As we discussed, it probably has less transmissivity but light reflected off it hits the reflector and has a chance to return - so overall it ended up with 6% loss.
If the second-chance emission hypothesis is true, TIR lights like FW3A won’t benefit from it because most of the light that bounces off the lens will hit flashlight walls eventually.
Sunset mode doesn’t look very interesting. It starts at low, gradually ramps down for an hour, then shuts off.
Candle mode was linked a few posts ago, though the video doesn’t show its auto-shutoff timer. It goes at regular brightness until the final minute, then dims, sputters, and shuts itself off.
Candle and lightning modes are completely random and don’t repeat. It uses noise from ADC readings as a source of real-world entropy, so the random number generator is actually random and never does exactly the same thing twice. It’s not crypto-grade randomness, but it’s pretty good for a 90-cent chip.
Sapphire is not a glass, it is grown as a single crystal of Aluminium Oxide.
It’s use in high-end watches is it’s extreme scratch resistance (it is nearly as hard as diamond). Actually quite easy to make, but not to shape.
Apple thought for a while that they would use it for the screens on top iPhones, but that project didn’t work, so they use Gorilla Glass like everyone else.
Except for the camera lense cover, where I think they still use sapphire for durability.
It’s added into the mix on every ADC reading, so 8 times per second. It’s not the only data source though. So the result is highly chaotic and genuinely random, with all bits constantly in flux. The lower bits are a higher quality of randomness than the upper bits though, so it’s recommended to do things like “rand() & 0b00001111” instead of “rand() >> 4”.
1233 - # Post . bansuri
. New requests:
Correcting: …
1125 - # Post . Bob_McBob
Apologies, I’m sorry.
I need to edit list.
Greetings.
–18 Off : # Post . DB Custom , See # Post . … “Delete, Remove”
–1174 Off : # Post . CM2010 , See #Post . … “Delete, Remove”
–931 Off : # Post . darrylo 3nd … “Delete, Remove”
–932 Off: # Post . darrylo 4nd … “Delete, Remove”
–1344 Off : See # Post Coscar, delete , “Remove”
1234 - # Post . mniezen
1235 - # Post . mniezen
1236 - # Post . FBsLights
1237 - # Post . preface
1238 - # Post . whopist
1239 - # Post . jaynick
1240 - # Post . jaynick
1241 - # Post . jaynick
1242 - # Post . tjl014
1243 - # Post . tjl014
1244 - # Post . Cutchya
1245 - # Post . I LIKE FLASHLIGHTS
1246 - # Post . DoubleU
1247 - # Post . ActiveAl
1248 - # Post . severide
1249 - # Post . Tarvos
1250 - # Post . Tarvos
1251 - # Post . kmwc72 CN
1252 - # Post . kmwc72 CN
1253 - # Post . ActiveAl
1254 - # Post . Lion42
1255 - # Post . Lion42
1256 - # Post . andyxxx
1257 - # Post . andyxxx
1258 - # Post . flashycali
1259 - # Post . Aussie78
1260 - # Post . dmsoule
1261 - # Post . dmsoule
1262 - # Post . manithree
1263 - # Post . tvizk
1264 - # Post . raqin
1265 - # Post . retsyx
1266 - # Post . Bervilat
1267 - # Post . kubed_zero
1268 - # Post . kubed_zero
1269 - # Post . korylprince
1270 - # Post . Ratus
1271 - # Post . Edindevon
1272 - # Post . GalaxyWide
1273 - # Post . Medicijnman
1274 - # Post . Nash_Vegas
1275 - # Post . Moomoomao
1276 - # Post . Moomoomao
1277 - # Post . Brinkmann
1278 - # Post . Brinkmann
1279 - # Post . bonfire
1280 - # Post . Moparguy
1281 - # Post . Moparguy
1282 - # Post . .-’_
…………… - 1282 See: .-’_
1283 - # Post . Nooner
1284 - # Post . Atom00
1285 - # Post . javipiloto
1286 - # Post . Lfatman
1287 - # Post . DarkParagon
1288 - # Post . Crazy999
1289 - # Post . LanternGuy
1290 - # Post . samnavy
1291 - # Post . Random Dan
1292 - # Post . finnegans
1293 - # Post . TheSoulless78
1294 - # Post . wiley07
1295 - # Post . jinjin19
1296 - # Post . QwertzHz
1297 - # Post . Cyzan
1298 - # Post . Cyzan
1299 - # Post . cujo255
1300 - # Post . geetee03
1301 - # Post . apurva
1302 - # Post . apurva
1303 - # Post . Marubae
1304 - # Post . HONDARIDER
1305 - # Post . HONDARIDER
1306 - # Post . yokomus
1307 - # Post . Chatika vas Paus
1308 - # Post . Chatika vas Paus
1309 - # Post . Snoballz
1310 - # Post . spaceminions
1311 - # Post . Mr.Scott
1312 - # Post . lohtse
1313 - # Post . lohtse
1314 - # Post . brettr1
1315 - # Post . gkushev
1316 - # Post . gkushev
1317 - # Post . wiley07
1318 - # Post . wiley07
1319 - # Post . Yoav.Klein
1320 - # Post . Bd7
1321 - # Post . alejo
1322 - # Post . hiker89
1323 - # Post . hiker89
1324 - # Post . hiker89
1325 - # Post . NordicMist
1326 - # Post . wheelgunwordslinger
1327 - # Post . Dsvist12
1328 - # Post . Dsvist12
1329 - # Post . Doobyscoo
1330 - # Post . mrgreengenes42
1331 - # Post . misterpearguy
1332 - # Post . MobileEMP
1333 - # Post . MobileEMP
1334 - # Post . MobileEMP
1335 - # Post . rennet
1336 - # Post . lew123
1337 - # Post . zeroflow
1338 - # Post . duhduhduhdiabeetus
1339 - # Post . Nortson
1340 - # Post . Hallamski
1341 - # Post . michaeltmohr
1342 - # Post . Glas4d
1343 - # Post . Glas4d
1344 - # Post . Coscar 1344See # Post Coscar, delete
1344 - # Post . gemmell
1345 - # Post . gemmell
1346 - # Post . a_idiot
1347 - # Post . jaharkes
1348 - # Post . madness
1349 - # Post . arisdes
1350 - # Post . Zeratull
1351 - # Post . severide
1352 - # Post . TheShadowGuy
1353 - # Post . Cursecut3r
1354 - # Post . Hesh24
1355 - # Post . Tony Cape
1356 - # Post . sbslider
1357 - # Post . LightUpTheDark
1358 - # Post . Jagger
1359 - # Post . soldsoulrockroll
1360 - # Post . ReallyInToCheese
1361 - # Post . noobsanpu
1362 - # Post . BurningPlayd0h
1363 - # Post . headburger
1364 - # Post . Phaze13
1365 - # Post . Iselldrugsforgolf
1366 - # Post . Typevii
1367 - # Post . tkd15
1368 - # Post . xikteny
1369 - # Post . bushmaster
1370 - # Post . kevinw0lf
1371 - # Post . scottie888
1372 - # Post . Gondwanaland
1373 - # Post . cannesahs
1374 - # Post . Polyesterboy
1375 - # Post . the0dore3524
1376 - # Post . Stereodude
1377 - # Post . CitizenK
1378 - # Post . bento_blf
1379 - # Post . klrman
1380 - # Post . yokomus
1381 - # Post . KJ4BXT
1382 - # Post . KJ4BXT
1383 - # Post . ale9g
1384 - # Post . Penguin
1385 - # Post . Penguin
1386 - # Post . waxing twilight
1387 - # Post . Roc32
1388 - # Post . Roc32
1389 - # Post . iamlucky13
1390 - # Post . Mops1
1391 - # Post . Mops1
1392 - # Post . wheremydonky
1393 - # Post . wheremydonky
1394 - # Post . wheremydonky
1395 - # Post . psumo
1396 - # Post . adirus
1397 - # Post . geetee03
1398 - # Post . zotee123
1399 - # Post . anycolourfloyd
1400 - # Post . CabalGrim
1401 - # Post . Lick
1402 - # Post . ttylamg
1403 - # Post . Cereal_killer
1404 - # Post . Jay
1405 - # Post . mb200k
1406 - # Post . stolikat
1407 - # Post . TonyG
1408 - # Post . asciiphil
1409 - # Post . Fady
1410 - # Post . Fady
1411 - # Post . Fady
1412 - # Post . lucydog
1413 - # Post . lightknot
1414 - # Post . lightknot
1415 - # Post . xertian
1416 - # Post . xertian
1417 - # Post . Enlightened1
1418 - # Post . Enlightened1
1419 - # Post . elnino
1420 - # Post . gottawearshades
1421 - # Post . 3061fps
1422 - # Post . andrewmac
1423 - # Post . andrewmac
1424 - # Post . firstcipher
1425 - # Post . skinny_tie
1426 - # Post . Nooner
1427 - # Post . Cereal_killer
1428 - # Post . Cereal_killer
1429 - # Post . bushmaster
1430 - # Post . kollers
1431 - # Post . Geese
1432 - # Post . caplang
1433 - # Post . vadimax
1434 - # Post . MonkeyLight
1435 - # Post . MonkeyLight
1436 - # Post . MonkeyLight
1437 - # Post . MonkeyLight
1438 - # Post . justaguy
1439 - # Post . justaguy
1440 - # Post . HeavyD3
1441 - # Post . HeavyD3
1442 - # Post . knuckles
1443 - # Post . Mops1
1444 - # Post . thejinn
1445 - # Post . fusion_m8
1446 - # Post . justanotherguy
1447 - # Post . Geese
1448 - # Post . JohnnyUtah
1449 - # Post . loki993
1450 - # Post . e1000
1451 - # Post . jamio
1452 - # Post . hodor
1453 - # Post . Ilmatic
1454 - # Post . Ilmatic
1455 - # Post . atasuke_
1456 - # Post . AcIDsNaZz
1457 - # Post . Desert Lumens
1458 - # Post . bulbeee
1459 - # Post . Melven
1460 - # Post . neBstress
1461 - # Post . autoxer
1462 - # Post . RichardBrown
1463 - # Post . Valerianis
1464 - # Post . takumi86
1465 - # Post . Gravedigger1
1466 - # Post . MascaratumB
1467 - # Post . RandyC
1468 - # Post . RandyC
1469 - # Post . coban
1470 - # Post . coban
1471 - # Post . eas
1472 - # Post . Delta_V
1473 -
1474 -
1475 -
1476 -
1477 -
1478 -
1479 -
1480 -
NOTE: If I overlooked a post, PLEASE IM me and i’ll edit for correction.
. . . . . . . . . . C L O S E D
Buying something can be devided into two steps. The deal (intention) and the delivery ((physical) transaction).
First step is where parties communicate their intentions (coming to a deal - offering something - paying for it).
Second step is actually delivering the item.
In the Netherlands the deal is annuled when one of the parties is unable to fulfill his/her obligation to deliver.
This can imply you have to pay for the actions that were already set in motion.
That’s what I have been told, about a century ago.
But feel free to think otherwise (other legal system?).
In this case the decision & declaration was made to be put on the list to buy one. It seems the remorse just reared it’s ugly head before the money changed hands. Maybe a technicality in some eyes… but the outcome is the same.
I think Henk4U2’s definition below sums it up nicely in fact……. :+1: .
Buyer’s remorse is often referred to as the reason for cooldown clauses in purchases, where you have 24 or 48 hours to cancel a deal without penalty regardless of whether or not a payment, delivery, or signature has been obtained.
The act of buying is not the defining moment, it is the decision to commit that is the turning point, after which second thoughts can creep in. The enthusiasm leading up to the point of commitment is a separate thought process to the hindsight afterwards, either one can be a distorion of reality since different emotions are brought into the picture.
