13576 posts / 0 new
spaceminions
Last seen: 4 months 1 week ago
bansuri wrote:
spaceminions wrote:
In another light, the anodization lets you do mechanical lockout by breaking the connection
Just an FYI: the above only applies to lights that don’t have a PC board that the spring is soldered to. The PCB is isolated from the tail cap and completes the circuit between the negative terminal and the main body by making contact with the unanodized end of the battery tube.
Was referring to emisar d4
Card Carrying CRI baby https://b.thumbs.redditmedia.com/laMC7BGhREfYTRQjYe2I5FMjTF1IjrmM6bPLK9SKEXU.png
bansuri
Last seen: 6 hours 31 min ago
Good example. You can see that the PC board isolates the circuit from the tailcap and you could sand off the anodizing and still have lockout.
Here’s a link to a pic from TK’s review. http://toykeeper.net/torches/emisar-d4/full/tailcap-inside.jpg
That ring of copper is what the body touches when you screw it on.
But back to the FW3A, I can’t imagine any of us are too worried about the finish as this will be a “user” rather than a shelf queen. LOL
spaceminions
Hmm, yeah it does. I do remember hearing that it was not so with another; maybe there’s some difference in the way the titanium one works, and that’s what I was hearing about. But yeah, I don’t think for a moment this won’t see some wear… might look better to not anodize and just polish scratches out as best as possible; regular anodizing isn’t immune anyway. I could go either way.
maukka
maukka's picture
Last seen: 19 hours 15 min ago
Anything except raw/bare.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 46 min ago
The tailcap might be able to do lockout by loosening it, but I wouldn’t recommend it. It’s not really meant to be unscrewed. It makes the clip loose, allows the tubes to slide relative to each other, and could still make contact by pushing the button hard enough to pop the rear PCB loose.
So… keep the tail end tightened up unless you’re swapping the button or clip or something. Change the battery at the front end instead.
raccoon city
raccoon city's picture
Last seen: 4 hours 37 min ago
+1
Geuzzz
Geuzzz's picture
I think a natural hard anodising would suit the light and keeps the original “raw” idea. Bit like the old Novatac flashlights.
raccoon city
Post #4000!
(At the moment.)
kevinw0lf
Last seen: 2 months 15 hours ago
I’m in for 1 if there be a LH351D version.
teacher
teacher's picture
raccoon city wrote:
+1
+2
(But, as I posted earlier; I am a strong advocate of letting Fritz make the choice!!) And as pinkpanda3310 stated, this will also eliminate stretching out this project even further.
That in itself is a win all the way around….. Thumbs Up
pinkpanda3310 wrote:
teacher wrote:
Here is another thought. Fritz designed this light (as far as I know), let him decide the finish & the rest of us can just deal with it if it happens to not be our particular preference. Thumbs Up
I agree. No need to stretch this out even more.
cabfrank
Last seen: 17 hours 14 min ago
Honestly, the finish doesn’t matter to me at all. Not a bit, especially if it won’t matter with regard to a physical lock out. (I’d prefer a physical lock out, given the option, by the way). So, I agree, let the designer decide.
Tom Tom
Last seen: 11 months 3 days ago
ToyKeeper wrote:
JasonWW wrote:
I don’t understand why there are seams 90° apart.
TBH, I don’t know either.
Both prototypes had it, but it’s a lot more noticeable on proto2.
However, I’ve heard that it took Convoy a while to get the clear anodizing right, and even then, it seems to be so thin that it can still conduct electricity sometimes. On my clear C8, I can measure electrical contact between a bunch of different places on the outer surface of the light.
My guess is that they crammed the anodising tank too full. Imagine lots of tubes standing in square formation, Current density i.e. ano. thickness varying dependent on how close to each neighbour. Hence “seams” at 90 degrees.
Tom Tom
Agreed, that would be perfect, and so durable. But proper thick hard anodising is a slow cold expensive process, I doubt Lumintop would know how, even if the alloy is suitable. It would be nice if they could though, it would lift it into a different class.
Rarely seen on a torch despite claims, the only one I have with it is an Inova X1, but I’ve also seen it on Surefires and I think Zebralight. None of which are $30 torches.
The main thing is no gaudy colours, and no bead-blast please.
Pulsar
Pulsar's picture
Last seen: 3 months 2 days ago
I think at this point a natural HA would look best.
Eraursls1984
Last seen: 1 month 1 week ago
Yeah, we’re definitely not getting a good ano, but I still think it’s better than raw.
Dman7777
Dman7777's picture
I like the silver finish. it looks unique. I assume they can get rid of the uneven anodizing in the production run.
Nev
Black.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 5 min ago
I “vote” that Fritz decide this thing about anodization and colour!!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
shirnask
shirnask's picture
Last seen: 2 hours 15 min ago
+1
pepinfaxera
Last seen: 1 hour 49 min ago
Thumbs Up . Thumbs Up . Thumbs Up
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
teacher
teacher's picture
Thumbs Up … /\ … Yep.
scottie888
please put me down for 1. thanks
Tom Tom
TK asked us for our opinions, so I’ve given mine.
Not sure whether Fritz is in tight control here, this is now quite a big project, and Lumintop will do what they do, hopefully listening to feedback.
Edit: and striving to up their game, which this already does no-matter the finish. Otherwise why bother with BLF unless you are going to listen and learn ?
Aesthetics matter to me, but I won’t get too precious about them on a $30 torch. Though it could be done beautifully and within budget.
teacher
teacher's picture
Amen. Thumbs Up
My first opinion is let Fritz choose.
BUT if he cannot or does not want to do that……
My next opinion is..
  • Bead Blast & Anodize Grey (1) or Black (2) or even Clear (3)
Just no raw unanodized aluminum on this $36 light.
severide
+1
gravelmonkey
Last seen: 5 days 3 hours ago
Medium or dark grey would be awesome.
Not keen on unanodized/raw or ‘silver’ anodising.
pepinfaxera
teacher wrote:
Amen. Thumbs Up
Thumbs Up . . . Thumbs Up . . . Thumbs Up
Gondwanaland
Last seen: 1 year 8 months ago
Interested +1
cannesahs
Last seen: 7 months 2 weeks ago
Please add me to the list for one (1).
And for discussion:
I prefer anodized, color doesn’t matter much as long as it isn’t pink or such.
Polyesterboy
Last seen: 1 year 6 months ago
interested+1
