a potential issue where after thousands of on/off cycles the areas get worn out; djozz developed "a fix while it ain’t broken".
  • The Sofirn C01 is a flashlight with a potted driver, that means it is NOT mod-friendly; trying to open up its head might destroy the driver.
  • The Sofirn C01 has no low voltage protection by design; remove rechargeable NiMH cell when flashlight starts to dim to moonlight level if you want to prevent accelerated ageing of the NiMH cell.
  • The Sofirn C01 is not tested and not certified for use as intrinsically safe light.
  • The included pocket clip is made from metal that is painted black, some people have reported the black paint to come off.
  • Remove the included pocket clip at the point where it is attached to the flashlight, otherwise you might break it.
I wish you luck on this one. If you manage to get Fenix to do this, I will certainly get a few.
+1. And it’s a very big if, IMHO. But I’m a sucker for tiny shiny lights.
I’d be interested. Good luck!
I’d buy one, nice!, but I will admire you if you get Fenix to do special editions on request! (never heard of that)
It is always good to have dreams. :innocent:
In case Fenix would not be interested in such an innovative special edition, then perhaps another good candidate manufacturer for high CRI 5mm Yuji twisty AAA could perhaps be Reylight?
I think the combination of high CRI, high reliablity due to fully potted electronics, high runtime (15+ hours on single AAA battery) at a low price point (sweet point >15 USD) is currently not available commercially. Therefore such a light could be an interesting commercial niche.
Also because it could be attractive to both “flashaholics” as well as “muggles”. Key to selling however, would be explaining to people the benefits of high CRI. And why a potted flashlight at this price point is so special.
I can already imagine a video with torture tests
https://www.youtube.com/watch?v=3dRppPINZfo.
I would absolutely be in.
I am in! I’d probably get 2-3 if the price is reasonable. Warm preferred, but will order either way.
As far as E01 torture tests:
5 Story Drop Test
5mm LED AAA Abuse Testing
Edited to add, I have a picture of what we’re going for, but the Sunwayman I previously modded will NOT withstand a 5 story drop. Mine died from a 5’ drop.
2nd Edit - not sure the picture is actually showing up. It will have to wait until after work.
Vinh at Skylumen has been modding E01’s with Yujis. They’ve been quite well received on the other forum; I have one myself and it’s an amazing little light.
I’d be in for 2, at least.
I am waiting for Vihn to ship my EO1, so I’m am in. Vinhs are $48 and he doesn’t repot them.
Nice! When did this happen?
Last I heard, he had done warm LED mods in the past, but then Fenix changed their potting compound and he could no longer get the driver clean.
And now I see he did a batch of Inova X5vn, too.
I appreciate you bringing this up, although I will first hold out hope for Fenix doing a run. They should be able to afford to sell them at lower cost than Vinh modding them by hand.
Also, the fact that there is interest in this light even at custom prices is more evidence Fenix should do a batch of Yuji E01’s.
Plus they would still be fully potted. Being cheaper would also make it easier to give them away as gifts. :wink:
If Fenix was to sell them at $15, they would be my favorite budget AAA light on the market.
I definitely appreciate Vinh’s work modding these though. They seem tough to crack open and mod, but it also gave me a chance to try a Yuji for the first time.
@richnpc: Nice! What CCT did you get? I got the 3200k variant.
Interested!
Even if Fenix doesn’t take it on, I’d be interested in something comparable.
I’d buy one!
I would be in.
In for 2 or 3
Normally I would be interested but I already have a Yuji GIU and imho a Yuji E01 would not be an improvement.
I highly recommend the Gerber Infinity Ultra as a Yuji host. Easy to mod with low temperature white threadlocker and only the inductor coil is potted. Lots of o-rings. Decent clip for hatlight use. Can use AA or AAA batteries. The “tail switch” is great. Kind of tailstands :slight_smile:
Thanks for your suggestion for the Gerber Infinity Ultra (AA/AAA) as a “cockroach” light with high CRI emitter.
That one is certainly an attractive light as well :slight_smile:
On the Gerber site, the Infinity has a MRSP of $22, AKA €18.50 in our currency.
I can buy it on Amazon.de for €33.95 and I have to pay €9.80 for shipping from Germany to where I live.
Only speaking for myself: not an option if you live in Europe.
Output is way lower also on the Gerber.
