in for 20
List updated.
BTW, guys, do any of you want smaller springs for driver boards?
I can try and make a special order of 500 big springs for tailswitches and bottom tailcaps, and 500 small springs for drivers.
30 thanks BlueSwordM. Possibly more if you run short on buyers.
Updated, and thank you for the support.
I’d be in for 40 springs and I’m in for more if you need the extra push to put the project into the green as well.
Updated again.
Lexel might also be interested in a larger order
I’m in for 50, Thanks
Updated again.
I have thought of sending some springs to Lexel and Texas Ace for testing.
I’m good for 20. :+1:
Updated.
BTW,just for fun, I just received a message from one of my other suppliers, detailing what I need to do to get the minimum order quantity to make 45% IACS Beryllium Copper custom springs.
It was really funny to see.
Basically, I would need to order 65 000 springs. Not 6500 springs. 65000 SPRINGS. Lol
So, I think I am going to stick with my main supplier for this group buy.
Unless some of you guys and gals want to order 1000 springs each
Would be interested in 30
I’ll take 30 if there are two sizes or 20 if it’s just this one
50 pcs for me, thanks.
The list was updated again.
UPDATE
I have added an interest list for a smaller spring. I might try to get another batch made for smaller springs. Express your interest if you want one.
I will also make an Excel sheet for following everything, as this is getting tedious.
interested in 20 depending on final price :disguised_face:
I have updated the list again,
So, would anyone be interested in a smaller driver side springs? Just wanting to know.
Put me down for 20 please. If the smaller ones get made I’ll take 20 of them as well.
Small springs is a good idea. Maybe I would be interested. But what dimensions?
Hmm. I had not thought about this.
Perhaps these dimensions and characteristics:
- Material: C17530(Berrylium Copper) with IACS of 38%
- Spring upper diameter: 4mm
- Spring base diameter: 5mm
- Spring thickness: 0,75mm
- Spring height: 8mm
- Plating: Zinc plating
That would be adequate for almost all driver side spring builds.
