How much floodier are they then the XP-L? IIRC the die size was about the same?
What as the results of slicing / dedoming?
It is a bit floodier than the XPL.
Dedoming(slicing) actually works quite well.
Is this Group buy still open? Or do we have to buy then from digikey now? I didn’t see a recent update in the op and have not had time to read BLF outside of my own threads this whole year.
Yes It is open. There was a delay at the supplier. But I finally got them today.
The Q8 reflectors still give you a nice hotspot though even with dome on so you will still get some of that signature Q8 combination love.
Any idea where this reel falls on this chart or do we need to test again?
Edit: I guess T6 after looking at the packaging closer F2T6Q2
yes everything are the same except about 125K colder.
contactcr:Edit: I guess T6 after looking at the packaging closer F2T6Q2
Works for me, puts it closer to my personal ideal 4500k color temp
I will take 20 (possibly more depending on exactly when payment is due) 4000k and 20 3000k.
Then if I can find that 5000k part number I can get some of those and try a mixed tint setup. That sounds very enticing.
@Texas Ace, you said my links were dead, right?
Strange. They were not dead 2 weeks ago.
Now I have to go back on the datasheet and search manually.
Ok, here are some not dead links:
Here is 5000k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4RTS6 – LED Lighting LH351D White, Cool 5000K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Here is 4000k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4TPQ6 – LED Lighting LH351D White, Neutral 4000K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Here is 3500k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4UPP6 – LED Lighting LH351D White, Warm 3500K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
2700k 90+CRI:
Order today, ships today. SPHWHTL3DA0GF4VPN6 – LED Lighting LH351D White, Warm 3000K 3V 1.05A 128° 1414 (3535 Metric) from Samsung Semiconductor, Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Hope I helped you Texas Ace.
Ok, I ’ll write you down in the list. You can pay any time while LED are in stock. Now only about 400/800 of 351D are reserved.
Dear AEDe,
I‘m just checking how much LEDs I need. I get back to you soon. Do you also sell the LH351D 5000K with CRI 90 or CRI 70 only?
Hi. Only LH351D 5000K in CRI 70.
5k 90CRI:
T6 Bin would be awesome! That’s going to be similar to a 4A Cree bin. The previous ones Maukka tested were above the BBL line and had some slight green/yellow like the 219C. Maukka applied the minus green Lee filters to bring it back down to the BBL. Hopefully this T6 bin means it will be neutral/rosy without having to apply a green filter.
Interested in 10x 90 CRI LH351D 4000K
What was the tint bin of the previous reel?
Edit: F2T7Q2, so like AEDe said, 125K warmer than the current reel and still below BBL.
FlashTom:Do you also sell the LH351D 5000K with CRI 90 or CRI 70 only?
Interested in 10 pcs of LH351D 5000K in CRI 70. Thank you!
Interesting that the previous one is supposed to be below the BBL but still came out to have some green like the 219C. Will Maukka be testing one from this reel?
AEDe: FlashTom:Do you also sell the LH351D 5000K with CRI 90 or CRI 70 only?
I would like to add one LH351D 4000K CRI 90, so it’s going to be:
10x LH351D 5000K CRI 70
1x LH351D 4000K CRI 90
Thank you!
Was there an update to prices recently?
