HL is obviously over rating their lights again. They are not using the 4000K 70.2 that Texas_Ace was using. Plus TA’s measurement of 24k lumen was a little bit high if I remember correctly.
HL should be rating them closer to 17k to 18k as I think that’s the lower end of the range with all springs bypassed.
These 2 lights are not very close to each other. I think the DX80 is actually around 28k lumen and can sustain that for quite a while even as the voltage goes down. It’s 8 cells extend that max output.
The MT09R are not 24k lumen. It uses a FET driver so as the voltage drops the max output drops. It can drop fast due to only 4 cells.
I hope Texas_Ace can comment on what the new HL can actually put out. It’s not 24k lumen. Maybe the CW are doing 16k lumen and NW 20k lumen for a short amount of time? It’s been a while, so I don’t remember off hand.
I think the DX80 is in a whole other league from the MT09R and I don’t even like Imalent. Some people say the current versions have all the bugs worked out. It can also sustain 7k lumen for over 90 minutes. A record I believe.
I would wait for proper reviews of the new MT09R before making any decisions. Let’s see if they got the drivers right and if they live up to the claims.
I got a mt09r p2 bin 5700k with TA driver… I got 21000 lumen at turn on and 18000-19000 lumen after 20-30 seconds… i measured with Texas ace lumen tube…
My guess it’s not going to. It’s probably (IIRC) closer to something like 18k lumens OTF, whereas the original version did something like 13k~14k lumens
I started a post for the replacement drivers: Haiklite MT09R GB replacement drivers
I got an email from HL on 6/7, telling me that the replacement driver would be shipped on that date.
I don’t think it’s safe to assume anything on these lights. I will be interested in the reviews once these factory lights ship to see if they got the drivers and UI correct and see if they come close to specs.
Haikelite does normally do warm whites. Typically they just use cool white and neutral white. So there could be an error in the description.
