Test/review of Charger Folomov A4
Charger Folomov A4
Folomov is new on the charger market and has started with some fairly powerful chargers. This is a four slot charger that can charge with up to 3A, but also charge with low current for small cells.
The cardboard box lists lot of specifications, battery types and features.
The box contains the charger, a power supply and a instruction sheet.
The charger has one 12V input barrel connector.
The user interface has four buttons, one for each slot and large display.
After putting a battery in a slot the current will flash for some time.
When flashing a short press on the slot button will change current in this sequence 250-500-1000-2000-3000-2000-500-250, holding down the button will change chemistry between LiIon and LiFePO4.
The user interface is slightly slow, i.e. a two fast presses is not detected.
I have one complain about the interface: When a current is changed for one channel, the adjustment time for that channel is extended, but not for the other channels, i.e. with 4 batteries in the charger you do not have time to adjust each slot in sequence, before the last slot starts. The solution is to put one battery in at a time and select current for it, then the next.
The display is fairly simple, each slot has a large animated (when charging) battery symbol, a chemistry text, a charge percent, the voltage and charge current.
Display during charge, the bottom line will change between current and voltage.
The slots uses the usual construction and works well. They can handle batteries from 29mm to 69.9mm long. The new 70mm cells are a very tight fit and very long protection 18650 will not fit.
The charger can nearly handle 70 mm long batteries, there is no problems with flat top cells.
Measurements
  • Charger will charge a LiIon with 0.4mA when full.
  • Charger will discharge a LiIon with 0.25mA when not powered.
  • Charger will discharge a NiMH with 0.05mA when not powered.
  • Below 0.7V the charger will show “Er” and charge with about 3mA
  • Between 0.8V and 2V NiMH is assumed
  • Above 2.0V LiIon is assumed
  • Voltmeter is within 0.02V in the full range.
  • Voltmeter will stop updating when charging is stopped.
  • Charger will restart if battery voltage drops to about 3.9V.
  • Charger will restart if battery is removed or power is cycled.
  • Power consumption when idle is 1.05 watt
4.2V LiIon charging
Charge current can be selected from 250mA, 500mA, 1000mA, 2000mA and slot \#1 and \#4 can do 3000mA, but not when the charger is filled.
A nice CC/CV voltage charge curve with termination at about 100mA
The other 3 channel is the same.
The two other capacities works fine.
This fairly old cell is handled nicely at 1A charge current.
Charging with 0.25A also works fine.
These two smaller cells I charged at 0.5A and it worked fine.
A 2A charge, termination current is about the same. The charger do not have perfect control of the CV phase, but it works fine.
3A works the same way
Four cells at 2A
When charging with a total current of 8A it needs nearly 4A from the 12V input.
M1: 46,0°C, M2: 47,5°C, M3: 47,3°C, M4: 43,1°C, M5: 46,7°C, HS1: 66,8°C
M1: 61,8°C, HS1: 64,0°C
The charger takes about 10 seconds to start.
If the button is pressed during that time the current is changed and the time is extended.
3.6V LiIon charging (LiFePO4)
The LiFePO4 charge curves looks good.
NiMH charging
Charge current can be selected from 250mA, 500mA, 1000mA, 2000mA and for slot \#1 and \#4 3000mA
This is a voltage termination with no top-off charge and no trickle charge. This means the batteries will not be filled completely.
The other slots is the same.
The two high capacity cells works the same way.
The voltage termination also works fine at 0.25A.
Here with an AAA cell.
Voltage termination gives fast detection of a full cell.
Fast charging at 3A.
With four cells the charger can do two cell at 2A and two at 3A.
For charging NiMH at maximum speed it needs about 2.5A from 12V, it is easy to see on the input current when the 3A charge is finished.
M1: 66,7°C, M2: 62,5°C, M3: 62,1°C, M4: 64,9°C, M5: 55,4°C, M6: 63,3°C, HS1: 92,2°C
M1: 62,8°C, M2: 48,7°C, HS1: 66,6°C
NiMH also needs about 10 seconds to start, the charger turns current off to measure voltage.
When adjusting the current the wait period is extended.
A closer look at the pauses, they are 0.1sec every second.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger may look a bit simple, but it has what is needed for charging two types of LiIon and NiMH and it can do it slow or fast, depending on what is needed. I like the simplicity of the user interface, but would have liked it a bit more responsive and a longer timeout when using it.
Because it terminates NiMH on voltage a one or two hour top-off charge would have been nice.
I will rate it as a good charger.
Notes
The charger was supplied by a Folomov for review.
Thanks for the review.
Capability aside, is it safe/advisable to charge AA Eneloops at 3A?
Safe: Yes
Advisable: No
You can get chargers with higher charge current from brands like Duracell and Varta
The high speed is fine if you need the cell charged asap, but not if you want a long life from the cell.
Thanks for the review HKJ! Looks like good charger. Another to the buy list.
Thanks for the review!
I don’t understand why manufacturers don’t give their slots the additional millimeter to make it fit all cells.
These large current fluctuations near the end of the charging cycle, what is causing them? And are they in any way harmful to the cell?
The control loop* is probably not designed perfectly, making the regulation a bit too lively. As long as the current mostly stays below maximum current and slowly drops it will not harm the battery.
The control loop is the part of the circuit that takes the measured current and use it to increase/decrease the charge current. The way to increase/decrease charge current may be to change a pwm oscillator (or it might be something else).
Thanks for the review this charger is on sale at one for 25. I picked it up and it’s 2 cell sibling it’s on sale for 15 dollars. Can’t beat it for 15 2 cells at 2 amps or 1 at 3 amp. I’ve had it about 2mobths now. And it’s been a great charger. I like how it starts at 250mah. If you have quick fingers you can put all 4 cells in and adjust the current. But it’s not a deal breaker for me. If I don’t need the cells quickly which I had don’t I have piles and piles of cells. I’ll just let it charge at 250. Sometimes 500 if I’m hard on my cells on discharge. Why be hard charging them.
But I’ve used the 2 amp and 3 amp charging just to try it out and it works great. Only did the 3 amp on some 26650s
Has anyone had issue with their A4? Ozythemandias found an interesting glitch where at first one bay appeared to charge extremely fast. And then later the bay started acting like a battery was always in it.
I’ve had that happen to mine once but not exactly like that. And it was exactly in slot 3 as well. Also real quick if you touch the charger or turn a battery while it’s charging and sometimes removing one battery while the other 3 are charging the voltages and percentages jump up across all the batteries. Try it sometime.but it always terminates correctly with my dmm. 4.19 everytime. I don’t know what the refresh rate is on it. Battery was done charging, took it out to put another in the screen was back to the regular screen. When I inserted the new battery it went straight to full. When I knew it was completely dead. I took it back out and unplugged it. Plugged it back in and havnt had it happen since. I will say though I’ve seen some other reviews say this. If you use the 2 amp charging on all 4 slots it makes a lot of heat. It will start fading the screen display while it charges until it cools back off. IDK if it will become permanent with repeated use. I’ve seen one imr review where the screen failed I believe or another battery site. I see it with mine. If you do 2 amps on all 4 slots put a fan on the charger where. It gets a decent amount of airflow. It really needs a fan or a more expensive screen that can take the heat. Even my a2 has the screen fade a 2 amp charging on both channels the display gets really hot. The batteries don’t get dangerously hot but the charger gets up there. All in all with that said I’d buy the charger Again no hesitating, my a4 and my opus run 24 hours a day. I usually limit my charging to 1 amp. That’s all that’s needed mostly. I have enough batteries I don’t need to really charge at 2 amps. Most of the time.
I just got it a few hours ago. It is Worth the $25 I paid for it. I still love my Fenix ARE-C2[I have 3 of them] but they are outdated a bit. Will always love my Opus BT-C3100 2.2.
I charged a few batteries @ 3A
Battery: Orbtronic 26650 5750mAh[Brand new]
Starting Vol…=3.62V
Finishing Vol.=4.21V
Time=1h 24m
Battery: VTC6[2 Years old]
Starting Vol.=3.58V
Finishing Vol.=4.17V
Time=45m
The end voltages were w/ my DMM which pretty much lines up w/ the chargers voltages.
I am estimating the charging is ~ twice as fast as the Opus charges at 2V
Now we will see how durable it is. Two of my Fenix ARE-C2 chargers are almost 4.5 years old. Thumbs Up
Early in the game for Mr. Folomov,but I like it so far
Someone mentioned the sliders were stiff in another review. Mine are perfect. Just about every charger I have had , I needed to put some lubricant on them. Mine do not need it.
I LIKE the fact that it gives the batteries a FULL charge,my Fenix chargers certainly do that w/ voltages of 4.22/23/24 very common.
The VTC6 only charged to 4.17V. I expected that as most chargers will not charge older batteries to 4.20V.
I just got it today. I noticed this. With my Orbtronic 26650 5750mAh. It went in @ 3.62V, withing several seconds it jumped to 3.81V and 52%. It stayed at those numbers for 20 minutes. I took the battery out and measured it w/ DMM. It was 3.79v. From that point on it acted normal as the battery charged.
I am not sure why it did that.
In the end it charged it fast and the end voltage was spot on w/ my DMM.
