I am compelled to point out that the prospects for this light actually producing 25,000 lumens are tiny. A number of MT09R’s were sold without drivers in the US. Texas_Ace designed a driver, and he added the driver to these lights for customers of the lights sold without drivers, and sold a license to use that driver to Haikelite for use in the MT09R. Texas_Ace offered a number of upgrades in addition to the driver to raise the output. I believe the highest output Texas_Ace was able to achieve was about 23,000 lumens from some units. However in order to achieve that, the LED’s were upgraded, and there were a number of internal modifications made to the light to reduce internal voltage losses (such as battery spring bypasses). Those internal modifications are impractical for a mass produced light, so they are unlikely to be on the factory produced MT09R lights. Absent the upgraded LED and those internal ‘tweaks’, I would be very surprised if the output exceeds 20,000 lumens. 20,000 lumens is a big number, no argument, but it definitely isn’t the 25,000 lumens claimed. If the units Texas_Ace hand built couldn’t reach 25,000 lumens, the mass produced version won’t reach it either.
Thanks for pointing out. Haikelite used to over spec some of their lights, this is their normal practice. I think they use the LED lumens instead of OTF lumens.
I have a MT03 II that is rated 12000 lumens and it gets really hot in 1 minute or two. Its thermal regulation seems to be not working.
I am sure this MT09R 25000 or 20000 lumens heat up much faster.
I think I don’t mind it doesn’t hit 25000 lumens as long as it is over 20000 lumens and throw much further than MT03.
The Texas_Ace driver used in the MT09R can put out 260 watts, so it is a pretty safe bet it gets very warm very quickly at full output.
It’s obviously not 25 000 lumens.
Even if you were to use top bin P2 XHP70.2s and spring bypasses all over the place, there is no chance it will get 25k lumens in a flashlight.
21000 lumen or 20,000 lumen for sure.
interested XHP70.2
Interested XHP70.2
3x XHP70.2 interesting
What’s the potential candela number?
100k+ for the XHP70.2, and 250k+ for the XHP35HI.
Translating to 600m+ for the XHP70.2 version, and 1000m+ for the XHP35HI version.
Thanks. I think 100kcd is good enough, if it can last 18000+lumens for 2minutes then it will be perfect. Price wise not sure yet as it’s quite close to DX80 if we include batteries costs and number of XHP70.2.
Interested in XHP70.2 version!
Interested but up to price
interested in xhp70 version
Interested thanks…
What is the difference between this MT09R GB vs previous MT09R GB?
The driver.
It now uses the Texas Ace FET+resistor array driver.
Thank you.
Several things…most of which is that the lights from the previous batch were “not up to snuff” to put it nicely. Many weeks of Texas Ace making lemonade out of lemons and modding these lights to work even better than they should have in the first place. Now this batch is claiming to use Texas Ace’s mods and driver design in this version of the lights.
Best part of last group buy…I got a blue and green light, both very nice colors…not to mention Texas Ace personally modifying both of my “not so good” stock lights into brilliant blasters.
The second batch/group buy may only offer black and white.
Also there was a different person running the first group buy than is running this one.
I suspect you will pay quite a bit less in time, trouble and money if you buy this light at GB prices (and assuming its as awesome as the modded ones), than many of us did to have ours tinkered with and upgraded.
Was blasting both of them around the neighborhood a few nights ago and people thought aliens were landing…these lights are so bright they actually CAUSE problems, not solve them…LOL!
Have fun and good luck!
