No option for “Prefer NO USB port/internal charging”? That’s my vote.
There’s no way I’m trusting charging Li-ion cells as an afterthought with the quality deficiencies rampant in the marketplace and the consequences of improper charging/treatment of Li-ion cells. I’ll continue charging my cells externally where I can keep an eye on them.
Maybe some manufacturer with a proven trustworthy and strict quality control track record might get my green light for internal charging some day, but for now, the only instance I can think of that it might be a good idea is for solar charging DBSAR’s BLF Ultimate Lantern while in the field as being worth the risk.
Hmm, that would be pretty handy though.
Good points, Phlogiston. +1
Who knows if in a year or two USB-C falls short and a version superior to USB-C is adopted. That may make it not easy to find USB-C cables. My personal preference on USB-C is that I will wait and see how it does once it has been widely implemented and used for long enough for real world durability to be accepted. Maybe it will live up to the expectations and be universally adopted or maybe it will be quickly passed over for the next bigger innovation. Hopefully it does live up to expectations and increases the universality and durability of charging, but I won’t be surprised if it doesn’t.
Carrying around a cable is far lighter, smaller, and more convenient than carrying around a whole charger.
Especially if your phone already uses that same type of cable and then you don’t need to carry around any additional stuff.
Great for when you need to charge the flashlight outside of home, like at work or when travelling.
Instead of 1) unscrewing flashlight 2) removing battery 3) placing battery in charger 4) screwing flashlight together to avoid misplacing a part 5) waiting for the battery to charge 6) unscrewing the flashlight again 7) placing the battery back into the flashlight 8) screwing the flashlight together again
You can simply plug in a cable, wait for it to charge, and unplug the cable.
Just like a phone.
You can charge it from a laptop or phone charger without needing a bulky li-ion charger.
I completely understand. I am just not very trusting of charging cells inside the light I may be depending on. If I know I will be gone for most of the day I will throw a few extra cells in my pocket and not even take a charger with me. When travelling I take a charger. My work doesn’t require the use of a flashlight for any kind of extended duration’s so that really never comes up. I am kinda anal bout lights. I usually have at least two on me and if I know I will be gone for the entire day I usually have a few more in my “zombie bag” that goes everywhere with me. That’s what the wife calls my bag I carry with all the things a man thinks he needs to go grocery shopping. You know, knives, guns, flashlights, fire starters, first aid kit, multi tool, para cord, etc. LOL
I don’t know, I just don’t trust onboard charging. I don’t want a 4 dollar battery destroying a 50 dollar light. Will it happen? Most likely not. I just don’t want to take the chance. I do like a lot of the options that USB C can bring into the flashlight industry though.
Obviously both the battery you use and the charging circuitry in the light should be high quality for safe use.
This is no different or any less safe than having a high quality li-ion charger.
Built in charging does not require a special battery, it could be any battery you currently use.
Yes, I understand that I don’t need a special battery and we would all like to think that what we are buying and using are high quality and will work perfect without anything happening to them. Just me personally if, and it’s a big if, something does happen to a cell I would prefer it to destroy itself and not take my light out with it. That’s it. If the battery takes out a charger with it that is fine with me but I would prefer to still have my light intact and working for the back up cells I have in my pocket. Some folks spend lots of money to mod and fine tune their lights and make them truly unique. I am sure they wouldn’t want a cell, cheap junk or good quality, even quality stuff fails occasionally, destroying their light.
I do have a few of those cells with the charging circuit built on top of the cell itself so I can remove the cell and plug the micro usb cable into it. They are pretty cool and work fairly well but they do make the cell not fit in some picky lights. I guess if I had to choose I would take that over any light with on board charging.
Seems like people severely overestimate how often a cell “goes bad”.
Even if a cell does go bad there is pretty much no chance of it destroying a light.
Go look at some video of people shorting the cells, the worst that happens is they get hot and stop working.
Having the charging built into the cell just makes it a smaller and lower quality charging circuit, and limits the cells available unless you want to mod a high quality cell like a 35E to have that circuit.
Having it built in to the flashlight is basically the same thing as having it built into the cell, but you have the option of using any standard cell.
I voted Micro B because they’re currently super common, most all my other camping gear charge from them, so it means less cables to carry.
Honestly, if it had been an option I’d have voted lightning cable as I prefer the lightning cable to even USB C - it has the benefits of USB C and is currently more common.
I own nothing with USB C yet so don’t want to have to take yet another “universal standard” cable with me
I know where you’re coming from there, waxing twilight.
I’m very picky about what lights I might buy with internal charging. At the moment, the only model I have like that is the Fenix UC35. Reputable brand, good reviews, tested to make sure my unit is behaving itself.
I don’t actually use the UC35, but I carry it as my backup 18650 light in backpack EDC. I don’t like the cold white LED, but it’s fully IPX8 waterproof, even if the USB port is uncovered, so it serves as a waterproof spare cell carrier and USB charger. I can even use it as a light if I’m really stuck
Normally, I prefer to swap cells and take the depleted ones home for charging in a dedicated charger. The UC35 only comes into play when I’m travelling or I expect to go through several cells that day.
As of 20th March 2018, the major smartphone manufacturers have agreed with the EU to support USB-C in all new smartphone models within 3 years. That can mean direct USB-C support, or the provision of a cable allowing the phone to interoperate USB-C with some other connector.
I voted for USB-C because (flash)lights with this newer standard will be still usable with the cables current in 5 years.
And i like the dual insertable socket/plug.
Here are some german language news articles, from which i’d found the english links i’d post at BLF:
Cool. I found the last couple of paragraphs in this one interesting:
I agree with the EU that devices should not come with a USB charger in the box, both to avoid electronic waste and because I prefer to pick a nice, universal multi-port charger for myself anyway.
Among other things, there will be a transitional period sooner or later where I have a mixture of old devices using micro USB and new devices using USB-C. Manufacturer-supplied chargers tend to be basic, single port units, so they only support one connector type. I’d far rather buy a universal charger with both connector types from Anker and just have one charger to carry.
i also agree that the charger shouldn’t be supplied now, i have several charger that i forgot completely about them
my charger has 5+1 Quick charge port+1 Type C port and it is enough for a geek like me
I remember the time around 2007, when miniUSB was the most common plug. Even when microUSB was released, i had a lot devices with miniUSB, which has been more sturdily in my opinion.
I hope USB-C will be as good as miniUSB.
Well, I would never call a magnetically coupled charge connector simply “magnetic charger” either. But, you’re right that it’s probably the most common interpretation of that phrase. Induction chargers are simply called “wireless” chargers usually. Sorry if I caused anybody confusion (ironically :person_facepalming: )
It doesn’t work on my phone with a small thin metal disc. Although to be fair, the disc is ferrous so it probably messes with the magnetic field…
Where would the receiving coil even go on an 18650 tube light? The tail?
I have preference for USB micro because most chargers have this connector.
Switching to USB-C is only useful with high A charging. Considering the chargers in a flashlight usually are weak there isn’t a real benefit for USB-C.
Many current power supplies have microUSB, but most new and all future power supplies will have USB-C.
Switching to USB-C is useful for easy plug injection, longer plug life and longer compatibility to power supplies in the future. In 2 years most chargers will be USB-C.
