ENEDED
+1
I’m curious to see what a beam looks like from something like that. I’ll wait for a review.
I am subscribing to see what are the specs.
I may become interested depending on the price and UI, mostly !
It surely looks good and I hope it has Amutorch high quality :+1:
Not to be off-topic, but this light and the FW3A have nothing to do one with another! The looks aren’t all that matters :wink:
Interested.
Freeme, if I recall correctly you mentioned something about an expected price below $ 35,00 in your first post. Now, this information is missing. Can you please check once again? Thank you!
Yes, below $35.
As per This Page it is 100mm long, takes an 18650, and there is a photo showing what looks (no surprise) like a very floody beam.
Not much more info than that, normal price around the $46 mark.
Check out the “double light cup version” photo, for a 2 emitter reflector version. A triple version like that would be like a mini Sofirn C8F.
Wow…$ 4.21 for a titanium flashlight? I bet even the host would cost more to manufacture and distribute than $ 4.21.
The $4.21 is for the double slot charger, not the flashlight, choose another option.
That makes sense. I forgot to turn off “no script”. :person_facepalming:
interested
Freeme, can you get a measurement of amperage and voltage at the board up top? Looks like a boost circuit running those emitters in series, just wondering what the levels are… no biggie if you can’t but sure appreciate the information if you can! :smiley:
Edit: Also, can you determine if the bead blasted head is also Titanium or is it Aluminum for better heat dispersion? And is the aspheric glass or plastic? Inquiring minds and all that… :wink:
Edit II: Sorry, but are the Nichia’s in the 5000K variant or warmer? The linked pages that show beam color show white but the indication there is also XP-G3 and this is Nichia 219C, thought I’d attempt to clarify. According the Nichia datasheets if the 219C is going to be making 1200 lumens with 4S set-up then the current should be in the 700mA range. This should fare pretty well in the heat department, do you have any feedback as to whether or not it runs on the warm or hot side?
Interested, too
Interested too.
Gosh why did I have to stumble upon this post/thread….another titanium light (single cell 18650) for my collection.
My Eagletac D25A Ti 2014 edition was over $50 when I got it on sale from Illumination Supply.
With an Aspheric lense for even flood lighting, this would be perfect for E21A 9080 or Optisolis emitters. Will paint the perfect wall of even HI CRI with perfect tint light for photography.
SKV89, that’s why I want to know the current/voltage… a very high CRI Cree COB can work very well in this type set up. :wink:
Interested
Interested
I’m interested. :sunglasses:
Interested, curious as to how the beam will look on this…
