How is pricing for new version? As opposed to upgrading? If price is good then better off buying new version to have BOTH thrower and spotter versions.
blinker:Do you think there is a way to get more throw?
Sure, slice the dome.
Dome on you get about a 45% reduction in throw (2200m to 1200m)
Sliced dome you get about a 27% reduction in throw (2200m to 1600m)
This is based on Texas_Ace’s GT. You lose about 15% lumens by slicing the dome, which isn’t too bad.Hopefully I remembered all these numbers correctly.
Okay, if a dome (I assume it comes with a dome) reduces it by 45% and no dome reduces it by 27% how do you get 0% reduction?
JasonWW: blinker:Do you think there is a way to get more throw?
You only get 0% reduction by using a led that has a die with the same luminus intensity as the XHP35 Hi. These leds exist (XP-L Hi, dedomed XP-G2, and Oslon Black Flat have even higher luminus intensity and should throw further) but have usually smaller dies so you loose output instead of gaining it. There is currently one led that gives the same throw combined with higher output, the Luminus CFT90, but it is not very efficient, it is a 3V led so it needs a new driver, it needs some modding get it fit and centered, and perhaps most significant it is a really expensive led, like over 100 dollar.
Let me correct the throw distance I used before. I thought it was 2200m, but it looks like it’s 2000m. So going from xhp35-HI to a hard driven stock 70.2 is a 40% throw reduction. The sliced dome has a 20% throw reduction.
Anyway, a larger diameter emitter is almost always going to decrease throw because it’s hot spot is larger. The xhp35-HI emitter die is about 5.5 square millimeters. The xhp70.2 die (dome on) appears to be about 22 square millimeters due to the roughly 40% magnification effect of the dome. (I think it’s 40% to 50%). Anyway, that’s a huge increase in emitter size.
Slicing the dome off makes the die about 15.7 square millimeters. That’s still 3 times bigger than the xhp35-HI.
On the other hand, a larger emitter can usually be brighter which then gives you back a lot of the throw distance you lost.
With the sliced dome 70.2 emitter doing 6,000 lumen instead of 2,000 lumen, the net result is a small 20% loss in throw.
You could go with a smaller emitter to get more throw than stock, but it’s a pretty small hotspot and was voted down during the GT design phase.
If you want more than 2000m throw along with a bigger and brighter hotspot, the CFT90 is the hot ticket. When pushed really hard, it can give about 2450m throw and 4500 to 5000 lumen (according to Skylumen). So the hotspot is a little bigger, it’s much brighter and the throw is increased. Sounds great! What’s the catch? They cost about $675.
The bottom line is a lot of folks don’t really need to see 2000 meters (1.2 miles). You can make the GT more practical with a 70.2. It doesn’t cost much more and it can still throw a long way, plus you get a much bigger hotspot to better see what your looking at.
BTW, all xhp50, 50.2, xhp70, 70.2 emitters have domes.
With the dome on you get about a –45- 40 reduction in throw (2200m2000 to 1200m)
With a sliced dome you get about a –27- 20 reduction in throw (2200m2000 to 1600m)
Keep in mind that VOB’s numbers were a fair amount higher then mine. He was using a P2 bin emitter vs my 4000k 80cri. So it is possible we are both correct. Since he has before/after numbers it is hard to argue the relative performance gains of his numbers.
blinker: JasonWW: blinker:Do you think there is a way to get more throw?
So what would be price range of group buy as opposed to original group buy price? Reason is if more cost effective to MOD or buy newer version?
JasonWW: blinker: JasonWW: blinker:Do you think there is a way to get more throw?
N.B. What counts for max throw is for the emitter to have max lumens per mm^2.
finally i can open my blf gt head, and damn that was a tough bastard to open :smiling_imp:
will contact neal for replacement
Let me know if you are not on this list and still have an issue.
If your issue has been resolved, let me know and I’ll remove you from the list.
See post #1 for the Issues List.
This might be the new contact email for GT issues.
Marketing.Lumintop@gmail.com
Bags and caps are still handled through Neal.
I added you to my list. Also make sure to contact Lumintop using the email under the list since I think they are now handling these issues.
zelee:finally i can open my blf gt head, and damn that was a tough bastard to open :smiling_imp:
will contact neal for replacementI added you to my list. Also make sure to contact Lumintop using the email under the list since I think they are now handling these issues.
thanks for the info
I updated post #1 with some news about contacting Lumintop if you have issues. The email address is still not confirmed.
I also put this new public “Unresolved GT Issues” list on page one and moved some old shipping details to a different post.
Texas_Ace, have you heard any details such as color and bin on the new CW emitter Lumintop is using in the GT?
I ordered 8 x35E’s before I ordered my gt , I havnt got them yet & I didn’t use the contact form because I bought them separate (on neals deals) , I’m using 30Q’s now so I’ll probly just ask for a refund , but I’ll be happy to get the batteries instead of a refund , I’ll see what Neal says.
I have not heard much besides I think they are the same D4 bin. They sprung the CW option on me and I never tested them or really got any details.
I’d be a n for an upgrade kit too.
Me too !
Tejasandre:I’d be a n for an upgrade kit too.
Me too !
+1 for me too
Did Texas_Ace not post a link to his new thread here?
The BLF GT70 "Giggle Monster" is coming! 7,500lumens, 1,500m throw!
Complete lights as well as upgrade kits. Check it out.
The BLF GT70 “Giggle Monster” is coming! 7,500lumens, 1,500m throw!
If he did, I missed it. Thanks for posting it Jason…… :+1:
Yep, I was so busy trying to get the thread started and then make sure that the sign up forms were working I didn’t post anything else about it.
Looks like my goody bag is in Chicago.
