September 6th New Arrival:
1.Haikelite MT01 Waterproof Long Shots Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009983851378.html?wid=1433363
Main Features:
●Ultra clear double-sided AR coated toughened glass lens, the light transmission is up to 99pct
●Waterproof level up to IPX - 8, the flashlight can work normally even on heavy rain days
● The shot distance is up to 300 meters with the wide beam range
●Five brightness level: extremely low: 50lm; low: 250lm; mid: 850lm; high: 2500lm; strobe: 2500lm
● When the light is on, fast single click and long press to lock out the switch
● Multifunctional flashlight anti-reverse protection, anti-discharge protection, battery power detection function, low-voltage protection, temperature control protection
● The flashlight powered by 3 x 18650 / 18700 battery ( not included )
2.HKV A11 LED High Power Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009157508212.html?wid=1433363
Main Features:
• Aviation aluminum alloy shell has excellent scratch resistance and corrosion resistance
• It can be used for 100 meters underwater
• 3 kinds of light can be adjusted underwater: white, blue and red
• Dual-lubricated O-rings provide dual safety for underwater use
• High performance integrated cooling surface on the base ensures low heat
• Scope of application: outdoor diving, hunting, patrolling, camping
• 4 x 18650 lithium-ion battery ( not included )
3.HaikeLite MT07S XHP70 II 5000lm Portable LED Flashlight - BLACK 6500K
https://www.gearbest.com/led-flashlights/pp_009671498460.html?wid=1433363
Main Features:
●Utilize a CREE XHP70.2 bead that can produce a blazing 5000lm illumination
●SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
●Lockout function: a single click followed by a long click to lockout the switch, repeat to unlock
● Digital full current regulation, anti-reverse protection, anti-discharge protection, thermal control remove / activation, last mode memory function
● Power indication light: 100 - 50pct: blue LED on; 50 - 9pct: blue LED flashes; below 9pct red LED flashes
●5 brightness levels: low ( 200lm ); mid I ( 550lm ); mid II ( 1300lm ); high ( 2300lm ); hidden turbo ( 5000lm )
●2 special mode: strobe ( 5000lm ); hidden moonlight ( 2lm )
4.HaikeLite MT07S - HI Portable CREE XHP35 HI LED Flashlight 7 Modes for Outdoor - BLACK COLD WHITE
https://www.gearbest.com/led-flashlights/pp_009791663221.html?wid=1433363
Main Features:
● 7 brightness levels: hidden turbo - high - medium II - medium I - low - hidden strobe - hidden moonlight
● Utilize a CREE XHP35 HI bead that can produce a blazing 3000LM illumination
● Waterproof IPX - 8, suitable for usage in rainy weather
● Powered by 4 x 18650 Li-ion battery ( not included )
● SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
5.HKV A28 Outdoor Portable LED Diving Flashlight - BLACK
https://www.gearbest.com/led-flashlights/pp_009662776193.html?wid=1433363
Main Features:
• Using high-quality CREE - XHP70 II chip, max output of 4000lm and beam distance of 500m
• High / medium / low / flash modes, suitable for using in different situations
• Power supply: 2 x 18650 ( not included ) / 2 x 26650 battery ( not included )
• LED will give you stable and bright light, nonthermal radiation, safe and reliable
