13638 posts / 0 new
rbmcmjr
Last seen: 1 year 9 months ago
Tom Tom wrote:
Streaming has been the death of music, I’ll stick to my vinyl and CDs curmudgeonly.
I can remember a time when audiophiles were bemoaning that CDs were the death of music.
gravelmonkey
Last seen: 10 hours 18 min ago
Option B sounds good. 1100lm after Stepdown is still awesome.
Firelight2
Firelight2's picture
Last seen: 1 hour 45 min ago
The one thing I don’t want to happen with the thermal stepdown is to have it just keeping ramping down indefinitely.
My D4 copper starts out great on turbo. But within a minute thermal rampdown has dropped the output to maybe 50 lumens. That’s WAAAAY too low. It should stop ramping down well before that point. Maybe at 500 lumens.
This is one of the things I like about my Eagtac DX3B… it stops ramping down at 70% no matter what the temperature sensor sees.
For Anduril, maybe have a user configurable floor on the rampdown?
Tom Tom
That’s when the rot started, with digitisation. Philips didn’t realise what a monster they had made, or how easy it would soon become to rip the stream or just copy the things. Then Fraunhofer came up with codecs, such as mp3. Winamp, Shoutcast followed.
The rest is history
I still think my MiniDisc sounds very sweet, ATRAC encoded.
Now, an analogue master tape, straight to vinyl with some sympathetic balancing through a Neve desk = heaven. Through my Garrard 401, SME tonearm, homebrew pre-amp, QuadII valve amps and a huge pair of KEF transmission line monitors. Have to wait until the neighbours are out at work before turning it up though.
A bit different from some Spotify through a cruddy bluetooth speaker.
ChibiM
ChibiM's picture
Last seen: 5 hours 9 min ago
I honestly thought you wrote: meltdown ..
Brings me to the next question: how hard is it to add a meltdown mode to the FW3A?
lol
joechina
Last seen: 17 hours 57 min ago
An option against to much heat can be different ceilings for SMOOTH RAMP and STEPPED RAMP. For your preferred ramp lower the ceiling, with 3 clicks you can switch to the other ramp where you can have full power if you need it.
nvanlaar
nvanlaar's picture
Last seen: 4 days 18 hours ago
Several things to explore (perhaps they already have been):
  • Improve the thermal path as best as possible (thermal glue or what not)
  • When it is turned onto turbo, increase the scan rate and/or turn up the derivative (D) of the thermal regulation PID to help with lag and make futurecasting more aggressive. -Switch modes/tuning when the button is pushed.
  • Have a straight-up timed step down, but do it in small increments to appear as a ramp down to a certain level where the PID loop would take over.
  • Add a true sensor (are there open pins/space for that?)
  • Others I haven’t thought of.
I have no idea how much coding space there is/isn’t.
“Facts don’t care about your feelings.”
~Ben Shapiro
ale9g
Last seen: 9 months 4 weeks ago
I’m in for one thanks
ToyKeeper
ToyKeeper's picture
Last seen: 10 hours 54 min ago
Tom Tom wrote:
TK, could it be that your thermal control works better at the lower levels because a lot of the heat is being generated in the 7135s rather than the LED. The 7135s being closely thermally coupled to the MCU and its internal temperature sensor. I suspect you are mostly controlling the temperature of the driver, not the LEDs.
Without having a temperature sensor on the LED MCPCB itself, I suspect trying to control it in B: is a difficult exercise. So a timed step-down bringing the 7135s back into use seems the most practical way forward.
Otherwise I think you would need two different control algorithms…
Yes, that is a significant portion of the difficulty here. The 7135 chips eat the extra voltage and produce heat at the driver, which allows the MCU to sense the heat much more quickly… while the FET burns it all off at the emitter, where the MCU can’t feel it as much.
However, the 7135 chips are still active at 100% in all FET modes except for level 150/150, full turbo. This hybrid method helps spread the tint shift over a wider span of levels, and reduces visibility of PWM.
What I have now already uses two slightly different algorithms depending on whether the FET is active. When the FET is engaged, the algorithm does thermal adjustments 4X faster. And the adjustments run at 8 different speeds depending on how far above or below the target temperature it is, which also increases the drop-down speed. So it changes at anywhere from 31 steps per second to 1 step every 8 seconds, depending. There are 512 total steps in the adjustment range.
Instead of simply adjusting 4X faster, but still doing it proportional to the measured amount of excess, I’m wondering if I should just make it drop directly to the highest non-FET level as soon as it detects any overheating at all. This could still be smooth, executed over a period of 4 or 8 seconds, but it would not even try to regulate between ~1100lm and full power, because 1100lm isn’t sustainable unless the light is in a very cold environment.
djozz wrote:
I’m all for thermal regulation B. Reason: I have a D4
Yeah, it says a lot that people who have a D4 have been suggesting option B.
djozz wrote:
the lock-out requirement (manual or via software) … my nuts found it … on turbo
Physical lockout isn’t as feasible on the FW3A, but soft lockout is a lot easier to access. Using 4 clicks instead of 6 may not sound like much, but it helps. And the lock/unlock blinks are like 50X faster. So, locking or unlocking takes about 1 second instead of 3+.
Plus, it works as a momentary mode at the current ramp floor. So, it doesn’t even need to be unlocked for quick tasks.
djozz wrote:
detection to detect the rising speed as recorded by the MCU, correlate that to what the actual temperature course is of the flashlight head and calculate an appropriate stepdown response. This could also work to get the correct stepdown when not fully ramped (but over sustainable current).
But your current temperature control algorithm may already work at this level?
Yes, it already tracks rate of change and calculates predictions of what the temperature should be in the near future. It then adds together several predictions over time so the response will also be proportional to how long it has been too hot or too cold. And the response is proportional to the sum of the predictions. If I understand correctly, this makes it a PID algorithm. Response is [p]roportional to an [i]ntegration of [d]erivatives.
Problem is, as far as I can tell… the MCU doesn’t feel the heat fast enough to correctly steer into the turn, so it slams against the wall before sufficiently correcting. So I might make it steer as hard as possible as soon as it senses a turn coming, so it won’t hit the wall on the first turn. After that though, it seems fine.
My D4 copper starts out great on turbo. But within a minute thermal rampdown has dropped the output to maybe 50 lumens. That’s WAAAAY too long. It should stop ramping down well before that point. Maybe at 500 lumens.
That’s fixed already. The D4’s thermal floor was too low. This is adjustable at compile-time, but the current thermal floor for FW3A is the 1×7135 level, or about 160 lm. I find that, while hand-held, it can sustain about 700 or 800 lm, or while tail-standing in a room at 70 F / 21 C it can sustain maybe 300. This 160 lm floor gives it a bit of extra adjustment room, but is still quite a bit brighter than the D4’s floor.
Additionally, the updated algorithm is less prone to overshooting and oscillating, so it’s less likely to hit the floor. And if a more direct turbo step-down is implemented, that makes it even less likely to hit the floor since it won’t have as much heat to shed while regulating.
Things are a bit different in muggle mode. In that case, it drops to about 10 lm when hot. No regulation is attempted. The goal there isn’t to maintain the highest possible output level, but to make sure a 3-year-old won’t start a fire.
Already implemented. It’s just intentionally difficult to do. The user would either have to hold the button in momentary mode at turbo (ouch), or configure the thermal parameters to have the highest possible ceiling and lowest possible sensor calibration (stick the light in a freezer and tell it it’s like 50 C).
But … don’t.
Exactly. The user can have full power in one ramp and a lower ceiling in the other.
By default, both ramps only go up to ~1100 lm. And one starts at moon, while the other starts at ~10 lm. But those are easy to change.
Not sure if thermal glue is going to be feasible or not, or how helpful it would be. I tried a sheet of thermal transfer material at one point, but it didn’t seem to help a lot. I think the attiny gets most of its heat through the legs, not through the surface of the chip. And I’m very reluctant to slather glue all over it.
When the FET is active, it already increases adjustment speed by 4X or more.
The step-down, if implemented, isn’t timed. It’s still temperature-based, but would have a big response and would be easy to activate. A hair trigger, so to speak. Step-down would probably go smoothly over a period of 4 or 8 seconds. Afterward, the regular PID method would take over.
A true MCPCB-mounted sensor would be nice, but is probably not feasible on this light.
Tom Tom
I don’t think TK is using anything like PID, that would be just stupid in a dynamic thing like this that doesn’t work like classroom theory.
It’s not an easy thing to control, and the hardware is fixed, this has to be delivered sooner rather than later, otherwise why even bother ?
Pragmatic solutions are required, whilst we know-it-alls chatter amongst ourselves.
ToyKeeper
ToyKeeper's picture
contactcr was nice enough to test the most recent build, the faster-but-still-regulated-during-FET “option A” on an Emisar D4. This was the result:
The level it regulated to may be a bit low, looks like about 300 lm or so, but it was also told to use a pretty low thermal ceiling. And it was probably not being held in a hand, so it wouldn’t have had as much heat sinking as it would during normal use.
Other than that though, I think this result looks pretty good. It adjusted fairly quickly to a stable level, didn’t overshoot, and didn’t bounce around.
bushmaster
bushmaster's picture
Last seen: 1 min 8 sec ago
Is building a light always like this? Will it ever be built? I had such high hopes too.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
ToyKeeper
ToyKeeper's picture
People often keep the development process behind closed doors, so it looks like things just pop out of Zeus’s forehead fully formed.
But yeah, development is usually somewhat messy. The difference here is that the process is more transparent. And this project has been particularly slow due to a variety of setbacks.
sbslider
sbslider's picture
Last seen: 3 days 16 hours ago
Ah, if people only knew what it takes to bring a product to market, or to a specific customer. Had to smile of a light popping out of Zeus’s forehead. I can hardly wait to read the discussion about what battery should have been used. . . .
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
ToyKeeper
ToyKeeper's picture
Sorry, didn’t mean to show my age. Old habits die hard.
Penguin
Penguin's picture
Last seen: 2 years 3 months ago
In for 2
Thanks!
ToyKeeper
ToyKeeper's picture
I did some testing on FW3A proto2 running at full power with a fresh 30Q cell, with the thermal ceiling set to 45 C. It was laying sideways on a table with a fan pointed at it. Here was its regulation pattern:
The main difference between options is whether that initial plateau exists. The light gets a bit hot to hold during that.
Although not shown here, beyond the right edge of this graph I put a few drops of water on the light, and it started getting brighter. Then I touched it with ice and it got brighter faster. So… it does step back up when the temperature drops; it’s just not shown on the graph.
Kindle
Kindle's picture
Last seen: 5 hours 59 min ago
fritz15 wrote:
Does this body of evidence also have a source other than your subjective perception of today’s music? Would be interesting to read up. Thumbs Up
The Musical Diversity of Pop Songs
Are Pop Lyrics Getting More Repetitive
Vickers, E., (2010)
The Loudness War: Background, Speculation and Recommendations
AES 129th Convention, San Francisco, CA, USA 2010 Nov 4-7 (Conference Proceedings – non periodical)
https://www.sfxmachine.com/docs/loudnesswar/loudness_war.pdf
Serrà, J., Corral, Á., Boguñá, M., Haro, M., & Arcos, J.L. (2012).
Measuring the Evolution of Contemporary Western Popular Music.
Scientfic Reports, 2, Article 521.
https://www.nature.com/articles/srep00521
Percino, G., Klimek, P., Thurner, S., (2014)
Instrumental Complexity of Music Genres and Why Simplicity Sells
PLoS ONE 9(12): e115255
http://journals.plos.org/plosone/article?id=10.1371/journal.pone.0115255
Mauch, M., MacCallum R.M., Levy, M., Leroi, A.M. (2015).
The evolution of popular music: USA 1960-2010
Royal Society Open Science, DOI: 10.1098/rsos.150081.
http://rsos.royalsocietypublishing.org/content/2/5/150081
Askin, N., Mauskapf, M. (2017)
What Makes Popular Culture Popular? Product Features and Optimal Differentiation in Music.
American Sociological Review, Vol: 82 issue: 5, page(s): 910-944.
http://journals.sagepub.com/doi/abs/10.1177/0003122417728662
I think the important thing is to remember these studies focus on ‘popular’ music ie what is marketable to the lowest common denominator in order to maximize sales.
I would always squeal with glee whenever another engineer would demolish the cherished subjective world view of the audiophile cognoscenti. Bob Carver remains a hero of mine.
ToyKeeper
ToyKeeper's picture
That seems roughly equivalent to what Okcupid found when looking at people who try to make their profile appeal to a general audience instead of showing the things which make them unique. They end up with a lot of 3-star and 4-star ratings but virtually no 5-star ratings.
Whatever the 10% is which counts as “not crud”, I think at least most people can agree that pop music isn’t it. Being too generic makes it bland and mediocre.
Kindle
Kindle's picture
As someone who grew up in the singer-songwriter era, it is especially shocking to me that the majority of popular songs over the past decade + have essentially come from two writers; Max Martin & Lukasz Gottwald (Dr Luke). There have always been prolific writers who sold songs to other artists, but I don’t think there has ever been an era when virtually all the top acts are little more than pretty facades.
Sigh…I’m going to go listen to some Alabama Shakes now to remind myself there are still amazing & unique talents out there.
waxing twilight
waxing twilight's picture
Last seen: 1 month 1 week ago
Wow, I’m late on this one. I guess I have a lot of reading to do to catch up, but in the meantime, I’m in for one! This project sounds pretty hot, lol. Facepalm Love
spaceminions
Last seen: 1 year 1 week ago
I sometimes put a light in a cool glass of water, where the cooling is usually sufficient to enable quite a lot higher output. I want the 1100>turbo range to have some sort of regulation in it, so that I can place the light in the water when it’s been running at the thermal limit and have it step up to the new equilibrium.
I’ll throw my voice in as someone who has a D4 and wants option A. I think the times I would use FET instead of the 7135 mode would be A) When I only want to use turbo for as long as possible before regulating down to whatever I can get and B) When I have enough cooling whether because it’s cold or wet enough to sustain more heat than the 7135 mode produces. Or if for whatever other reason it had more cooling than otherwise, or if I was less bothered by the heat or something.
Card Carrying CRI baby https://b.thumbs.redditmedia.com/laMC7BGhREfYTRQjYe2I5FMjTF1IjrmM6bPLK9SKEXU.png
Tom Tom
This is the conundrum, fitting 3/4 of a Q8 into an S2 sized package.
“Ye cannae change the laws of physics”.
“I’ve got to have 30 minutes” …
Perhaps filling the head with a phase change material could keep it going on turbo for more than a minute before step down. Much much better than simply relying on thermal mass.
Quick estimate: Paraffin wax, heat of fusion 250 kJ/kg.
https://en.wikipedia.org/wiki/Phase-change_material
Find a way to fit say 25g, that could soak up 6.25 kJ, lets say on turbo its pulling 4A from 3.7V = 14.8 W ignoring the light coming out of the front.
So the wax could maintain the head at a safe level for 422 seconds = 7 minutes of full turbo before step down became necessary. Of course there would then have to be a lengthy cooling off period before giving it another full blast. Meanwhile it would make a nice handwarmer on cold days.
Another wacky idea: monitor the LED forward voltage shift with temperature to get a precise reading of the LED junction temperature rise. Saves the need for an MCPCB sensor and measures it where it really matters. Use high melting point solder too, in case of accidents.
https://www.rohm.com/electronics-basics/leds/led-characteristics
PS: if there are going to be FW3Ti and FW3Cu in future, the thermal control may need some re-tuning to cope with the very different thermal properties in case A (particularly for Ti), hopefully the “universal” system will adapt when in 7135 mode.
PPS: I think there is still a place for “hotwires” in bright torches, at least the incandescent bulb chucks it’s waste heat out of the front instead of into an MCPCB, and of course the CRI is perfect Wink Make a handy fire-starter in emergencies too.
stephenk
stephenk's picture
Last seen: 7 hours 17 min ago
Another vote for option B – safest option!
JaredM
JaredM's picture
Last seen: 1 hour 4 min ago
TK
First off – thank you!
I’ll say I haven’t followed every minute of this behemoth thread, so pardon if this has already been discussed extensively..
My first thought is if we want the PID to function perfectly and be the sole method (over months and years of operation and thousands of samples!) keeping this thing from going to skin blistering temperatures is to have a dedicated thermal sensor as close to the (primary) heat source as possible. It’s very common practice now for bigger name manufacturers to have an NTC thermistor on the MCPCB. Measuring this far upstream will make it possible to get AHEAD of the temp control, and not require so much host calibration or predictive/preemptive throttling. One major concern I have with using the current temp sensor location, besides the obvious and previously stated shortcomings, is the driver retaining ring possibly coming loose on the F3WA. Most of you with a convoy tube light with right-hand-threaded tailswitch retaining rings has come across it loose over repeated use and battery changes. This could cause a serious change in thermal resistance in the sense circuit and potentially lead to extreme over temperature conditions. Small chance maybe, but one that’s avoidable IMO.
That said, if this can’t be done at this point in the project, then I really hope the safest and most reliable options are employed to limit the >1000 lumen modes. If timed step-down from turbo to high is necessary, that’s fine! Everyday carry is exactly what a light like this exists for, and no reasonable person would prefer burnt clothing and/or skin over an extra click to keep it in turbo if necessary.
cabfrank
Last seen: 3 min 49 sec ago
Just for perspective, I remember the Eagle Eye X6 group buy, when we were hoping the light would be able to ACHIEVE 1000 lumens.
ToyKeeper
ToyKeeper's picture
A MCPCB-mounted sensor would be awesome, but won’t be feasible on this light. Maybe in a later version, with a redesigned driver.
So for now the MCU is stuck making predictions based on a laggy and noisy built-in sensor.
Despite that though, the normal regulation works pretty well… except for the specific case of turbo, which it allows to run long enough to make the light uncomfortable to hold. But perhaps that could be avoided by adding a drop of thermal goo in production. That just makes the driver really hard to reflash. I hope future drivers will have programming pin access on the battery side of the driver, though the FW3A may not have room for that kind of thing.
The retaining ring doesn’t actually touch the body tube, so it’s far less likely to get loose over time. In the prototypes it does sometimes touch the inner tube though, which is a main factor holding up the project. Can’t go to production until that’s solved, because spurious button presses are bad. It’s easily fixed with a short strip of kapton tape around the end of the inner tube, but a better solution is needed.
spaceminions
Given how hot most of the electronics can run safely versus the low temperatures we’re expecting of them, and the fact that burns to clothing and such from lights like the d4 and this come from the intense light and not the body of the light itself, I don’t think that the non-muggle mode should be quite so cautious that being even a degree over the setpoint for a few moments would prompt a stepdown. I think it should just be allowed to get a bit uncomfortable for a few moments to allow you to see whatever it was you activated turbo to see, then let the thermal control figure itself out and lower it down into the sweetspot of the regulation range. And of course the potential of operating it in a cold or wet environment where the full turbo heat would be easily dissipated is a big point – if I used this as a handwarmer or in water to keep it cool.
JaredM
JaredM's picture
Understood. But for future compatibility of parts, is it possible to at least get a placeholder solder pads on the MCPCB?
I believe others have mentioned this already, but there are silicone thermal materials that’d be ideal for this application. I’m sure you are familiar with the ~1mm thick “ gum tape” used often on laptop processors and such. This wouldn’t adversely effect modding/servicing friendliness
Could you explain the tube/retaining ring issue in more detail? I’d love to help with any mechanical design/packaging issues. And if I weren’t any help, I’m sure someone else might have an idea. Fresh eyes work wonders sometimes
Tom Tom
In full turbo, and when approaching it, as the FET PWM ratio increases the 7135s contribute less and less to the current flow, so less heat is generated on the driver/MCU temp. sensor hence the increased lag.
A quick and dirty way to fix this might be to mount a power resistor as close as possible to the MCU, connected to the LED drive output. This way the parasitic loss in this heater resistor would provide the quick response needed for PID type strategies, compensating for the lower contribution from the 7135s.
If the driver was arranged so the resistor was only powered by the FET, not the 7135s, there would be no parasitic loss in 7135 modes, but that might require a second small FET just to drive it.
Edit:, or use a gate-able constant current source, shorted to ground, as the heater, rather than resistor+FET.
Otherwise the classic method is to use feed forward in addition to PID, but this requires a pretty good model of the overall behaviour and is not for the faint hearted.
Since we are not trying to thermally control it, simply to turn it down just before it overheats, I reckon some straightforward mapping of the behaviour could work.
Mapping could be attempted by taking a series of step response measurements using a thermocouple on the head and timing the duration from start temperature to critical temperature. Maybe map 8 or 16 different power levels, from full 7135 to full FET. These could then be used, factored by the head temperature measured at the MCU, to determine a step-down time for each power setting, the step down being either smoothed out, or left to step to give visual indication of what’s happening.
Once back down to full 7135 the universal algorithm taking over again.
PS: some more detail on how to use the LED Vf as it’s own temperature sensor:
http://www.electronicdesign.com/lighting/use-forward-voltage-drop-measur...
PPS: You already have a constant current source on the driver (x1 7135) so if you could arrange a second set of wires to the LED (4 wire probe) feeding an ADC input to the MCU, you could do it, with just the tiniest flicker when taking the measurement. Guessing at 2mV/degreeC slope, you’d be looking to resolve say 200 mV over the range 0-100C, on the say 3V Vf, which sounds do-able.
