Huh? Which (light’s) driver? I like the UT20’s and the v2’s. The v1 had the pause in the middle, but I just stick with stepped modes. I’m not about to hack’n’slash a driver unseen.
If I brick a cheapie 105C/105D driver, I can stick in a new one for 2bux or so, but not a light that has a proprietary driver.
Strangely, that’s one light that I like as-is, both the design and UI. The beam’s a bit fried-eggy, but not too bad. In practice (vs white-wall hunting) it’s not bad at all.
Ohhhh yeah, it comes with a holster… have it, but haven’t used it.
Ugh, I hate high→low modes. Even those lights like the original SP32/31(??) that had the l/m/h/m/l/m/h/… up’n’down steps, I tried getting used to it, but it just drove me buggy. I still need low→high, preferably with shortcuts to high/turbo if possible, so I can reset the light to lowest, and then be able to select lowest with a simple turn-on, else high/turbo with, say, a doubleclick.
I like it quite a bit, enough to get a 2nd one as a backup. My only concern is that it doesn’t get “too hot, too fast”, so it either doesn’t cook (lower max current) or the thermal path isn’t as good as it should be. My Folomov D4 gets hella hot in a very short time (and has high→low modes if yer interested), so I know it wicks away heat from the LED very well.
The feature which endears it to me as an EDC is the forward-clicky tailswitch. Lets me do a quick flash’n’dash when I need to, without annoying full-clicks, and without worrying about mode-changes, or doing the press’n’hold to turn it on and/or off.
So… reflector, charger, battery, tailswitch… yeah, it’s long for a reason. I don’t mind, though.
