I agree with those two, and I ALWAYS like orange.
This is not meant to be negative, it is just a thought. I wonder if it would make such a small light look cheap or toylike.
I would be a buyer regardless of color though, so I guess it would come back to earlier thoughts in this thread about letting Fritz make aesthetic decisions on his design.
Yes, in addition to the regular red, blue and green. This is Convoy, though. I don’t know if Lumintop has access to the same silver and grays as they do.
The prototype gray was fine to me except for the “seams” in the finish. I never noticed them on the earlier pics.
Same here. The “seams” would have been dismissed even if noticed though because one is used to seeing reflections and lighting artefacts in photographs that look like that, and ignoring them as not likely part of the object.
At the moment, Anduril uses a thermal regulation method which knows nothing about the actual host characteristics or driver. It simply senses “overheating” or “underheating” like a user-adjustable thermostat, with some information about magnitude, like the degrees of excess multiplied by how long it has been in that condition. From this, it attempts to find a happy medium, with the adjustment speed determined by the magnitude. It’s fairly universal and typically works well with no need to hardcode anything about the host itself. Also, the adjustments are so smooth they’re basically invisible without a lux meter.
But.
On such a small and overpowered light, like the FW3A, overheating can happen so fast that it barely even has time to react. By the time it senses that things are trending too high, the light could already by too hot to touch. It works fine on a larger host like a Q8, or at a more reasonable power level like 3 Amps, because sensor lag is much less of a factor there.
So I’m wondering if I should change it. It currently regulates fine from the default ceiling level of ~1100 lm, but it doesn’t drop fast enough from full turbo.
Instead, I could make it drop immediately (or at least very very quickly) to the highest regulated level of ~1100 lm whenever it senses any overheating condition while the FET is active. Even if it’s over by just 1 degree for just a few seconds, it’d trigger a full turbo step-down and shut off the direct drive circuit. Maybe it’d still do the smooth ramp-down, but it would no longer be invisible — it’d be fast enough to see, like 4 seconds. And since there’s thermal lag, it might continue to regulate downward for bit afterward, overshooting its ideal target level, but at least the host wouldn’t get anywhere near as hot as a slower method.
Although dropping from 100% power to ~25% power is a huge change in the amount of heat generated, to the eye it looks more like it’s going from 100% to 80%. Effectively, it looks like dropping only one level.
So.
What do people prefer?
Smooth but slow universal method which allows full turbo to run longer but may require the user to exercise common sense and turn the brightness down manually sometimes.
Fast drop to a hardcoded level which is safer but may potentially be a little oversensitive and uses code instead of common sense to enforce “turbo is for brief use only”.
There is also still a muggle mode, which probably couldn’t start a fire even if someone wrapped it in dark-colored insulation with a low ignition temperature. So, use that for the kids. The question is how it should behave in non-muggle mode.
- as flashaholic and as a person that knows that these are not toys, I would prefer option A, meaning that I would be responsible to take care of the light and turn it OFF or cool it down if needed (except, maybe, in unattended conditions).
- as a person that knows that [besides the thousands of enthusiast members that are in the GB lists to get 1 or more of these lights] there will be a sale of the FW3A beyond our lists, for “muggles” or not so “aware” people, I would carefully ponder option B.
I am inclined to say more A, however :smiling_imp:
Of the two options, I prefer the first: "Smooth but slow universal method...". I like the idea of more direct control of the light's output.
Thanks again TK for doing so much for this project, and continuing your efforts! This project would not be nearly so cool without your coding skills making a super cool UI :)
I can see points for both options, but I do know that I use my D4 less often than I intended to when I bought it because of the potential for burned fingers and lighting pants on fire (even if I’m not lying!). I carry a variety of flashlights, use them most days, know how to be safe and understand the dangers and I still can see the value in the second option.
Turbo in a light this size is not a feature that I’d use often. I’d show off to friends and family with it or use it if I need a lot of light quickly. Neither of those situations require minutes (or even a single minute) of turbo so I’m not so worried about a stepdown at the first sign of overheating.
I can guess that there are a bunch of folks who hate the thought of throttling down a light with this much potential, but I think that the second option is wisest.
What about an additional “expert mode”?
That might not be optimal from the manufacturers’s point of view, though. :laughing:
Btw: Btw: With this lamp you could - if not yet available - make a master degree in control engineering. A self-optimizing deadbeat algorithm would be fine.
