Awesome! I wanted to build something like that, triple with 1 red emitter and 2 white emitter. What driver did you use? Could you give some detail please? Thanks.
This is a “CWF Dragon” which is a FET+1 but instead of combing the two channels it has a separate pad for the 7135s. I then customized Crescendo where the ramp of the two channels isn’t completely parallel and the 7135 channel ramps up and then off then the FET channel ramps up and max. There is a couple frames of overlap between the two channels as it looks a bit odd with the hard switch to the FET channel from the 7135 and vice versa
In the process of changing the LED’s in a Tiny Monster TM16, took some fitting of 4 individual 20mm MCPCB’s and then I got em glued in with JB Weld (out of Arctic Alumina Thermal Adhesive) So tomorrow I will wire up the 4 XHP-35’s in parallel and see where it’s at. Should be considerably brighter with a tighter beam profile from the HI style 35’s. I aim to try keeping the thermal resistor in there somewhere so the stock driver functions as intended, will see how that works out.
I did this once before and was seeing around 7200 lumens, the TM16 comes with 4 XM-L2 in series so replacing them with 4 XHP-35 in Parallel actually works out pretty well. (or it did before, hope it does again. lol) In stock form with the XM-L2’s it’s making 4170 lumens with a semi-large hot spot.
Being forgetful as all get out, I had the MCPCB’s fitted and glued in before I realized they needed emitters on em. Sure would have been tough re-flowing the 35’s onto the bare boards after the JB Weld set up! lol :person_facepalming:
Since I have to help my Aunt in the morning, I got the TM16 assembled this evening. Quad XHP-35 up and running, thermistor has glue drying to hold it in place. I really don’t enjoy soldering leads on those tiny things!
I have Convoy XP centering rings on the MCPCB’s at the moment to help hold pressure down onto the still setting MCPCB’s, those will either have to be shaved or removed to get proper focus so I know the beam isn’t correct as it stands, but it sure is bright! I’ll try it in the lightbox before I go to bed, give the dollop of JB Weld some time to set up on that little thermistor before I upend it into the box.
Ow the famous Dragon as I predict… unfortunately Charles didn’t sell single driver, 5 driver per lot which is very expensive. Very nice job anyway, and definitely sound complicated .
Simple build, Sofirn C8F, XPL HI V2 1A and TA driver with Narsil…
Nothing extreme here but this host is a real bargain at $13 (spent twice that money into the components) Considerably brighter than my X6 with triple XPL. Probably selling this one when the 21700 version releases.
Replaced driver with 17mm Mountain Electronics driver with D4 firmware.
Replaced stock microswitch with a different one
Replaced stock aluminum star with a copper Noctigon (16mm star filed down to 14mm)
Replaced stock emitter with XPL HI 4000K 5D
Wire bypass performed on both head and tailcap springs (with copper disk added at the top of each spring to protect the wire bypass’ solder.
Aluminum ring glued around top of external switch button. Converts the raised pushbutton into a flush pushbutton. Greatly minimizes chances of accidental pocket activation when lockout is not used.
Not a hard mod as I’ve done this before previously on a black SP10 and on a Thofire TK05. However, I quite like the look of the blue anodizing on this one.
If you mean the SP10B’s driver retaining ring I did it the usual way:
Wrap head of the light in 3M indoor stairway grip tape. This is a very sticky and grippy rubber tape that provides great grip, yet peels off cleanly when done.
Then I just used Snap-ring pliers inserted into the slots in the ring and turned and off it came.
If you mean the metal switch-boot retaining ring, I didn’t remove it. I just glued a new ring on top of the old one with arctic alumina.
Bought one of the latest batch of BLF-348’s from Gearbest and found out they are putting 219C’s in them instead of the advertised 219B 45K so I put in a Samsung LH351D instead. I think the dome is a little too big but i got it together and it looks fine so, good enough.
Also flashed my D4 with Anduril thanks to some extra inspiration from user goshdogit - now to do some temp calibration cause this thing got WAY hotter than I expected so the temp must be way off.
I got my new Titanium Emisar D4 and it’s a beaut! The copper head section is superbly made and finished, the battery tube has a square checkering for knurling, just all in all a very well done little light! And the 219C’s make 3100 lumens at start on a VTC6, works for me! I really want it to have Anduril like all my others but I am loathe to disassemble this beauty. It’s so deserving of candlelight though, and the ability to limit the ceiling on the ramp works magic to handle all the heat, so I’ll probably end up taking it apart anyway and getting it converted.
