Silicone cube doesn’t have to be 1 cm thick. A piece of silicone thermal pad of whatever thickness might help.
A silicone-based thermal glue shouldn’t impair mod friendliness significantly.
The one thing I don’t want to happen with the thermal stepdown is to have it just keeping ramping down indefinitely.
My D4 copper starts out great on turbo. But within a minute thermal rampdown has dropped the output to maybe 50 lumens. That’s WAAAAY too low. It should stop ramping down well before that point. Maybe at 500 lumens.
This is one of the things I like about my Eagtac DX3B… it stops ramping down at 70% no matter what the temperature sensor sees.
For Anduril, maybe have a user configurable floor on the rampdown?
That’s when the rot started, with digitisation. Philips didn’t realise what a monster they had made, or how easy it would soon become to rip the stream or just copy the things. Then Fraunhofer came up with codecs, such as mp3. Winamp, Shoutcast followed.
The rest is history
I still think my MiniDisc sounds very sweet, ATRAC encoded.
Now, an analogue master tape, straight to vinyl with some sympathetic balancing through a Neve desk = heaven. Through my Garrard 401, SME tonearm, homebrew pre-amp, QuadII valve amps and a huge pair of KEF transmission line monitors. Have to wait until the neighbours are out at work before turning it up though.
A bit different from some Spotify through a cruddy bluetooth speaker.
An option against to much heat can be different ceilings for SMOOTH RAMP and STEPPED RAMP. For your preferred ramp lower the ceiling, with 3 clicks you can switch to the other ramp where you can have full power if you need it.
Several things to explore (perhaps they already have been):
Improve the thermal path as best as possible (thermal glue or what not)
When it is turned onto turbo, increase the scan rate and/or turn up the derivative (D) of the thermal regulation PID to help with lag and make futurecasting more aggressive.
-Switch modes/tuning when the button is pushed.
Have a straight-up timed step down, but do it in small increments to appear as a ramp down to a certain level where the PID loop would take over.
Add a true sensor (are there open pins/space for that?)
Others I haven’t thought of.
I have no idea how much coding space there is/isn’t.
Yes, that is a significant portion of the difficulty here. The 7135 chips eat the extra voltage and produce heat at the driver, which allows the MCU to sense the heat much more quickly… while the FET burns it all off at the emitter, where the MCU can’t feel it as much.
However, the 7135 chips are still active at 100% in all FET modes except for level 150/150, full turbo. This hybrid method helps spread the tint shift over a wider span of levels, and reduces visibility of PWM.
What I have now already uses two slightly different algorithms depending on whether the FET is active. When the FET is engaged, the algorithm does thermal adjustments 4X faster. And the adjustments run at 8 different speeds depending on how far above or below the target temperature it is, which also increases the drop-down speed. So it changes at anywhere from 31 steps per second to 1 step every 8 seconds, depending. There are 512 total steps in the adjustment range.
Instead of simply adjusting 4X faster, but still doing it proportional to the measured amount of excess, I’m wondering if I should just make it drop directly to the highest non-FET level as soon as it detects any overheating at all. This could still be smooth, executed over a period of 4 or 8 seconds, but it would not even try to regulate between ~1100lm and full power, because 1100lm isn’t sustainable unless the light is in a very cold environment.
Yeah, it says a lot that people who have a D4 have been suggesting option B.
Physical lockout isn’t as feasible on the FW3A, but soft lockout is a lot easier to access. Using 4 clicks instead of 6 may not sound like much, but it helps. And the lock/unlock blinks are like 50X faster. So, locking or unlocking takes about 1 second instead of 3+.
Plus, it works as a momentary mode at the current ramp floor. So, it doesn’t even need to be unlocked for quick tasks.
Yes, it already tracks rate of change and calculates predictions of what the temperature should be in the near future. It then adds together several predictions over time so the response will also be proportional to how long it has been too hot or too cold. And the response is proportional to the sum of the predictions. If I understand correctly, this makes it a PID algorithm. Response is [p]roportional to an [i]ntegration of [d]erivatives.
Problem is, as far as I can tell… the MCU doesn’t feel the heat fast enough to correctly steer into the turn, so it slams against the wall before sufficiently correcting. So I might make it steer as hard as possible as soon as it senses a turn coming, so it won’t hit the wall on the first turn. After that though, it seems fine.
That’s fixed already. The D4’s thermal floor was too low. This is adjustable at compile-time, but the current thermal floor for FW3A is the 1x7135 level, or about 160 lm. I find that, while hand-held, it can sustain about 700 or 800 lm, or while tail-standing in a room at 70 F / 21 C it can sustain maybe 300. This 160 lm floor gives it a bit of extra adjustment room, but is still quite a bit brighter than the D4’s floor.
Additionally, the updated algorithm is less prone to overshooting and oscillating, so it’s less likely to hit the floor. And if a more direct turbo step-down is implemented, that makes it even less likely to hit the floor since it won’t have as much heat to shed while regulating.
Things are a bit different in muggle mode. In that case, it drops to about 10 lm when hot. No regulation is attempted. The goal there isn’t to maintain the highest possible output level, but to make sure a 3-year-old won’t start a fire.
Already implemented. It’s just intentionally difficult to do. The user would either have to hold the button in momentary mode at turbo (ouch), or configure the thermal parameters to have the highest possible ceiling and lowest possible sensor calibration (stick the light in a freezer and tell it it’s like 50 C).
But … don’t.
Exactly. The user can have full power in one ramp and a lower ceiling in the other.
By default, both ramps only go up to ~1100 lm. And one starts at moon, while the other starts at ~10 lm. But those are easy to change.
Not sure if thermal glue is going to be feasible or not, or how helpful it would be. I tried a sheet of thermal transfer material at one point, but it didn’t seem to help a lot. I think the attiny gets most of its heat through the legs, not through the surface of the chip. And I’m very reluctant to slather glue all over it.
When the FET is active, it already increases adjustment speed by 4X or more.
The step-down, if implemented, isn’t timed. It’s still temperature-based, but would have a big response and would be easy to activate. A hair trigger, so to speak. Step-down would probably go smoothly over a period of 4 or 8 seconds. Afterward, the regular PID method would take over.
A true MCPCB-mounted sensor would be nice, but is probably not feasible on this light.
contactcr was nice enough to test the most recent build, the faster-but-still-regulated-during-FET “option A” on an Emisar D4. This was the result:
The level it regulated to may be a bit low, looks like about 300 lm or so, but it was also told to use a pretty low thermal ceiling. And it was probably not being held in a hand, so it wouldn’t have had as much heat sinking as it would during normal use.
Other than that though, I think this result looks pretty good. It adjusted fairly quickly to a stable level, didn’t overshoot, and didn’t bounce around.
People often keep the development process behind closed doors, so it looks like things just pop out of Zeus’s forehead fully formed.
But yeah, development is usually somewhat messy. The difference here is that the process is more transparent. And this project has been particularly slow due to a variety of setbacks.
Ah, if people only knew what it takes to bring a product to market, or to a specific customer. Had to smile of a light popping out of Zeus’s forehead. I can hardly wait to read the discussion about what battery should have been used. . . .
I did some testing on FW3A proto2 running at full power with a fresh 30Q cell, with the thermal ceiling set to 45 C. It was laying sideways on a table with a fan pointed at it. Here was its regulation pattern:
The main difference between options is whether that initial plateau exists. The light gets a bit hot to hold during that.
Although not shown here, beyond the right edge of this graph I put a few drops of water on the light, and it started getting brighter. Then I touched it with ice and it got brighter faster. So… it does step back up when the temperature drops; it’s just not shown on the graph.
Vickers, E., (2010)
The Loudness War: Background, Speculation and Recommendations
AES 129th Convention, San Francisco, CA, USA 2010 Nov 4-7 (Conference Proceedings - non periodical)
Serrà, J., Corral, Á., Boguñá, M., Haro, M., & Arcos, J.L. (2012).
Measuring the Evolution of Contemporary Western Popular Music.
Scientfic Reports, 2, Article 521. https://www.nature.com/articles/srep00521
Percino, G., Klimek, P., Thurner, S., (2014)
Instrumental Complexity of Music Genres and Why Simplicity Sells
PLoS ONE 9(12): e115255
Askin, N., Mauskapf, M. (2017)
What Makes Popular Culture Popular? Product Features and Optimal Differentiation in Music.
American Sociological Review, Vol: 82 issue: 5, page(s): 910-944. http://journals.sagepub.com/doi/abs/10.1177/0003122417728662
I think the important thing is to remember these studies focus on ‘popular’ music ie what is marketable to the lowest common denominator in order to maximize sales.
I would always squeal with glee whenever another engineer would demolish the cherished subjective world view of the audiophile cognoscenti. Bob Carver remains a hero of mine.
That seems roughly equivalent to what Okcupid found when looking at people who try to make their profile appeal to a general audience instead of showing the things which make them unique. They end up with a lot of 3-star and 4-star ratings but virtually no 5-star ratings.
Whatever the 10% is which counts as “not crud”, I think at least most people can agree that pop music isn’t it. Being too generic makes it bland and mediocre.
