*BLF LT1 Lantern Project) (updated Nov,17,2020)
Geese is number 868 on the interest list
Welcome to BLF falcora, you are number 869 on the interest list for the BLF Ultimate Lantern
There appears to be a typo, “MH351” instead of “LH351D”. Just a note for the next diagram update.
If the hardware supports tint mixing, I’ll add it to the firmware. It’s not really my decision, but I hope it happens.
I think Nitecore makes something like that. The LR30, I think.
I was wondering about this too. Waterproofing the top of the lantern is probably important so it can operate during rain.
+1
The plan is constant brightness when changing CCT. And constant CCT when changing brightness. Except perhaps for a “natural” mode where CCT automatically goes up with brightness. Regardless, if it’s 6W on the warmest setting and 6W at the coolest setting, the plan is to make it 6W halfway between too… instead of 12W.
I’ll have to add an eeprom value for color balance, but that shouldn’t be hard. The main thing with adding features is just trying to keep the code size down so I won’t have to cut anything else to make room.
Maybe. I’ve been thinking about making sunset configurable. The questions there are a matter of choosing the most useful options and avoiding big changes in code size. There’s not much room left in the Q8, GT, and FW3A builds, and I hope to make things work on all platforms if possible.
Yes, that’s the plan.
I use candle mode quite a bit, especially in a lantern.
Depending on how things go, some things could potentially be removed though. Like, there might not be much point in keeping muggle mode, since the lantern doesn’t run hot enough to damage itself. And I’ll probably turn off thermal regulation entirely because the sensor isn’t near the emitters.
about to copy the just finished specifications here now shortly :slight_smile: feel free to alter, correct or add anything that i missed.
IMPORTANT: -I just received a message from Barry, and he told me he apparently left Thorfire, but he can still communicate with the factory that built the Q8, (an affiliation for Sofirn i believe) Barry mentioned to me he can still work with us, but more so if we go with a different brand name possibly. any suggestions or idea are welcome. Also i want to create a PM group for everyone who has contributed to the lantern project so we can communicate by message easier.
- BLF/Thorfire Lantern specifications Sheet:
- Lantern features & design:
  • Compact design based from the BLF Thorfire Q8 mid-section and battery section, with great run times, output, and tint ramping, mode groups, built-in USB charging capability, and versatility. Unlike most all commercially available LED lanterns, many of them have a lack of usable modes, low run times, built from plastic & less durable, have a low CRI color rendering and very cool white or bluish light tint. This new lantern design has all those issues eliminated for much more practical & versatile area-lantern for camping, off-grid, cabin use, or emergency lighting. With a built in USB charging circuit (set at 1.0 amps to 1.5 amps progressively) this lantern has a unique feature of its design, with the usb (possibly a efficient TP4056 chip controlled Lithium Ion charger circuit that is connected directly to the battery side of the driver allowing the lantern to still run on lower modes while charging at the same time. Using a solar panel charger of 10 watts or more, the lantern can be a infinitely sustainable off-grid light source for remote locations where there is no electricity.
- Based from the BLF Q8, (using the same battery tube and similar midsection, with a similar driver but instead of using a FET, this lantern uses four 7135 regulator chips to control current to a lower maximum draw current of 1.4 amps. The firmware will be developed specifically for lantern use by Toykeeper of BLF, and will have user defined mode groups, but with added modes including Candle-mode, sunset-mode, & possibly a tint ramping mode, (which allows the driver to ramp/fade between 3000K LEDs to 5000K LEDs, which will require a third lead for the LED star to have two channels, (one channel for three 3000K 3535 type LEDs and three 5000K 3535 LEDs, possibly the new Samsung High CRI LH351D-3535 series of LED emitters. There will be an added 1/4-20 threaded tripod mount placed in the bottom of the the lantern base.
Much of the battery tube, midsection, and base will be the same as the q8, but the mid section will have less cooling fins as it will not get as hot or require the same heat dissipation as the Q8 does, allowing the lantern mid-section to be more streamlined. The base has to be slightly thicker metal to allow the threaded tripod mount. Threads are to be anodized as the Q8 to allow it to be able to lockout by unscrewing the body from the mid-section. The electronic switch should use a yellow or amber LED instead of the green as in the Q8, so the switch can be used as a night light when the lantern is off. roughly 90 degrees around from the on-off switch, the USB charging port is recessed with a rubber plug-cap to seal out water.
-( if cost allows, the circuit could have an USB power bank option too, to allow the lantern to be a power source for charging phones, but must have a minimum of 2.0 amps at 5 volts for charging larger smart-phones. Also if cost allows this charging & power circuit option can be the new USB-C format.
- The mid-section design will have a similar shelf in the mid section like the Q8 has for the LED star, but for the lantern it has a threaded center hole for the assembly bolt, small holes near the center bolt hold for the wires, & a notched ring to hold the center wire-tube. Also there will be an o-ring seal around the outer perimeter for the lens/globe to seal on to prevent water from entering. The lens/globe is to be made from either a durable poly-carbonate material (for crack resistance) or a HDPE type material. ( not acrylic material, as acrylic cracks to easily. The frosting should be between 35% to 40, to allow the most light transmission but also give a good, smooth balanced light diffusion to lower hard-light and shadowing. (Most LED household bulbs are roughly 60 frosting, the lantern should be less at 35 to 40%. ( meaning the LED emitter will be visible through the lens, but still mildly frosted.) The lens/globe is shaped like a tapered “cup” to allow more downward light with less reflection glare, with a solid bottom one-piece area to add strength to the globe. Also the bottom surface and the center tube needs to be a flat/matte bright white material, as matte white smooths out & reflects more light smoothly than silver or other shiny surfaces does. (See cross section drawing & description)
The head of the lantern is a solid aluminum unit for the LED star to mount on as a heat sink, also will have the center tapered bolt hole for assembly. the upper area of the lens/globe will fit into a grove around the underside of the head, with a rubber seal/o-ring to seal out water.The LED star will be a 2-channel design, using six 3535 LED pads, with every second pad around the PCB star traced to be on the opposite channel, (three LEDs per channel for the tint ramping option.) The top of the head will have two lanyard holes, (drilled angular from the top to the sides so the holes do not pass to the inside of the head unit, and a 550 para cord lanyard attached with sturdy resin hook-type end clip at the top ends. (see cross section drawing)
-Specifications:
- uses up to four 18650 LiIon cells (in parallel configuration)
- modified Q8 driver design, four 7135 regulators, (no FET) new firmware developed by
Toykeeper.
- 170mm tall x 57mm wide
- Lighted electronic switch, (same as Q8 but with amber or yellow LEDs.
- Mode groups similar to Narsil, but with additional Lantern special modes, and three wire tint-ramping feature & modes.
- USB charging, ( either USB-micro or newer USB-C with power bank feature.
- down-firing LED design, with three Samsung LH351D 3000K high-CRI LEDs, and three Samsung LH351D 5000K High CRI LEDs.
- Average between 600 to 8000 lumens on maximum mode. ( tested with Samsung LH351D 4000K LEDs with four-7135 regulators on Q8 driver & Q8 Narsil firmware.
- maximum mode run time tested at 1.4 amps draw on four 3500mah high capacity Panasonic 18650 cells measured at roughly 12 hours.
- o-rings at top & bottom of lens/globe and around upper bolt head to seal out water.
- electronic & mechanical lock out.
  • tripod mount on bottom for use as a raised lantern on a tripod.
The mode groups aren’t the same as a Q8, exactly… because it has none. Instead, it lets users define their own mode group. It still offers both a smooth ramp and discrete brightness levels, but the latter is user-configured instead of using hardcoded mode groups.
The cooler tint should probably be 5000K instead of 4000K.
Interesting. First I’ve heard of the angle, I think. I had assumed it was 90 or 180.
I’m not sure it’ll get 850 to 1000 lumens with just 1.4 Amps. Time for some quick measurements and napkin math.
Using measurements and some numbers from spec sheets, I get…
  • XP-G3 CW 70CRI:
    • measured 160 OTF lm / 7135 chip
    • rated 177 lm / 350mA
  • LH351D 5000K 90CRI:
    • rated 410 lm / 1.05 A (or 137 lm / 350mA) (or 547 lm / 1.4 A)
    • calculated 520 OTF lm at 1.4A
So, my guess is about 520 lm for this lantern, if it uses 4x7135 per channel and has very little loss. To hit the range of 850 to 1000 lm, it would probably need 7x7135 per channel (estimated 911 lm).
There was a post in another thread somewhere with a quote from a Sofirn employee, to the effect that Sofirn is the manufacturer for Thorfire, not just another brand using the same manufacturer. So if correct the Q8 is a Sofirn manufactured product to Thorfire specs, which explains why Sofirn can sell original Q8 parts.
Would it not be preferable to deal with Sofirn directly? Since they are breaking out with their own products now, they must have a design team, and have all the Q8 specs programmed already, as well as a parts inventory. Sofirn seems to be building a good name for themselves and taking our niche market seriously, wouldn’t this be an ideal opportunity to let them run with it directly rather than handing it to a 3rd, and as yet unknown brand? Seems to me to be a relationship worth pursuing, thinking future projects as well. Prototyping would surely be smoother dealing with the manufacturer directly rather than through a 3rd party.
:+1: @Zulumoose
[quote=ToyKeeper]
How would reflowing the leds influence the tint ramp. Say I would reflow the Leds and use 2000K and 6000K leds, would it mess up the tint ramp? BTW: I don’t even know if there LEDS in that spectrum, it’s just an example.
I would really like the warmest tint available for this lantern and for lightning mode I think a really cool tint would offer the best effect…. Not saying I want to push my thoughts for the final product, I can roll my own by reflowing the LEDs. That’s why I ask the question.
It would not mess up the tint ramp.
TK is just saying we should have a wide range of tints between 3000k and 5000k.
So yes, you can reflow your own 2000k and 6000k LEDs. However, for the 2000k version, the output will suffer tremendously.
[quote=dekozn]
Apart from that imperfect blending of the two led tints will show up clearer when the tints are further apart, I do not think that the quality of the in-between tints gets much worse if 2000 and 6000K are chosen. That said, if I think of the led spectra that add up, I’m very sure that 2700 and 5000K give perfect in-between tints, and I expect but am not completely sure that 2000 and 6000K give perfect in-between spectra.
Edited my errors :slight_smile: especially the 45 degree one. ( it should be at least 90 degrees or can be 180 degrees on the opposite side if needed ( in place of the original Q8 tripod hole)
as for the lumens, i was mostly estimating from the measurements i got using four XP-L LEDs at the time. (maybe the white-surface light bounce amplified the light? (the upper & lower light surfaces painted matte white really increased the light out 180 degrees around the lantern over the bare metal surfaces did) we can go with 5000K for the higher LEDs., though i have none of them to really test yet.
good point. Barry will be the liason to decide where & under what brand the BLF lantern will be manufactured. I just realized that we don’t have a name/model for the lantern yet… ( like Q8, GT, A6, etc. we need a model number or name for the lantern.
We need a name for the lantern, (like the Q8, GT, A6, etc.) the lantern does not really have a unique name yet. Post your thoughts on a name we can use, ( or number designation?) then we can put it to a vote.
@DBSAR, do you want me to speak to Sofirn about the project?
I asked them out for a DIY part for the BLF Q8 battery tube and tailcap, and I discovered they were making a BLF Q8 V1.5, with an extended battery tube, and XPL HI.
I could perhaps forward the lantern specs and measurements/characteristics to them and see if they are good with making it.
That would be great if you want to. I send Barry the specs & drawing last night, and assuming he has the ties with Sofirn too.
Yep. The reason I am more comfortable with Sofirn than Thorfire is that even Haikelite is willing to send replacement parts for their lights, which has not been the case at all for Thorfire.
Sofirn on the other hand is very cooperative.
On the other hand, it is so amazing that we can actually do these kinds of group buys.
10 years ago, that would have never been possible. Be it custom BLF lights, custom springs, LEDs that we can’t buy without ordering 800pcs(Nichia).
Finally, on another point, how was your camping trip?
good points. I am still on my east coast trip, (will be until July 16th.) i plan on doing more detailed field tests of the lantern & 3000K & 4000K LH351D LEDs while on this trip.
I’m interested in one.
Name ideas:
- Campfire
- CF6 (CampFire, 6 LEDs?)
- SunLight
- SL4 (Sunlight 4, 4*7135 chips?)
- 天灯 (Sky Lantern… bonus points for a red anodized version)
Ooh the BLF Skylantern.
Now that is a good name.
I vote for BLF Skylantern
