Other than battery holder, any option for accessories like shoulder strap(must have for such big light), short tube? No need for separate order.
In for 2, NW if possible. Love my original GT & very interested in the XHP 70.2 version. My previous older “throwy” lights (several models of the Jetbeam BC40, which goes about 350 meters) look insignificant compared to the XHP 35 GT!
If it was a neutral white with little tint, I would change my CW to NW in the form. For comparison, my Q8 color is just perfect for me, whatever it is rated at.
PM checked & replied to…… :+1:
It took longer to type than it does to do……
Signed up.
1 conversion kit
One GT70 and lens please.
Signed up for:
1 BLF GT 70 NW
8 Samsung 30Q Batteries
In for one
Signed up for
1 giggle monster
1 conversion kit
2 battery carriers
maybe 1 reflector?
maybe 1 lens
maybe 8 cells
teacher:TA…… a question whenever you have time. No rush… Is the Neutral White option going to actually be that, as close as possible to Truly “Neutral White”…. without the yellow/orange tint?? Neutral White with little or no tint warm or cool. :+1: But better a lean to slight cool than yellow…. if it must lean.
Yeah…. I feel the same way depending somewhat on what the CW ends up being.
To me for the most part anything below 5000K is going into Warm White.
I consider 5000K to 5700K true NW.
But to each their own….
IIRC the Q8 was 5000K. It is nice. A bit cooler would have been just as nice too.
No puke yellow/orange on the warm end & no harsh blue on the cool end for me.
True Neutral White & lean to the cool side if it must works for me in any light.
In for
1 conversion kit
1 battery carrier
I raised my spending limit to $250. I’m hoping it will be less.
‘Theodore’ would be proud my friend….
Hope you had a good 4th!!!
can you get Lumintop to dome slice the xhp70 perfectly?
This has been discussed, they are going to test a few first to make sure they can do it before offering it as an option. If it is an option then it will be available when you buy the light for an extra fee.
Yes, all of the basic options like short tube will be available at check out and I will be adding some things to the Form once they tell me the prices as well. So hold onto your confirmation emails so you can edit your reservation for the new items!
The Q8 is 3D tint and that is the goal we are hoping for with this light as well.
Filled the form for a conversion kit. Any idea how long can it hold turbo before stepping down? Wonder if it’s possible to use the 35Es that came with my GT
Yes, you can use the 35E’s in this light as well, it will not be as bright as 30Q’s but will work just fine.
Not sure on exact step down time but around 2-3 minutes if I had to guess depending what tempreture you calibrate it to.
It gets warm pretty quick but it also has a lot of mass to absorb the heat.
1 Giggle Monster in NW- (4000K would be awesome)
8X 30Q
I am sure we will surpass 100 people to get the $240 price, we are at 90 lights reserved now. I will try to post the list once we reach 100.
After that it depends how fast word spreads, the price of a short group buy is there is not as much time for people to hear about it.
Interested in Flashlight or Kit.
Separate Driver would be Interesting too.
4000K is the best for me.
Interested in XHP70.2 Head without Reflector, with Tailcap and Battery-Carryer.
I want to make two flashlights from my first XHP35 with both tubes, which I plan to mod to aspheric with Collar.
