1. Are there any real internal differences between the various “generations”, or has the technology been basically the same since 2006 with just more accurate manufacturing techniques or quality control? If it’s basically the same, then are the increases in stated cycle counts mainly due to discovering they had better performance than originally thought, or has manufacturing really doubled the performance with respect to cycles?
2. Does trickle charging really damage Eneloops?
3. Are other LSD brands such as Duracell and Ikea Ladda really re-badged Eneloos? If so, what generation?
4. What is the best way to store Eneloops for extremely long shelf-life (i.e., when not used in devices)? What charge level?
5. I have noticed that heat is about the only thing that really destroys the capacity of Eneloops. Hot, but lower than heat typically generated in lithium-ion lights. What is the maximum temperature recommended during discharge?
6. I have 2006 AA Eneloops that still have most of their capacity, even at reasonably high discharge (2 amps). Their internal resistance is higher than new cells, but still pretty good. What is the expected life-span of Eneloops, if cycle counts are not a factor (i.e., less than 100 cycles)?
-What is the relation between deep discharging (< 0.9 Volt) versus cycle life and internal resistance?
- Is it true that discharging an Eneloop Pro down to or below 0.9 Volt reduces cycle life with about 100 discharge cycles?
- How prone are Eneloops to internal cell damage because of physical shock and vibration (for example dropping them on a concrete floor from a height)?
What is the fastest way to kill an Eneloop (so we know what not to do)?
I could also ask, are the Toshiba, Canon, Nikon, Watson, Ikea, Amazon batteries eneloops? :)
At least somebody had to drop the IKeabomb in the thead.... literally EVERY eneloop thread somebody has to drop that in there..LOL.
Good questions. Don't know if I can ask the ikea question though.....
The max temperature for charge is about 60degrees celcius. But eneloop chargers (maybe not all) will cut the charge at 57 degrees, cool down and continue charging.
Deep discharge is to <0.6 Volts or lower.. but will write it down
Never heard of that.. will add it to the list.
That's hard to answer, at least they answered that in their FAQ, and I also did in the FAQ. Dropping can damage, but I dont think they can precisely tell what is too much etc.
I think not, but I’ll be interested in hearing his answer also. :+1:
On a side note… I use them (Eneloops) in all my cameras & have for years. I get great results with them (Eneloops)….
In fact Eneloops are the best thing since sliced bread!!!
I have some well over 10 years old that are still going strong. So far… knock on wood…. I have never had one go bad. . . :+1:
1. Will Eneloop ever make a standard sized C, D, or 9V version as their competitor Tenergy does? We’re aware that there are AA conversion adapters for this (size C, D) but the capacity is limited as a result.
2. Has Eneloop considered making a DC solar charger sold as part of a battery package as Costco sells in its AC charger version? IMO it could be a great seller for hikers, preppers, power-out emergencies, etc.
3. Has Eneloop considered making a USB battery charging port version? Competitors are coming out with more and more rechargeable batteries that have this very convenient feature.
Thanks ChibiM. New to charging eneloops and never knew the little AA's could take up to 2A charging.
Would also be interested what the technicians says allowable temps would be for charging AA and AAA for longer life as I could set
my MC3000 to cut off around that and rest the batteries before charging up to full. I always feel they get too hot when charging in some chargers but never knew for sure.
