13638 posts / 0 new
d_t_a
Last seen: 1 hour 30 min ago
I wasn’t able to read all the previous posts, but I’m wondering about the emitter poll results. As of last time I was following the polls, the XP-L Hi version had already overtaken the lead over the Samsung LH351D as top choice.
I’m wondering if the “people’s choice” results have already been forwarded to Lumintop for evaluation? (I actually would like to try out both these 2 versions, if Lumintop would offer both of them, fingers crossed).
CM2010
Last seen: 9 hours 14 min ago
Dark grey.
TheShadowGuy
@d_t_a :
It looks like the XPL HI was the most popular choice, followed closely by the LH351D. The rest weren’t really close at all to those two, if I’m reading the results correctly. According to the updated OP the results have been submitted to Lumintop, so now we play the waiting game…
I’m really hoping the LH351D is offered in a neutral or warmer tint. That would be awesome.
dekozn
Last seen: 2 weeks 6 days ago
Oops I just made vote, said on the website that it wasn’t closed yet. TBH if it’s not offered in high cri I’m out + I don’t see the point in a 4 LED light with throwy emitters……..
Idiot proofing something only creates improved idiots.
teacher
teacher's picture
They will do just fine with the optic is the way I see it. But each has a preference of our own.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 26 min ago
It’s 3 emitters, but it’s not throwy. It’s expected to be in the range of about 2 to 4 cd / lm, which puts it solidly in the “floody” category. Generally 5 to 15 cd / lm is the common range for EDC-style lights, under 5 is really floody, and over 15 is typically considered more of a thrower.
The main point of XP-L HI in this light is to get as close as possible to a common EDC-style beam without sacrificing overall output.
OTOH, I’d probably also be happy if it was a FW1A, with a single LH351D 5000K 90CRI in an OP reflector. It would make the light a bit longer, but I think it would still be bright enough.
cabfrank
Last seen: 1 hour 48 min ago
I think that would be great for a second version also.
teacher
teacher's picture
Thumbs Up /\
DavidEF
DavidEF's picture
Last seen: 2 days 18 hours ago
ToyKeeper,
Since the opinions offered so far on the finish are all over the map, do you think it would be wise to start another Condorcet poll for the finish? I know some specifically said they’d rather not draw this out, but it seems the opinions differ wildly even among the few who have answered here so far.
- The YKK Philosophy
Noir
Noir's picture
Last seen: 18 hours 8 min ago
With the surface treatment you have to differentiate between the mechanical finish and the chemical finish.
For the mechanical finish I think the major options are:
  • No finish. The light is taken "as is" from the CNC machine, this means it will potentially have some slight machine marks (groves and such). This should be the cheapest option, because no extra manufacturing steps are required. I believe this option was intended from the start.
  • Beadblasted or sandblasted. This will hide machine marks. Depending on how it is done (how severe and if sand or beads are used), the light will feel relatively smooth, slightly velvety or even a bit like sandpaper (like ArmyTek lights). The prototypes have such a finish, but I'm not sure how smooth or rough the surface is, maybe someone who has handled the prototypes can tell us.
  • Polished. This will hide machine marks and makes the light shiny. As far as I know this option is better in terms of durability (of the anodization) compared to bead-/sandblasting.
For the chemical finish the major options are:
  • No treatment, i.e. bare aluminium. This should be the cheapest option, but the surface won't have any protective layer. Not sure about the durability and potential staining (maybe someone with a non-anodized BLF A6 can chime in).
  • Anodized. Here it is a question of color. With all colors other than black there is a risk of color mismatches between different parts of the light (e.g. body and tailcap), but black is very boring, thousands of lights are black. To minimize the risk of color mismatches it is probably best to anodize all parts of one particular light simultaneously (not sure if Lumintop is able/willing to do this). Natural color (a light or medium grey, sometimes leaning towards olive green) is, as far as I know, the most durable color.
  • Any other surface treatment, like ceramic coating, DLC, a coating using PVD method (TiN, TiCN, TiAlN, CrN, CrVN, CrAlN...), chrome plating, electroless nickel plating and probably many more. These are seldomly used on flashlights and would therefore make the light more unique, but most of these are probably not feasible because they either can't be done in house by Lumintop and/or they are too costly (but it is IMO at least worth asking if they are feasible). Electroless nickel plating is IMO most the interesting, it is used by Prometheus Lights (Darksucks). The first run of Preon P 1 Mk III was made with 4 different finishes and the pictures are great to compare surface treatments.
My first choice would be no mechanical finish (slight machine marks add character and I believe it was intended this way from the start) with electroless nickel plating (has a very nice "metal" look and is better than bare aluminium and probably also better/more durable than clear anodization).
My second choice (in case electroless nickel plating is not feasible) would be no mechanical finish plus anodization in any color other than black, preferably natural color (or maybe dark grey).
jon_slider
jon_slider's picture
Last seen: 2 hours 40 min ago
post #1 says:
FW3A Team wrote:
TBD: Cree XPG2/XPG3 NW, Nichia 219c NW, XP-L HI NW, or Samsung LH351D NW
What emitters does it use? • Not yet determined. Probably XP-G3, Nichia 219c, or XP-L HI (+$10).
Change Log
2018-06-22: Updated spec for optics and O-rings, added note about thermal regulation. Moved emitter type polls down to old news.
Old News
Poll (2018-06-08): Voting is open for emitter details: (results: the top choices were XP-L HI 3D and LH351D 4000K)
post #2 says:
FW3A Team wrote:
Emitters
3 pieces 3535 footprint
Cree XPG3 NW
LEDs mounted on DTP triple star
TheShadowGuy
@jon:
From the top of the first post:
Quote:
Current status (2018-06-22): Second prototypes tested, emitter poll results collected, sending in feedback for host changes and emitter type(s). Only a few product details left to finish before production.
As far as finish goes, the original idea was no finishing other than clear ano. If that doesn’t work, I’d rather have the mechanical finish be as minimal as possible and the chemical finish be as close to a natural colour as possible, such as a medium grey. Overall I think I’d be happy enough with !=raw && !=black.
ToyKeeper
ToyKeeper's picture
The reason I asked informally was to give Fritz more data about whether to go for grey, silver, bare, or another vote. While opinions so far are varied, it sounds like a lot of people are okay with Fritz deciding what the finish is.
As far as I can tell, the most common preference is dark grey / natural, followed by bare. Perhaps it can be made in a natural ano finish by default, with a batch of bare aluminum made for those who want one? That seemed to work fairly well for the BLF-A6. It’s up to Fritz to decide what to do though, and to negotiate the details with Lumintop. Every new option we ask for makes things harder for them.
jon_slider wrote:
post #1 says… post #2 says…
It looks like more updates are needed, to make the information consistent.
It’d be nice to have the first few posts in a text file and a revision control system, to make changes more consistent, convenient, and transparent… but that isn’t how it’s handled right now. A text box in a browser leaves a lot to be desired, compared to a full-featured text editor.
teacher
teacher's picture
And now…. a brief musical interlude. Wink
cabfrank
Nice interlude choices. Its terrifying that these songs are now considered “oldies” by a lot of people.
lohtse
lohtse's picture
Not sure if I had already stated that I require TWO …. thanks
Caving, Climbing, Mountaineering, Kayaking, Diving etc any time anywhere!!! If you in the UK let me know and lets Play!
Current lighting
Olight X7R,M2R,S1 Baton,S10R Baton 3m,S2R 2, I1R EOS,SofirnC8T,Lenser P7'2,Lenser P14,BLF A6,Fenix HL50,HM50R,HL55,CL05,HL05,CL09,CL25,Nitecore HC30,HC65,NU12,NU32,Astolux K1,Petzl E-light,Tikka Xp3,XP3LED,DUO,Atomlight,Xtar Warboys H3,PL47 Manker E03H and many Chinese ones
teacher
teacher's picture
cabfrank wrote:
Nice interlude choices. Its terrifying that these songs are now considered “oldies” by a lot prople.
Thanks Frank. Wink And yep, there has been a lot of ‘water under the bridge & spilt milk’ since those were released. Thumbs Up
Oops…. better go take my nap, I’m feeling my age just talking about it. Facepalm .. Big Smile . Big Smile . Big Smile
lionheart_2281
lionheart_2281's picture
Last seen: 45 sec ago
Hell yeah, sweet tunes, better than today’s garbage
teacher
teacher's picture
My feelings too….. Wink
JasonWW
JasonWW's picture
Last seen: 6 hours 25 min ago
To be fair, there was just as much garbage in the 70’s, 80’s and 90’s too. It’s a matter of separating the wheat from the chaff. Silly
teacher
teacher's picture
/\….. Thumbs Up .. That’s probably true.
pepinfaxera
Last seen: 1 day 15 hours ago
N. 1313 and 1314 , See Interest list by pepinfaxera
New requests: See #Post duplicate , Page 111
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
ToyKeeper
ToyKeeper's picture
At one point, people were complaining that 90% of science fiction is crap. A sci-fi author responded, admitting this is true… but meaningless. Because, as he said, 90% of everything is crap. Sci-fi is no different. And thus was formed Sturgeon’s Law.
I’d argue, though, that many things actually have gotten better over time, and are still doing so. There was certainly very good music made 50 years ago, lots of awesome songs. But looking at recent music, the amount of good songs is an order of magnitude more, and the production techniques have evolved to improve the quality and sophistication of the result. In both cases, it may be that only a 10% slice of the pie isn’t crap… but the entire pie has gotten bigger and fancier over time.
Flashlights are probably a more relatable example of this happening though. Again, most are junk. But today there are a lot more good ones than there used to be, even if there are also a lot more bad ones. And in some ways, even today’s junk out-performs top-of-the-line models from 20 years ago.
bansuri
Last seen: 5 days 1 hour ago
Absolutely! It’s why I don’t freak out if something doesn’t put out 5000 lumens, have a perfect tint, or any number of other parameters.
When I started there were purple tints and blue tints, 120 lumens was AWESOME, and it was mostly AA and CR123a lights.
The FW3A is science fiction come true. Seriously.
Thought of the FW3A when I looked at a horizontal mill at work today:
JasonWW
JasonWW's picture
Sturgeon’s law is bunk. The parameters are not clearly defined. It’s very easy to say 90% of everything is crap. It’s just opinion.
Just like the old saying, you can have it fast, cheap or good. Pick two. Due to the fuzzy parameters you can make it fit virtually every scenario.
I think it’s more of a psychological phenomenon rather than any actual facts.
cabfrank
Because of teacher the enabler (and because I haven’t heard it in so long) I am now going to play Southern Cross very loud, and have a beer. It’s not even seven o’clock here, so I doubt the neighbors will complain, but if they do, I’m blaming teacher. They will probably be confused.
flashycali
Yeah I too blame Teacher for my unproductive afternoon spent watching music videos on youtube….all his fault! Big Smile Party
teacher
teacher's picture
I hear ya’ men… mission accomplished!!! Big Smile . Big Smile . Big Smile . Thumbs Up
I too have been totally unproductive because of watching ‘oldies music videos’ on YouTube this afternoon & evening…… Big Smile
Oh well…. whatever I needed to do will just have to wait till another day. It is not like it was ‘life & death’ stuff anyway…….. Big Smile ….. Beer . Wink
ToyKeeper
ToyKeeper's picture
JasonWW wrote:
Sturgeon’s law is bunk. … I think it’s more of a psychological phenomenon rather than any actual facts.
That’s kind of the point. People’s judgements and complaints typically say more about the person than about the thing being judged. And that’s okay, as long as they recognize it, which I think Sturgeon’s Law attempts to do. Most things don’t appeal to most people, because of differences in taste. If anything, I’d estimate that 90% is generously optimistic. The actual ratio of music I don’t like is probably closer to 99%. I don’t even remember the last time I heard anything on the radio which appealed to me. But that doesn’t mean the music is actually crud; it just doesn’t fit my narrow range of tastes.
Okcupid did a similar study at one point, though the article seems to be gone ever since they restructured their site. They found that people who tried to appeal to a general audience got a lot of 3- and 4-star ratings, but very few at 1, 2, or 5 stars. They didn’t receive many messages and weren’t very successful at finding matches. Meanwhile, people who proudly flew their freak flags, openly displaying tattoos or unusual physical features or an entire wall of pokemon or whatever, received mostly 1-star and 5-star ratings. And they usually found matches fairly quickly.
In many endeavors, there is really no point in being mediocre… because being judged at only 3 or 4 stars isn’t good enough to get into Sturgeon’s 10% category of “not crud”. Instead, it works better to identify and amplify uncommon traits. That means getting a whole lot of 1- and 2-star ratings, but for the people who like it, they’ll really really like it and, in their minds, it’s not 5 stars… it’s more like 500.
So, with that in mind… 90% of adages are crud, including Sturgeon’s Law. Thumbs Up
I just hope the FW3A won’t be crud.
joechina
Last seen: 1 day 10 hours ago
ToyKeeper wrote:
… I don’t even remember the last time I heard anything on the radio which appealed to me.
My last one was Alice Merton: No Roots , last year.
