Massive fraud on 18650s in the Littokala Aliexpress stores!
Thank you for the comparison! Fortunately, most of my lights are under 8 amps. Although, I have two D4s (Nichia and Cree). For whatever reason, I can't get more than 10A with real 30Qs, VTC5s, 25Rs, 20Rs, so these fakes don't deprive me of much with the current collection. Lol
It's great to have additional ammunition with test data above!
You’re going to avoid the whole brand because you bought from a fake store? This seems a bit extreme…
The real Liito Kala store is 133859, not 217753.
I received mine and they were clearly fake so I filed a dispute through Aliexpress using the positive end of the cell as evidence and describing the lack of serial number. Aliexpress stepped in and agreed with the seller because the seller apparently provided a “authorization file / purchase invoice from the brand owner” (Samsung). What should I do to provide more evidence? Should I remove the wrapper or would that make it worse?
Is there some unevenness in the wrapping that could lead to a conclusion of them being not from factory?
Can you measure internal resistance and compare with other good cells? Even of a different model….
In general, unwrapping shouldn’t hurt the proof in any way other than destroying evidence (i.e. wrap itself).
But it may affect the resolution - you won’t be able to return the items to the seller.
Oh, any photo/video of unwrapped cell in a charger will be less trustworthy unless you find some clearly visible markings on the cells.
I speak about the return because that’s what the seller asked for in my case.
I agreed on condition that the seller pays for shipping. They system does not allow such resolution, so I only sent a message with such requirement.
My case is still open and will probably be settled next Monday.
It’s really too bad this store apparently had to sell fakes. If they just sold the LG cell, it would have been a good price for a decent cell, and nobody would complain or feel ripped-off.
If someone is going to sell fakes, the least they should do is fill a 18650 can with sand, and put a crap 200mAh 14500 Ultrafire in it. Otherwise, it seems like they’re just not putting in the effort.
I’ve got one at home that is hilarious, it’s labelled Ultrofite, it is very lightweight with a ridiculous 4000+ rating, claims to be protected yet is no longer than an unprotected cell, and has the familiar red and silver wrapping. It came bundled with a noname brand zoomie. I must take a couple of pictures and post them for a laugh. I don’t know whether they spelt the name wrong deliberately, but why bother, it’s not like there would be any consequences.
Wow, faking an Ultrafire. They’re getting desperate!
So I wanted these cells for average light use, so they seem to fit the bill
BUT I did want cells to run my Sinner triple Nichia, my 2 late models Zebras (Mk 3 and 4) AND my new D4 that came at the same time.
Now I am wondering…I have 18 of these sitting here
I am going to email the seller…
Edit, they want a video of my testing procedure? wth
PP dispute
The Zebras should be fine, if these truly are 10A cells. I have both the SC600w MkIV HI and the SC600w MkIV Plus. The HI will only draw about 4-5 amps, at most. The Plus will draw more, but at most 6 amps on a fresh cell and 8 amps on a low cell (more current is needed to boost it up to required voltage from a low cell).
I use Sanyo NCR18650-GA cells in both. They’re 10A cells, and they work fine. If I know I’ll be using the Plus on max for a lot of time, I’ll stick in a Sony VTC6 cell, but it’s not really necessary.
As for your other lights, they may require something higher than 10A, or at least benefit from it. Chances are that anything using a FET driver (like the D4) will simply run a bit dimmer, but not actually use more than 10A.
Thanks WiTL
If they offer some for of refund, I guess I can rotate out all the KP’s I have at home and work… for ‘average lights’…
I am just paranoid about the Sinner or D4…
Is this store any legit?
aliexpress.com/store/133859
I recommend “Varicore” instead of “Liitokala”. I bought 4 batteries from this store and they are original and properly wrapped (I bought pointed version). Shipping prices are also fair.
And this is another store I have bought cells, but shipping cost is too much now:
https://www.aliexpress.com/store/1270703
I cannot afford to waste time or money on things that may or may not be what I’m wanting. So thanks for sharing your experience with a place I will not bother going to. You saved me a head ache. :beer:
I have video of cells, and showed the internal resistance is too high, I showed the four vents, I showed a real 30q to compare.
In the video, there are 2 older used 30qs and 2 of the new ones from AliExpress, all on the opus charger. You can see the two new ones have higher resistance.
Seller says ” buyers said that the product is a problem, but the picture provided is false, cannot prove that I have a problem with the product, but also seriously deal with customer service,thank you.”
Well if we all show them the cells we were sent, it proves he is selling counterfeit cells.
AI has ruled in the seller's favor. They stated I did not include adequate evidence of counterfeit such as including authentic cells in the pictures, etc.
Not really bothered as the cells are a fair price for what they actually are. They drive my modded Q8's fine. I wouldn't put them in anything that wants more than 10 amps though. I opened a dispute because the vendor is blatantly falsely advertising. Kind of shocked that so many valid and consistent disputes can be opened about a single product from a vendor and AI doesn't weigh the pattern of complains in their decision.
Maybe we should get all our complaints together and then reopen the lost disputes pointing at all that evidence?
If the seller does continue to say that our pictures and videos and evidence are fake, I would advise to pull a charge back if possible.
The risk with that is that Ali will then cancel your account, since it costs Ali quite a bit when you do a credit-card charge-back. They might not do it the first time, though.
Also, don’t you have to provide evidence of fraud to your credit card company? What is their criteria for charge-backs?
It is a shame that Ali is letting this vendor get away with what are obvious fakes. But, they’re only obvious to us. The Ali drone making the decision has no idea whether 4 holes is good or bad.
Even the vendor might not know they’re fakes. They could have been provided fakes by an unscrupulous middle-man.
Word for word, that was the response to me as well.
I sent a dispute to PayPal and within minutes, it was escalated to claim. The seller almost immediately sent a response to PayPal so it's on!
Point is, they're completely covering their arsse with scripted BS.
I’ve had many disputes in Ali (none about batteries thou) and they always, ALWAYS have sided with my complaints after a rejection or non-response from the seller, and I never had any negative consequence to my account (once got blocked by sofirn store, but that was a store sucker punch because of a negative review)
I find it unusual that Ali hasn’t sided with the buyer in this case. Maybe you could use pictures from other BLF threads as evidence to counterfeit. I do encourage anyone with these batteries that are different in any way to open a dispute and complain directly via message to the store and give them 1 star reviews (to product and store)
