D.I.Y. Illuminated Tailcap - gChart Editions
153 posts / 0 new
gchart
gchart's picture
Last seen: 31 min 47 sec ago
I’ve had a bit of fun creating some new Illuminated Tailcap designs and I thought I’d share them with ya’ll. Thanks to PilotDog68 for sharing files with me which served as a nice springboard. My main goals for these are to:
  • Learn and share my experiences
  • Address some accidental bridging (from too-close traces) I’ve experienced in the past
  • Where possible, make things single sided so that everything can be reflowed (on a hot plate)
  • Try new things and have fun!
Booster Tail v1.5
Created for dual-voltage flashlights, especially for those using AA / 14500 such as the Sofirn SF14 or Lumintop Tool AA (both tested). This uses a TPS610995 (DRV / WSON package) step-up voltage regulator to regulate from 0.7V – 5.5V in to 3.6V out. There are two separate channels with two LEDs each. It also has a “bridge” pad to convert it to a single-channel output. BOM. Oshpark
Big Switch 19mm
This is made for the larger forward-clicky switches like those in the Brinyte B158 or Convoy L2. This is a single-sided version with 3 LEDs each with their own balance resistor. All components are 0805 size for easier assembling. Oshpark
Single Sided 16mm 4 LED
This is a “normal” style tailcap in 16mm, but with everything on one side so that is can be reflowed all together. All components are 0805. Oshpark
Single Sided 16mm 6 LED 0603/0402
Like the 4 LED version, I wanted something single-sided for easy reflowing, but thought I’d try squeezing 6 LEDs and keep them tight to the switch. In order to make everything fit, I used 0603 LEDs and 0402 resistors. Oshpark
Single Sided 16mm 6 LED 0805
Like the 4 LED version, I wanted something single-sided for easy reflowing, but the components have been rotated to fit the 0805 pads all on one side. The smaller 14mm tailcaps may not fit over the components properly – not yet tested. Oshpark
Low-Voltage Protection, Constant Current 16mm
This board uses a Voltage Reset Monitor to provide LVP and an LDO to provide a constant voltage (an in effect, constant current). Everything is on a single side for quick & easy reflow soldering. BOM. Oshpark
Low-Voltage Protection, Constant Current 19mm
This is the same as the 16mm board, just with a larger diameter and hole for larger switches. BOM. Oshpark
Edited by: gchart on 10/16/2018 - 11:53
gchart
gchart's picture
Booster Tail v1.0
The TPS61221 step-up voltage regulator in this project seems to do a good job of efficiently managing a wide range of input voltages.
For the first test, I used green LEDs on both channels, each with a 24K Ohm resistor. Some measurements:
  • Eneloop: (I forgot to measure the battery voltage, assuming 1.2V), the tailcap drew 0.34 mA from the battery. The boost circuit produced 3.294V and the LEDs dropped 2.14V. That figures out to be around 0.10 mA going through the LEDs.
  • Li-Ion: battery was at 4.070V, the tailcap drew 0.11 mA from the battery. The boost circuit produced 3.587V and the LEDs dropped 2.14V. That figures out to be around 0.12 mA going through the LEDs.
  • While not perfectly the same, the consumption from NiMH and Li-Ion are very close (0.10 mA vs 0.12 mA, respectively). Given the differences in input, I consider this a win.
  • Boost circuit efficiency on NiMH: (3.294 V * 0.10 mA) / (1.2 V * 0.34 mA) = 80.7% efficient
  • Boost circuit efficiency on Li-Ion: (3.587 V * 0.12 mA) / (4.070 V * 0.11 mA) = 96.1% efficient
  • Runtime on a 2550 mAh NiMH: 2550 / 0.34 / 24 / 30 = 10.4 months
  • Runtime on a 900 mAh Li-Ion: 900 / 0.11 / 24 / 30 = 11.4 months
Booster Tail on an Eneloop
Booster Tail on a Li-Ion
Assembled Booster Tails, v1.0 on the left and v1.2 on the right
Bill of Materials (per tailcap)
  • Step-Up Regulator: TPS61221 ($1.12), 1 required
  • Inductor: LQM18FN4R7M00D ($0.13), 1 required
  • Capacitors: CL10A106MP8NNNC ($0.14), 2 required
  • Total per board: $1.53 (excluding PCB, LEDs, and balancing resistors)
PS – I did have some fitment issues when trying to put this in my SF14, it needed filed down quite a bit to fit. An updated version will be created shortly.
DavidEF
DavidEF's picture
Last seen: 5 days 14 hours ago
Cool! It’s fun to do stuff like this for the learning experience. Also, it’s always good to have more options available. Wink
- The YKK Philosophy
emarkd
emarkd's picture
Last seen: 3 weeks 1 day ago
This is cool, very well done. I also really enjoy building and playing with these lighted tailcaps and your options are a very welcome addition. I’ve gotten pretty quick at hot-surface-reflowing the 6 LEDs on one side, then flipping it over and mounting the resistors underneath using hot air, but your solution would be even faster. That’s nice! I’ve never had a need for a boost tail in any of my builds..yet, but I’m glad to know this is out there if the need arises. Thank you.
DavidEF
DavidEF's picture
I don’t think anybody needs a booster tail unless they want to put tail-cap LEDs in a low-voltage (boosted) flashlight. I think for most of us, the thought of running LEDs in the tail-cap of a 1xAA powered light just never occurred to us. IIRC, there were a couple of people who mentioned wanting/needing something like this in the other lighted tail-cap thread(s). Now, it is a reality!
ImA4Wheelr
Last seen: 2 weeks 5 days ago
Nice creations gchart.  I look forward to lighting some of my favorite NiMh lights.  Need to take some measurements and then place an order with Oshpark.  Thank you Smile
gchart
gchart's picture
Thanks! I just added the BOM to the second post. If you want, check a few dimensions of your lights to see what size of board will fit. I had to file mine down to around 15.5mm to fit in the SF14. I have a Tool AA on order, I dunno what size board that is. I’ll redo the Booster Tail board, but I’d like to make it a “one size fits most” if possible.
DavidEF
DavidEF's picture
gchart, I think making the bigger size board is better, since it is easier to sand down a board that is too large than to add more to one that is too small. Also, OSH Park requires a “trim” around the edge of the board, where no copper is allowed. Making the board larger and sanding it down allows you to have copper all the way to the edge when installed in a light. Maybe not important for a tail-cap spring board, but more so if you ever make drivers that need electrical and thermal conductivity to the host.
djozz
djozz's picture
Last seen: 46 min 50 sec ago
Very nice boards, I have been hoping for a booster board at some point because I’m not able to figure it out myself. What are the cap-values in booster tail v1.0, and what is component L ? never mind, should have read post #2
Btw, the tail ring in the Tool AA is 15.9 mm.
gchart
gchart's picture
Thanks for the measurement, djozz!
Post #2 has the component details at the bottom including links to them at Arrow. L is an inductor (chip style), 4.6 uH size 0603. The caps are both 10 uF size 0603.
Another thing that should be obvious but not stated or tested: the booster board should also work great for 2xAA lights. Anywhere between 0.7 and 5.5 volts should work.
ImA4Wheelr
Screw measuring lights.  Of course the board will fill (or can be made to fit) most of my lights.  So for starters, I ordered 3 v1.0 boost boards and some of another one of your other boards.  The parts from Arrow were free overnight FedEx shipping!   Yahoo!
gchart
gchart's picture
Yeah, I’ve been loving Arrow’s free shipping. Maybe a bit too much Big Smile
MRsDNF
MRsDNF's picture
Last seen: 1 hour 12 min ago
Nice. Smile
Nicolicous
Nicolicous's picture
Last seen: 5 hours 44 min ago
Wow good job with booster tail light.
Been hunting for them along time Smile
Nico -.-
gchart
gchart's picture
Facepalm Time to hit PAUSE on any excitement with the Booster Tail. I’ve discovered a bug that I need to wrap my head around and I think I’m out of brainpower for the night.
As it turns out, enough juice can flow through the boost circuit to maintain a low mode instead of switching the flashlight completely off. They’ll cycle through upper modes just fine and will turn off from an upper mode. Just not from a low mode – the flashlight will stay on (albeit rather dimly).
Perhaps a different bleeder will work. I tried a 680 Ohm; I might need to try lower. If that doesn’t do that trick, maybe I need to introduce some resistance in front of the voltage regulator. This stuff is on the outskirts of my knowledge. I need to read up on some of this and do a bit more testing. Apologies for the premature announcement. Sad
ImA4Wheelr
No need to apologize gchart.  This is one of the beautiful aspects of BLF.  You have plowed a new path and now we get to try to help work out the bugs that generally occur when something new is created.  BLF collaborating, a beautiful interactive process.
DavidEF
DavidEF's picture
This is the way I see it too. I personally don’t have enough knowledge to be any help with this. But surely there is somebody here that can help with this bug. I still appreciate you creating this project and sharing it with us, even though it isn’t perfect yet. Crown
ImA4Wheelr
I too lack the knowledge to provide a full solution.  I will throw out an idea out though.
Apparently, the circuit is allowing current to flow backwards though itself.  It may be that a diode is needed in series with the circuit.  Unfortunately, I don't know what diodes would be good candidates and how much additional current they will pull when the light is off (and the tail light is on).
But I get a head of myself.  Gchart, do you have a circuit diagram available that we could look at?
gchart
gchart's picture
I just sketched out an overly simplified circuit diagram a minute ago, but it’s just pen on some rough paper. I can digitize it and upload if desired. At this point, I want to check out lower-resistance bleeders (say 470 instead of 680 Ohm) before assuming the tailcap needs modified. I had given thought to a diode, but after looking at my sketch, I don’t feel that that’s the answer.
Here’s the boost circuit diagram per the TPS61221 datasheet. Vin and Gnd are routed to the switch board, Vout is routed to the LEDs with a series resistor.
click for larger image
ImA4Wheelr
Worth a shot, but it seems the problem is power flowing into the driver via the normal route (i.e. Positive from terminal of cell, and Negative from battery tube (via the taillight boost circuit).  The bleeder resistor will control current flowing from the positive terminal to the to the battery tube.  It would be a kind of slow short circuit and not impact flow from the tailcap.  It seems the problem is not the amount of positive power going to the tail pcb via the tube, but negative power feeding backwards through the tail circuit to the tube (and on to the driver).
Looking at the diagram, the booster chip bypasses the LED (the led being a diode itself will not allow reverse current).  So a diode may be needed either after VIN or before the ground connection to the chip.  Looking at the top side of your board, it appears there may be enough room to cut either the positive or negative trace and insert a diode.  Questions is, what diode would be a good candidate.  Also, will the voltage consumption via said diode be enough to make the circuit not work when a cell drains to a certain voltage.  That might actually be good as a low voltage indicator.
I would be very happy to do some surgery and try when my boards arrive, but I would need some guidance on what diode to try.
gchart
gchart's picture
Sounds logical enough! I should be able to scavenge a diode from a “for parts” driver and cut that into the Vin connection. It may not be a perfect match, but I would think good enough for testing. Hopefully I’ll have some time to try that tonight.
Lexel
Lexel's picture
Last seen: 43 min 30 sec ago
looks like you are using Eagle for design, if not Diptrace i cant help you giving a basic design with the diodes arranged
17/20mm board with LVP based on loneoceans design but with more stuff going on
0603 LED and 0603 resistor barely fits the central ring with custom pads for reflow only
for people who are afrid of dual layer reflows that red glue that gets hard above 85°C helps a lot, but its no problem to put the LED board on a post or clamp and apply 2. side solder paste with a tip and parts stick to the paste on both sides usualy fine if not too heavy
gchart
gchart's picture
Thanks for the tips, Lexel. I have been using Eagle. I hadn’t heard of DipTrace – I see they have a 300 pin freeware version; is that what you do?
While you’re here, any thoughts on the strange behavior I was experiencing yesterday? I’m hopeful the diode will do the trick, but I’m open to ideas!
gchart
gchart's picture
Update: I tried adding a diode (1N5819) at Vin, but I think we went backwards in functionality. Seems to be no change on Li-Ion, and now the tailcap doesn’t illuminate on NiMH.
Lexel
Lexel's picture
maybe by using a small transistor instead a diode, so you got reverse blocking but a very low voltage drop
gchart
gchart's picture
New theory… Is it possible that the capacitors are feeding the main driver instead of the tailcap (when the load from the driver is low)? Perhaps I need to put diodes between the capacitors and ground?
Edit: nope! I tried just removing both capacitors. I still get the same behavior on Li-Ion. On NiMH, the tailcap fails to light up at all, and the light strobes when the switch is off. So it seems like there’s voltage leakage (?) through the TPS61221 to ground. Would a diode at the ground pin address that?
ImA4Wheelr
Thank you for sharing your results.  I wish I could be more helpful.  I would be experimenting just like you are if I was in your shoes.  When I looked at the datasheet for the TPS61221, I saw no mention of built in reverse polarity protection.  So I'm assuming the chip is allowing current to flow through it backwards.  Lexel's idea about a small transistor sounds great.  Maybe google what they look like and see if you have any old stuff you can harvest one from.
Schoki
Schoki's picture
Last seen: 2 weeks 4 days ago
Could you describe the strange behaviour of the main LED and the tail LEDs on clicks a bit more precise?
gchart
gchart's picture
Schoki, if a picture is worth 1000 words, what’s a video worth?
This is where a feel a bit helpless. I understand a few core principles, but that’s about it. The extent of my electronics education is what I got from a breadboard kit when I was 10 or so. I appreciate any help you can provide!
Another theory I had today… in a “normal” illuminated tailcap, there’s voltage drop in the loop due to the tailcap LEDs. But in my boost circuit the VIN to GND path likely doesn’t have much drop – is that providing a suitable path for driving the main LED since there is negligible voltage drop?
gchart
gchart's picture
On a lighter note, I put one of my Big Switch boards into a Convoy L2 tonight. Having the bottom of the board bare made the installation a breeze; no hacking away at things to make clearance for the resistors on the bottom of the board.
Red, White, & Blue – Happy Independence Day, America!
moderator007
moderator007's picture
Last seen: 56 min 19 sec ago
I’m wondering if you have tried changing the bleed and led resistors. I had a light that had the same behavior until I tried change the resistors to get a value that worked. The led’s in the tail look very bright to me, but I like mine very low anyway so they don’t light the bedroom up at night.
I usually set mine around 50 to 82k, probably a little low for some. You might try changing resistors.
I do understand your using a boost ic, don’t know if this will help or not just a thought.
