Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
SKILHUNT M200 USB Compact EDC Flashlight - NATURAL WHITE 4500 - 5000K
https://www.gearbest.com/led-flashlights/pp_009560930996.html?wid=1433363
Main Features:
● Unique design
Unique compact design, it is non-slip, waterproof, and abrasion resistance.
● Brightness level
Press side switch to low, mid, high, turbo, cycle.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable
● Super bright and latest CREE XP - L LED, max 1200lm, high-performance, high-efficiency, and energy conservation
● Built-in magnetic charging system, fast charge and convenient
● Automatic memory function, remember last used setting and can be preset to specific output mode for instant access.
● Low-voltage prompts function
The light will flash when the battery is low, remind the user to replace the battery on time.
● Powered by 1 x 18650, 2 x CR123A, 2 x RCR123A ( battery is not included )
● Voltage: 2.7 - 8.4V
Waterproof rate: IPX - 8
JETBeam BR10GT LED Rechargeable Bike Light
https://www.gearbest.com/led-flashlights/pp_1848493.html?wid=1433363
Main Features:
● Unique design, compatible with multiple platforms: bicycle, handheld, rail mount and many more
● Rechargeable by USB port with water-resistant rubber cover
● Springs at both ends mitigate shock for increased reliability
● Maximum output of 1100 lumen reach out to 230 meters
● Digital stitch constant circuit control. Up to 14 hours of runtime
XM-L T6 LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1836395.html?wid=1433363
Emitters: Cree XML-T6
Emitters Quantity: 12
Lumens Range: >3000 Lumens
Color Temperature: 6000-6500k
Feature: Waterproof,Cool,Strong
Battery Quantity: 4
Battery Included or Not: Yes
MHVAST TG20 USB LED Dual Mode Flashlight
https://www.gearbest.com/led-flashlights/pp_1830730.html?wid=1433363
Specifications:
● Emitter Type: XPL V6
● Material: aluminum alloy
● Mode: high, medium, low, ECO; strobe, SOS, beacon
● Lumens: 1250 Lumens
● Battery Configurations: 1 x 18650 or 2 x CR123 Li-ion Battery ( not included )
● Lumens Range: 235M
● Waterproof: IPX 8
● Input Voltage: 2.7 - 6V DC
● Charge: micro USB charging
1. Jetbeam TH15 Tactical Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009530129764.html?wid=1433363
Main Features:
● Unique triple tail switches ( JETBeam’s patent ) and a side switch design
Using triple tail switches and a side switch design, it is convenient for us.
● Seven lighting modes
Very bright, bright, medium light, low and medium light, low light, energy saving, flashing, so many brightness options are convenient for us.
● Powered by 1 x 18650 2600mAh rechargeable lithium-ion battery
● Waterproof rating: IPX - 8 ( 2 meters underwater )
● Voltage: 5V
Irradiation distance: 228m
2.Nitecore LR12 1000lm Flashlight Camping Light
https://www.gearbest.com/led-flashlights/pp_009307968687.html?wid=1433363
Main Features:
● Unique design
Tail cover rotary switch design, it is non-slip, waterproof, and abrasion resistance.
● Five lighting modes
Signal light, low light, medium light, high light, extremely bright, so many brightness options are convenient for us.
● Powered by 1 x 18650 rechargeable battery
● Light source: CREE XP - L HD V6 beads
● Voltage: 3.7V
Irradiation distance: 200m
3.Nitecore MT21C Tail Magnetic Flashlight
https://www.gearbest.com/led-flashlights/pp_009877396626.html?wid=1433363
Main Features:
● Aluminum material
Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● lighting modes
Extremely high light, high light, medium light, low light, energy-saving gear, flash, SOS, beacon light, so many brightness options are convenient for us.
● Voltage: 3.7V
4.Nitecore GEM10UV Stepless Dimmable Flashlight
https://www.gearbest.com/led-flashlights/pp_009998598739.html?wid=1433363
Main Features:
● Aluminum material
● 3000mW UV light
● Widely application
It is suitable for identification jewelry and so on.
● Powered by 1 x 18650 rechargeable battery ( not included )
● Voltage: 3.7V
Jetbeam WL - S4 - GT Searchlight LED Flashlight
https://www.gearbest.com/led-flashlights/pp_009241569169.html?wid=1433363
Main Features:
● Aluminum alloy material
Using aluminum alloy material, it is non-slip, waterproof, and abrasion resistance.
● Button switch
● Six lighting modes
Extremely low light, high light, medium light, low light, flash, SOS, so many brightness options are convenient for us.
● Powered by 4 x CR123A or 2 x 18650 battery ( not included )
● Light source: CREE XHP70 beads
● Voltage: 5V
Irradiation distance: 400m
Charging time: 4h
Head diameter: 63mm
Body diameter: 26mm
Length: 243mm
New Arrival June 27th
1.Convoy S9 XML2 Direct Charge Side Switch Flashlight - BLACK 6000 - 6500K
https://www.gearbest.com/led-flashlights/pp_009210413813.html?wid=1433363
Main Features:
● Side switch
● lighting modes
When the flashlight is off, press and hold the button to start the moonlight file 0.1 percent.
When the flashlight is off, click the button, you can turn on the gear after the last flashlight was turned off ( the gear is 0.1 percent moon - 3 percent low - 30percent mid - 100 percent high, double-click strobe flash )
When the flashlight is turned on, long press the button, you can turn off the flashlight.
● Powered by 1 x 18650 battery ( battery is not included )
● Light source: CREE XML2 beads
● Voltage: 4.2V
Waterproof rate: IPX - 6
2.Convoy C8+ XPL HI Portable LED Flashlight - BLACK 4000-5000K
https://www.gearbest.com/led-flashlights/pp_009317032402.html?wid=1433363
Main Features:
● Tail switch
● 12 groups of 55 modes
● Light source: CREE XPL HI beads
● Voltage: 4.2V
3.TANK007 TK360 - 1 R5 Outdoor Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009441545082.html?wid=1433363
Main Features:
● Aluminum material
● Tail button switch
● One mode
● Powered by 1 x CR123 or 1 x 16340 battery ( battery is not included )
● Light source: CREE XP - G2 beads
● Voltage: 0.8 - 4.2V
4.Outdoor Lighting Multifunctional Aluminum Alloy Charging LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009309728890.html?wid=1433363
Main Features:
● Aluminum material
● One mode
5.Convoy M2 Portable LED Flashlight - BLACK 6000 - 6500K
https://www.gearbest.com/led-flashlights/pp_009917547179.html?wid=1433363
Main Features:
● Unique design
Simple design, it is non-slip, waterproof, and abrasion resistance.
● Light source: XML2 beads
● Voltage: 4.2V
Yippie! I was waiting verry long for the next XR-E Flashlight! :smiley:
Hi friend,
Thank you for your attention to Gearbest.
Once we have now item we will listed here.
July 2nd new arrival:
1.Mecarmy PS14 - A Aluminum Alloy LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009589450488.html?wid=1433363
Main Features:
● lighting modes
Turbo, high, middle, low, strobe, so many brightness options are convenient for us.
● Powered by 1 x 14550 battery
● Light source: CREE XPL - HD LED, one cool white one neutral white
● Voltage: 1 - 5V
2.Mecarmy FL10 Portable LED Flashlight - BATTLESHIP GRAY
https://www.gearbest.com/led-flashlights/pp_009629756080.html?wid=1433363
Main Features:
● Titanium material
Made of TC4 titanium, lightweight, portable, permanent color, corrosion and scratch resistant finish.
● lighting modes
Triple clicks to access turbo mode, click again for strobe
● Standard micro USB charging port with charging indicator
● Keyring attachment hole design, easy to carry
● Bottom bezel design for self-defense in the emergency
● Powered by built-in 120mAh lithium-ion polymer rechargeable battery
● Light source: CREE XP - G2 S4 LED beads
● Voltage: 3 - 5V
Waterproof rate: IPX - 5
3.NiteCore BR35 1800LM Bicycle Lamp - BLACK
https://www.gearbest.com/led-flashlights/pp_009849224740.html?wid=1433363
Main Features:
● Aluminum material
● lighting modes
Extremely high light, high light, medium light, low light, so many brightness options are convenient for us.
● Built-in 6800mAh rechargeable lithium-ion battery
● Light source: CREE XM - L2 U2 beads
● Voltage: 3.7V
Charging time: 3h
July 5th New Arrival
1.Tank007 TC29B Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009227476125.html?wid=1433363
Main Features:
● Aluminum material
● Five modes
● Light source: CREE XR - E Q5 beads
● Voltage: 3.0 - 4.5V
● Button switch in the head
Irradiation distance: 500m
Charging time: 4h
Working time: highlight 3.5 hours, low light 10 hours
2.Orcatorch D820V Waterproof Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009191031179.html?wid=1433363
Main Features:
● Powered by 1 x 26650 rechargeable battery
● Titanium alloy side key switch, convenient operation
● USB charging function
● Professional anti-pressure waterproof structure design, diving depth of up to 150 meters
● Anti-reverse design to prevent damage to the circuit caused by battery reverse mounting
● Battery over-discharge protection
● Light source: XM - L2 ( U4 ) 4pcs / XPG(R5)2pcs /(UV purple)2pcs beads
● Voltage: 3 - 8.4V
Waterproof rate: IP68
Irradiation distance: 318m
Charging time: 3.5h
Sorry, this was ironic. It’s a verry old LED with not up to date efficiensy.
I dont want to by a Flashlight with Cree XR-E LED.
July 9th New Arrival:
1.Xtar VC4 18650 4-slot Lithium-ion Ni-MH Battery Charger - BLACK
https://www.gearbest.com/chargers/pp_009676245583.html?wid=1433363
Main Features:
●Four slot
Compatible with most rechargeable lithium-ion batteries and nickel-chromium-nickel-metal hydride batteries.
●LED indicator light design
Real-time battery voltage display, each cell voltage is approximately 10 percent of the battery capacity.
● LCD display, innovative turntable style
● Charge current display, suitable for all 5V USB power supplies
● Four-slot independent
● 0V voltage activation function, over-discharged battery
● 0.5A and 1A charging current
● Overcharge / overcurrent / overvoltage protection
2.Xtar Rocket SV2 Smart Quick Charger - BLACK
https://www.gearbest.com/chargers/pp_009806508920.html?wid=1433363’
Coupon code: IT$LEDSV2
Main Features:
●Double slot
● LCD screen displays battery power, charging status and charging current
● Automatic identification for simultaneous charging of lithium-ion and nickel-metal hydride batteries
3.lii-500 18650/26650 Lithium Battery Charger with LCD Display - BLACK
https://www.gearbest.com/chargers/pp_009343206925.html?wid=1433363
Main Features:
Different specifications of batteries can be charged simultaneously such as 18650 / 26650 / AA / AA / A batteries, etc.
4 charging slots
Features 4 charging current regulator, 300mA / 500mA / 700mA / 1000mA. Each channel works independently
LCD screen
Updates every second to keep you in the loop on the charging process
Quick test mode
4 channels detect the battery capacity quicker than the Nor mode Short circuit / over-current / over-charging / over-discharging / reverse polarity protection / temperature control / charging between 1.65 - 2.2V / bad battery recognition and activation
DC input voltage: 12V / 2A
Car charger input voltage: 12V / 1A
Please NOTE: batteries are not included.
4.Allmaybe TC2 Lithium-ion Battery Charger - BLACK
https://www.gearbest.com/chargers/pp_009360164937.html?wid=1433363
Coupon code: IT$LEDTC2
Main Features:
●Double slot
● It can charge two batteries and one external device at the same time.
● Shell made of ABS fire retardant material, excellent heat dissipation design
● Ingenious display
●0-volt activation function, to save over-discharge lithium-ion battery
●Automatic identification, intelligent selects its appropriate charging gear ( 0.5A / 1A / 2A ) for battery
●The sub-capacity test function, through the release of capacity, accurately measure the actual battery capacity
July 12th New Arrival:
You can use the coupon code: CA%LA704
1.SUNREI Rechargeable Smart Sensor Fishing Headlight - DARK KHAKI
https://www.gearbest.com/headlights/pp_009850577828.html?wid=1433363
4 Lighting Modes, Last up to 110 Hours,
Adjustable Strap,
IPX6 Waterproof Headlamp for Camping Running Hiking
Product Specification
Technical Parameters (Mode, Lumen, Lighting distance, Burn time):
Middle in Spotlight (70 lumen, 46m, 18hours)
High in Spotlight (230 lumen, 85m, 5.6 hours)
Low in Spotlight (9 lumen, 15m, 110 hours)
Sensing (140 lumen, 65m, 5.6hours)
2.SUNREI Youdo2s Outdoor LED Waterproof Super Bright Hiking Headlights - GREEN YELLOW
https://www.gearbest.com/headlights/pp_009440823245.html?wid=1433363
Headlight Brand: SUNREI
Type: LED Headlamp
Main Emitters: Cree XP-G2
Emitters Quantity: 3
Luminous Flux: 190
Battery Type: 3 x AAA battery(not included)
Battery Quantity: 3
Battery Included or Not: No
Beam Distance: 30-80m
Impact Resistance: 1M
3.SUNREI Youdo 3 Outdoor Mountaineering Hiking Rechargeable Headlights - CELESTE
https://www.gearbest.com/headlights/pp_009704558827.html?wid=1433363
Main Emitters: CREE XPG3 R4
Luminous Flux: 190
Feature: Waterproof
Battery Type: Lithium-ion Polymer Battery
Battery Quantity: 1
Rechargeable: Yes
August 4th New Arrival:
1.NiteCore C2 6500 Lumen Rechargeable Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009157651840.html?wid=1433363
Main Features:
• Powerful output, blazing bright 6500 lumen max output and maximum range of 398m
• Compact body, easy to carry and comfortably fit in your palm
• 5 brightness levels and 3 special modes through the single button control
• Memory feature to access the previously used brightness
• Charging time is 3 hours
2.Xtar D26 Outdoor Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009173812850.html?wid=1433363
Main Features:
• Using high-quality CREE XM - L2 U3 chip, max output of 1100lm and beam distance of 310m
• Features 4 brightness modes, ( 1100lm / 600lm / 200lm / 60lm ), suitable for using in different situations
•Mid-size and lightweight, convenient to carry
• Power supply: 1 x 18650 ( not included ) / 1 x 26650 battery ( included )
3.Mecarmy PS16 Stainless Steel Flashlight - DARK GRAY
https://www.gearbest.com/led-flashlights/pp_009412356782.html?wid=1433363
Main Features:
●Stainless steel material
Ultra bright USB rechargeable flashlight, constructed from CNC precision machined stainless steel, it is non-slip, waterproof, and abrasion
resistance.
●lighting modes
● Powered by 1 x 16340 battery ( included)
● Light source: CREE XP - G3 S5 LED beads
● Voltage: 3 - 4.5V
4.Mecarmy PS14 - A Aluminum Alloy LED Flashlight - BLACK
Main Features:
●Aluminum alloy material
●lighting modes
● Voltage: 1 - 5V
5.Mecarmy FL10 Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009546450146.html?wid=1433363
Main Features:
●Titanium material
●lighting modes
● Unique titanium switch prevents accidental activation
● Voltage: 3 - 5V
Hi GearBest!
Is there any chance you add this product to your store?
Nitecore NU25
August 13th New Arrival:
1.WUBEN A21 Portable Super Bright LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009529056619.html?wid=1433363
Main Features:
●Aluminum body material
Using aluminum body material, it is non-slip, waterproof, and abrasion resistance.
● Side button switch design, easy to use
●Light modes
5 modes / strobe / stepless dimming design, so many brightness options are convenient for us.
●IP - X8 waterproof
● Powered by 1 x 21700 battery ( included )
● Light source: CREE XHP70 LED beads
2.Brinyte DIV15S Portable 4-LED Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009610893343.html?wid=1433363
Main Features:
• Using high-quality CREE XPL - Hi V3 bead, max output of 3800lm and beam distance of 442m
• High / medium / low / super low / beacon / SOS / flash seven modes, suitable for using in different situations
• Side switch, easy to use
•Made of aluminum alloy, comfortable hand feeling
• Rotatable adjustable dive handle bracket for easy use
• Mid-size and lightweight, convenient to carry
•IPX - 8 waterproof, can sneak into the water 200 meters
• Power supply: 2 x 26650 battery ( not included )
August 21st New Arrival:
1.Boruit BC09 Super Bright Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009895787548.html?wid=1433363
Main Features:
• Using high-quality CREE XM - L2 chip, max output of 750lm and beam distance of 180m
• Power supply: 1 x 18650 ( not included ) / 2 x CR123A battery ( not included )
• LED will give you stable and bright light, nonthermal radiation, safe and reliable
• IPX - 8 waterproof
2.Nitecore C1 Portable 1800lm Waterproof LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009933401264.html?wid=1433363
Main Features:
● Featuring a premium CREE XHP35 HD E3 LED for a super bright 1800 lumens max output
●High efficient constant current circuit board provides constant illumination
● Crystal coating technology combined with precision digital optics technology for an extreme reflector performance
●Power indicator beneath the side switch displays remaining battery power and blinks to report battery voltage to the nearest 0.1V
● The built-in ATR module automatically regulates its output and adapts to the ambient environment, maintaining optimal performance
● Powered by one 18650 battery or two CR123A batteries ( battery not included ), the C1 offers up to 300 hours of runtime on low and up to 30 minutes on the turbo
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish with a magnetic tail cap
● Toughened ultra-clear mineral glass with anti-reflective coating; waterproof level is up to IPX8, two meters submersible
3.Boruit BC05 Super Bright Portable LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009823667715.html?wid=1433363
Main Features:
• Using high-quality CREE XP - L2 chip, max output of 1180lm and beam distance of 285m
• High / medium / low / strobe / SOS modes, suitable for using in different situations
• Power supply: 1 x 18650 ( not included ) / 2 x CR123 battery ( not included )
This image is wrong, both here and on your site! :person_facepalming:
It is related to the Nitecore Concept 1… :expressionless:
September 6th New Arrival:
1.Haikelite MT01 Waterproof Long Shots Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009983851378.html?wid=1433363
Main Features:
●Ultra clear double-sided AR coated toughened glass lens, the light transmission is up to 99pct
●Waterproof level up to IPX - 8, the flashlight can work normally even on heavy rain days
● The shot distance is up to 300 meters with the wide beam range
●Five brightness level: extremely low: 50lm; low: 250lm; mid: 850lm; high: 2500lm; strobe: 2500lm
● When the light is on, fast single click and long press to lock out the switch
● Multifunctional flashlight anti-reverse protection, anti-discharge protection, battery power detection function, low-voltage protection, temperature control protection
● The flashlight powered by 3 x 18650 / 18700 battery ( not included )
2.HKV A11 LED High Power Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009157508212.html?wid=1433363
Main Features:
• Aviation aluminum alloy shell has excellent scratch resistance and corrosion resistance
• It can be used for 100 meters underwater
• 3 kinds of light can be adjusted underwater: white, blue and red
• Dual-lubricated O-rings provide dual safety for underwater use
• High performance integrated cooling surface on the base ensures low heat
• Scope of application: outdoor diving, hunting, patrolling, camping
• 4 x 18650 lithium-ion battery ( not included )
3.HaikeLite MT07S XHP70 II 5000lm Portable LED Flashlight - BLACK 6500K
https://www.gearbest.com/led-flashlights/pp_009671498460.html?wid=1433363
Main Features:
●Utilize a CREE XHP70.2 bead that can produce a blazing 5000lm illumination
●SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
●Lockout function: a single click followed by a long click to lockout the switch, repeat to unlock
● Digital full current regulation, anti-reverse protection, anti-discharge protection, thermal control remove / activation, last mode memory function
● Power indication light: 100 - 50pct: blue LED on; 50 - 9pct: blue LED flashes; below 9pct red LED flashes
●5 brightness levels: low ( 200lm ); mid I ( 550lm ); mid II ( 1300lm ); high ( 2300lm ); hidden turbo ( 5000lm )
●2 special mode: strobe ( 5000lm ); hidden moonlight ( 2lm )
4.HaikeLite MT07S - HI Portable CREE XHP35 HI LED Flashlight 7 Modes for Outdoor - BLACK COLD WHITE
https://www.gearbest.com/led-flashlights/pp_009791663221.html?wid=1433363
Main Features:
● 7 brightness levels: hidden turbo - high - medium II - medium I - low - hidden strobe - hidden moonlight
● Utilize a CREE XHP35 HI bead that can produce a blazing 3000LM illumination
● Waterproof IPX - 8, suitable for usage in rainy weather
● Powered by 4 x 18650 Li-ion battery ( not included )
● SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
5.HKV A28 Outdoor Portable LED Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009662776193.html?wid=1433363
Main Features:
• Using high-quality CREE - XHP70 II chip, max output of 4000lm and beam distance of 500m
• High / medium / low / flash modes, suitable for using in different situations
• Power supply: 2 x 18650 ( not included ) / 2 x 26650 battery ( not included )
September 11th New Arrival:
1.HKV A15 LED High Power Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009789576955.html?wid=1433363
Main Features:
2.MT35Plus Super Bright Outdoor USB Charging Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009939052333.html?wid=1433363
Main Features:
• Aluminum alloy, practical and durable
•Key breath lamp design to detect the voltage and remaining power in time
30 percent above, green light is on, 10 to 30 percent, red light is on, 10 percent, red light is flicker.
• PTZ hole design, can be used for fixed lighting
• Underwater 1m waterproof capacity, 1.5m anti-fall rating
• Four modes: moonlight file, medium bright file, high brightness file, very bright file
• Silicone button, widened and non-slip
• 2 x 18650 battery / 4 x 18650 battery ( not included )
3.WUBEN A21 Portable Super Bright LED Flashlight - BLACK
Main Features:
●Light modes
●IP - X8 waterproof
December 19th New Arrival:
HaikeLite MT03 Portable 21000lm High Power LED Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009427144440.html?wid=1433363
Main Features:
• Using high-quality XHP70.2 lamp bead chip, max output of 21000lm
• Power supply: 4 x 18650 battery ( not included )
•Widely application
It is suitable for camping, fishing, hunting, hiking, searching, working.
