Isn’t there like a 5700k version of this emitter? I would love to try it if it wasn’t 6500k CW. I highly doubt this thing can produce more than 5000 lumens on a single 26650, but if it could, that is amazing even if it is only at 0 second.
There seems to be an xhp50.2 version as well if you google it
a sst 50 light will be available next month
https://img.alicdn.com/imgextra/i4/402098252/TB25CuQzbSYBuNjSspfXXcZCpXa\_!!402098252.jpg
https://img.alicdn.com/imgextra/i1/402098252/TB2viS2i_mWBKNjSZFBXXXxUFXa\_!!402098252.jpg
https://img.alicdn.com/imgextra/i2/402098252/TB2U6VFzXGWBuNjy0FbXXb4sXXa\_!!402098252.jpg
https://img.alicdn.com/imgextra/i3/402098252/TB2US5QzbSYBuNjSspfXXcZCpXa\_!!402098252.jpg
A mod friendly light … Swap driver , keep chrging since it is inside the tube , voila !
Now that is an awesome find!!! Interested!!!
Neal confirms that pictures match
there is a youtube review of an eagle eye light direct driven with a single SST40 emitter running around 2400 lumens. I think if the maker can get enough current to each LED, this light might be quite impressive. Can’t wait to get mine…shipping next week is the rumor.
With a reflector and lens installed i doubt any sst40 is doing 2400lm without burning up shortly after
Interested…
With a FET driver it might be able to achieve 5,000lm, but 6,000lm with 7135 driver is impossible.
It could be a 3 channel FET driver, with 1x7135 on the 1st channel, 8x7135 on the second channel, and direct FET on the 3rd channel.
I found the triple XHP50.2 version on a Chinese site but not sure where to order it for the US. Any idea if the triple 50.2 version uses a different driver than the SST40 version? The 50.2 is 6v right?
Oh… it makes sense and Amutorch wouldn’t be the first one to use BLF drivers in their flashlights…
It should be a different driver, as there are 7135s in the sst40 version, meaning the emitters are in parallel.
Would the xhp 50 have more lumens or the sst40?
Every second time I read the name of this light it’s “Avaria” instead of “Avarita”.
And “Avaria” is a homophone of a Polish word for “failure”……
Same thing in Portuguese
yup, xhp50.2 would do maybe over 4000 lumen per led, so 3 led would be over 10000 lumen in theory
but finding or making the driver is pain in the @ss
so SST40 is more suitable for this light
Thank you! I went ahead and pulled the trigger on this one.
Try an “Arius” knife. I always register it as “Anus”. :person_facepalming:
I’m thinking swapping the 3x50.2 with 3x Nichia 144a 90CRI would have great results.
Maybe 3x LH351D 90CRI would perform almost as good too.
Anyone got one of these?
From my perspective a far more interesting question about this light is the power source. It is shown a single 26650 battery, and to deliver 6000 lumens, is going take 20 amps if not a little more, and there are not a lot 26650’s out there that can sustain 20 amps for a long period. The more output you want, such as from xhp50.2, the more power you need. 10,000 lumens is going to require 30+ amps, and if you thought 20 amps for a sustained period was difficult, 30 amps is much much worse, and in either case, the heat dissipation is going to be very big problem, very quickly. The Keeppower IMR 5200mah according to HKJ’s testing isn’t good for much more than 20 amps.
