Based on the lights I have and how I use them, I would say magnetic charger (proprietary, as said by raccoon city).
(With this I am not sayin the other types are useless; on the contrary, they are, I just prefer to use magnetic chargers. Apart from these, Micro USB is my choice, as there are many cables laying around… )
I voted micro b everyone has a dozen of those cables around. The USB c is much newer my phone now has it. But flashlights don’t need to charge at 3+ amps. The two amps the micro b can do is plenty.
My wife had a phone about a year and half ago that was USB c and the factory cable caught fire in the phone within 2 weeks of use. It burned the charging port up. Original wall block, original cable, phone and battery. Luckily we were right there on the bed and smelled it and saw the smoke rising. Battery was perfectly fine I kept it as a back up for mine.
Charging speed has nothing to do with connection type, at least for as long as the current capabilities of the connector aren't exceeded.
The USB type-C connector is a bit more robust than USB micro-B and a tad more current capable. The USB micro-B is widespread and cheap; I can even buy 10-packs of USB micro-B male connectors for less than $1 on eBay. Both are great and I endorse availability of both options.
On the other hand, screw propietary connectors and standards.
C > Micro because it’s more durable, non-directional and will definitely be the more common connector at some point in the future even if it isn’t yet.
Magnetic charging like Armyteks or Klarus, where it works with any battery. Not having to deal with rubber port covers or worry about them failing is nice. Just don’t make it like Olight where it only works with their proprietary batteries.
Type C would be my 2nd choice because it is reversible, more durable, and it would be nice to get all of my electronics using a single cable type.
Magnetic chargers kinda suck because you have exposed contacts which can short, but also require a proprietary connector.
Not only do you need a different magnetic charger for every brand of flashlight but you also can’t use the regular USB C cables you probably already have (or will have) for phones and computers.
It is possible to make USB C ports waterproof so that they don’t require a cover, but the cover is still good to prevent dirt from getting in.
Some flashlights have the USB port inside so it is protected by the flashlight body instead of a cover.
So in other words, charging speed has everything to do with connection type, if we don’t want to be stuck with current charge rates forever. A new USB standard needs to emerge with higher current capacity. Frankly it is all madness. (Most) Flashlights are not tiny and would benefit from a larger charge port, that is not only capable of more current but more mechanically robust. The batteries themselves are obviously another limit to charge rate, but there is and always will be a race to improve them and a need for standards to support evolving battery tech.
It is very common for both USB C and mUSB sockets to break off of PCBs, at least their solder joints do. For this reason I feel that either are terrible choices for anything that is not disposable and costing under $10, but it becomes absurd when on a phone or camera costing several hundred dollars, or something like an LED flashlight which, if it did not have terrible design choices like that, might be viable for far longer since tech advances tend to only make incremental brightness updates to flashlights, not anything revolutionary to the core purpose of making light. In other words a good flashlight could last for decades of casual use.
Flashlights should use USB A. Phones and other thinner devices should use USB mini-B. Nothing should use micro USB or USB C. The consumer electronics industry has seen over 50 years of consumer devices with flaky connectors (starting with 1/8 headphone jacks ?) and still hasn’t learned much. It’s one thing to make “disposable” products and another to make them so fragile that core functionality is lost because they tried to save 3 millimeters worth of connector size.
I agree that magnetic charging is not ubiquitous enough yet but the way to get there is make a robust design and NOT patent it, or only do so in order that others can’t, and freely offer it to the industry. Get it out in to the world and let others copy it into their designs.
It would not need to have exposed contacts to the extent that it was easy to short them out. They could easily be recessed just enough that it would take a deliberately matching shape, piece of metal to do so. For example we see this all the time with small mechanical connectors, don’t usually have objects getting inside them and shorting the connector out, unless you happened to have a pocket full of metal shavings.
I think somebody is confused about magnetic charging. It doesn’t need any contacts at all! It uses a changing magnetic field to induce a charge. Some phones have magnetic charging capability in addition to a regular USB charging jack. Magnetism is universal and AFAIK, magnetic charge induction isn’t a patented process.
USB has a higher current capability than any previous USB connection.
It is also more robust than all other USB connectors.
If someone is breaking USB C off of their phone then they have absolutely no care for their device and are probably pulling the entire cable to rip the connector off.
No other port will magically be more robust and endure this kind of abuse.
Instead of making everything idiot-proof just take care of your devices and there will be no problems.
And no I have never heard of someone ripping USB C off their phone.
Unless USB develops a new magnetic connector that all devices implement, it’s not gonna happen.
Magsafe died in favour of USB C.
