FWIW, I got the SN6X-2X back in the group buy (several years ago) and with a simple lens change to an UCLp it gained 27Kcd. So while we want to think in terms of linear application, emitter/reflector dia/ lumens… the shape of the reflector and the quality of the lens can play a huge role and both are something we very rarely quantify.
The picture you and your daughter holding the Mini GT is so cute. The flashlight just fits well and is right for her little hand. Now I want one!!! I like the design and style and I even think it’s better than the D1s.
When I’m doing quick calculations/comparisons I do tend to give the manufacturers the benefit of the doubt as far as using high quality lenses and reflectors, etc… Competition can be fierce so they know they need to use good parts and try to be honest about the specs because the guys on this forum and CPF will test and verify these things.
For sure there is always the chance that a bad part can be used by mistake that really hurts performance and my guesses become wrong.
For Mikeadoo, I know he just wants a general comparison. Are they gonna look the same or will the GT Mini throw noticable further? Should he get it or just stick with his C8s?
I think it’s gonna be a nice boost in distance. Not double, but 39% assuming Lumintops numbers are accurate.
Edit:
Here is a review I found on the C8s.
Flashlion measured 2.15A output instead of 2.8A which means it’s not 900 lumen. More like 600 to 650. He also only measured 35kcd. This is only 374 meters.
If Mikeadoo’s C8s is like this, then the GT Mini really will shine twice as far. It’s a huge difference.
Thanks Jason! I don’t have the tools to do the measurements to see if my C8s is like that one, but I still want this mini GT.
Looks cool and I gifted a couple of my stock C8s to my family and neighbors.
If you want to measure throw distances, all you need is a tape measure and a lux meter.
HS1010A or LX1330B are both good and cost from $10 to $30.
Here is a video on how to do it. It’s easy.
You can measure amp draws with a clamp meter like the UT210E for about $33. There might even be a coupon to get it a bit cheaper.
These are cheap, basic tools for measuring flashlights.
You can go one step higher with a Texas_Ace Lumen Tube for about $135. Then you can measure lumens. Not too many folks want to spend that much money, though.
If the light is well done (I expect a good reflector and focussing from Lumintop), the numbers are kind of predictable given the reflector size and led: 1200-1400 lm output, 120-140kcd throw.
That’s more than I’d expect. That’s about 5. But I doubt there are many around here who can claim more than a 95 mod rate.
I haven’t modded (but would like to):
Meteor (swap driver and optics)
Okluma DC2 Cu (swap driver and optic)
Rey brass pineapple (could use V2 driver and V2 reflector)
BLF-348 (should be ~8 lm instead of ~50 lm)
… and I don’t intend to mod:
SWM V11R
JB RRT01
L3 L10-219b
Zebralight H52Fw + SC52
Olight S-Mini Ti + S1-Mini Ti
Cooyoo Quantum SS
DQG Tiny AAA IV
I’m not counting anything I helped make, like the A6 or D4, or anything sitting in a box of old stuff I never use.
But I’d definitely mod the GT Mini, because if it can run Narsil it should be able to run Anduril. Same thing I did with the original GT. I doubt it needs any physical changes… just a new personality.
