I found the triple XHP50.2 version on a Chinese site but not sure where to order it for the US. Any idea if the triple 50.2 version uses a different driver than the SST40 version? The 50.2 is 6v right?
yup, xhp50.2 would do maybe over 4000 lumen per led, so 3 led would be over 10000 lumen in theory
but finding or making the driver is pain in the @ss
so SST40 is more suitable for this light
From my perspective a far more interesting question about this light is the power source. It is shown a single 26650 battery, and to deliver 6000 lumens, is going take 20 amps if not a little more, and there are not a lot 26650’s out there that can sustain 20 amps for a long period. The more output you want, such as from xhp50.2, the more power you need. 10,000 lumens is going to require 30+ amps, and if you thought 20 amps for a sustained period was difficult, 30 amps is much much worse, and in either case, the heat dissipation is going to be very big problem, very quickly. The Keeppower IMR 5200mah according to HKJ’s testing isn’t good for much more than 20 amps.
This is not such a good cell for high drain due to its heavy voltage sag. Something like a Liitokala blue or black or a Shockli 5500 would be a lot better choice. The really hot ticket would be the Samsung 30T 21700 which can do 30A continous. Depending on the driver design, a too powerful battery might burn up the driver or emitter. More testing is needed.
Yes, 2400 lumen would be it’s output in raw form. Output drops a bit once installed in a light.
In the video
Chris does not have an integrating sphere to measure with. He is using a ceiling bounce measurement and his correction numbers might be off a little.
I imagine 1800 to 1900 lumen is more realistic for OTF lumens. So this NA40 could in theory be doing 5500 lumen with a FET driver and good battery (not so much the KeepPower). 5000+ lumen is a realistic number to me. I’m curious to see output tests with a good battery.
For that light you would need a boost driver for sure and current designs are limited in output. The Acebeam EC65 is a quad xhp35-HI running a single 21700 cell. It can put out 3750 lumen. So right around the 45 watt range (Same as Lexels and Loneoceans boost driver limit). If you have 3 xhp50.2 in 6v parallel on a 45w driver and a good high drain cell you can expect a bit less output than the NA40, maybe 4000 lumen, but have it as steady output, where the FET driver immediately starts dropping voltage and output.
IDK, this xhp50.2 version sounds strange and there’s a reason we have not seen that style of light. Further investigation is needed.
