When I had the djozz springs made a few years ago by the Tevema factory, the price break for bulk purchase (20 cents! instead of a dollar) was 2000 springs. At the time there was no way there would be interest enough for 2000 springs so I did not dare to go for that number. I’m glad that the interest is so high this time, that helps enormously for the price!
Please please go for the better mechanical properties, the intl-outdoor spring works fine for such a short spring with little travel but a longer spring of the same material will fail bigtime mechanically.
@teacher, I was just checking with the community to see if they wanted something else.
This past, I spent a lot of time during my free time during research about which type of beryllium copper that we could use in a spring application.
There are other types of beryllium copper that would be even better suited to a spring. However, they only have 22% IACS, and therefore, not worth the money over a phosphor bronze B-2 spring at 19% IACS.
There is 60% IACS beryllium copper that can be used. However, it is too rigid and its module of elasticity in tension is lower than 38% IACS Beryllium Copper, so not as good for a spring.
TLDR: 38% IACS Beryllium Copper C17530 is best suited for this application.
Use the small spring on drivers that have components on the back of them. A Simple FET+1 driver doesnt have any components on the back so you can use a big spring. A driver with a half dozen 7135 modules on both sides will require this skinny spring so it wont interfere with those components
1. Gold plated= gold color and gold plating for corrosion resistance
We will be using a zinc plating as it has a bit lower cost, and still good corrosion characteristics and a nice silver look, which I prefer over a gold plating.
2. Big springs almost always used in the tailcap, and small springs are used on the driver, as the contact pad of the drivers are usually way too small for such a large spring at the base(9mm), and not interference with small components.
3. No it will not be too tight. This is why dual beryllium copper springs are the grail of flashlights. It allows for universal cell compatibility, and shock absorption, compared to a single spring and a brass button, which upon a large enough shock, it will transfer the kinetic energy to the cell, and may collapse the terminal. This is no problem for a dual spring light. Most springs can’t provide low enough resistance for high power lights, but using beryllium copper 38% IACS mitigates this.
Nothing that is even measurable at all. It’s just a coating, between 0,75um and 1,25um, or 0,00075mm-00125mm.
The coating is so thin it does not affect electrical characteristics at all.
Nickel could be used, but zinc does actually protect the metal more from corrosion more than nickel, is less expensive, and actually has 5% more conductivity than nickel(27% vs 22%).
TLDR: For springs, zinc and gold are probably the best bet, but zinc spring is cheaper and still great, so we are going with this,
After going through many similar projects I would feel much better seeing the final product tested by a BLF member before we go plunging into a group buy.
If that is information your willing to share I would also be interested. I have considered having batches made in XYZ sizes many times. If Richard is just special I understand though, he holds a pretty warm place in my heart too
Gold would be my first choice… Did they give a price? I can live with zinc. As long as we are absolutely sure to get something besides bare copper……
If there is a price break like that at 2000pc I would also be very interested to know. And +1 for the mechanical properties.
Finally, thank you so much for doing this BlueSwordM!!! Put me down for 100 + 100. If there is a significant price drop at 2000pc as mentioned above I’d be in for a lot more.
1. The supplier is not very keen on providing samples with less than a 1000 springs. I will take the plunge for the purchase, but that means I will not be able to start the real group buy in 3 weeks to amass the necessary hobby funds to fund this project, if the demand grows to say 2000 springs.
However, if I can get a sample of something like 10 springs, that problem could easily be solved as that would prove they are good suppliers and good springs.
2. Yes, ASF, I will contact you too so you can sell springs at your store too, once the group buy is over. Spring bypasses are great, but they require so much work and time, so very high current springs are a blessing.
3. Yes they did give a price. And the gold coating is about 5% more expensive. And I also prefer a silver look compared to gold for some reason :laughing:
4. 2000pcs should be even less expensive per spring. It will be amazing if I can reach a price of 0,25$US per spring, or even lower.
Finally, you are very welcome. I am very honored for you to be thankful to me, vesture of blood. And, added 100 small springs and 100 big springs. I think I’ll have to halt the group buy interest list soon enough though at a total of 2000pcs, including the big and small springs.
A pre-made sample of the same material even if not the exact dimensions costs them nothing. Just to be able to check the fit and finish and material. I don’t think anyone would hold it against you if you wanted to assume less risk and press them on this issue, I certainly would.
BlueSwordM it looks to me like making 2000 large and 1000 small would be pretty easy to do, especially if there’s a bigger price break at 2000.
Might help if you contact them and find out the difference. I know for myself if they are cheaper each piece I’m going to up my order a little more. The main thing being if they are really good, everyone’s gonna want them. You really need to test samples even if there something they have surplus from another order. Just my two cents
Thanks for doing the GB. :+1:
