Signed up for the conversion kit.
I have another question.
I have my doubts about the XHP70.2 being able to survive for long against a FET driver with 8x18650 behind it. Texas Ace claims the driver can output 250 watts. As per TA’s own measurements, the XHP70.2 outputs 10k lumens at 187 watts, at which point it is already starting to be so overdriven it has started to lose output. That is at a forward voltage of 15.6volts, when a FET driver will push voltage directly from the batteries, at about 16.8 volts on a fresh set of batteries. That means 5.5 amps/battery (190watts, maximum tested by TA, already harmful for the led) or 7.5 amps/battery (250 watts the driver is claimed to be able to sustain). 7.5 amps is not such a high amperage that a set of high discharge batteries, like the 30Q batteries that may be offered for sale bundled with the light, would sag overly from it.
I’m guess you guys have found a solution to this problem, but I wonder what it is.
TA has tested it in reality and it works/survives. He can probably explain why better than I can.
I haven’t gotten all the test numbers from him on amp draws, etc… which is why this info is blank in the Specs area. The amp draw may also vary a bit based on the particular emitter used. This has not been decided on yet.
Maybe he can fill in some of those details later today.
It’s early days yet. This will be answered as soon as it’s known.
Signed up for:
1 x GT70
1 x Conversion kit
Yes, I am working on the short tube being an option, just waiting for confirmation and final price.
The new centering ring that will come with the kit should focus the light, although the xhp70.2 has a lot of adjustment room depending on if you want maximum throw or least dark spot in the middle of the beam.
So it is possible that people may want to refocus it anyways for their own preference but I do not expect lumintop to offer different centering ring options and they have not confirmed with me what focus they are going with.
I have some 3D printed centering rings I could release for people to print out if needed. or I could sell the rings themselves as well worst case.
I do not think spare centering rings will be an option.
It will have a circle in the middle, square centering rings can cause issues like snapping the LED off the mcpcb when tightening the reflector if it grabs for some reason.
It should be 20AWG wires like the normal GT.
The Amps will depend on the exact LED they find, which is why they are not listed yet. In my testing I have seen 9-10A being the normal range with 8 full high drain cells.
It should survive fine, the resistance of the springs in the carriers drops the power so the max current should only be ~10A or so depending on the LED selected. This is quite reasonable and many have driven it this hard or harder. It actually makes peak output at around ~12A so driving it harder could see slightly higher numbers.
The 250 watts is simply what the driver has been tested to with multiple xhp70.2 LED’s connected. In this light with a single LED it is around 130-150w.
As long as the LED’s are properly reflowed to the mcpcb (which they should be) and thermal paste is used between the mcpcb and the shelf, it should not have a problem.
I have run the prototype light on turbo until the cells died and it had no issues even though it got to 91C.
If you are worried you can simply not use turbo and only use the top of the ramp which has a lower max power.
Current should be around 9-10A if I had to guess based on my own and VOB’s P2 bin LED testing.
When are the conversion kits expected?
At the same time as the lights are ready. We have no final timeline at this point although I hope for it to not take longer then 3 months. Ideally they will be ready in 1-2 months but just too early to know right now.
Count me in for the Upgrade Kit. I would love to upgrade my GT to XHP70.2 but I still have to find a way to open it. I tried it a couple of times but all tries were unsuccessful. I even broke the locking mechanismen of my vice by tightening it to hard. But this damn cheap vice just would not stop to rotate while I tried to open the head by turning it with a bicycle tube for grip. However it seems like time for a bigger and better vice :D
Against my better judgement, signed up for 1 NW with batteries and an extra carrier. Put “maybe” for lens & reflector, cause…maybe.
What am I missing with the extra reflector option? I understand how a lens can break or get scuffed but it seems the reflector is pretty specific to this light and not much risk of being damaged… Considering how many people seem to want one I must be missing something though so feel free to point it out to me.
It is basically a chance to get a 120mm reflector for custom builds. Many many people asked for it in the first group buy but since they could not even get enough reflectors for the group buy lights obviously they could not sell them separately.
I promised to try and make the reflectors available later and this is me following through on that promise.
There is really no need for an extra reflector for most people.
What would be cool is if Lumintop could offer a “premium” version of the reflector. Slow cut, hand sanded to a super smooth finish. It adds time and money, but maybe there are buyers?
Until TA and Jason open the BLF machine shop in Houston i guess i wont be needing spares.
I would be in for it. Might as well go all the way for a light like that but I doubt Lumintop would agree to doing it.
Yeah, I don’t see them offering a better reflector, they had enough trouble getting this quality. The reflector itself is actually fine, the only issue is the coating process and it is quite difficult to get reflectors this large coated perfectly. Better sanding would really not help much.
Signed up for 1, NW, 8x30Qs. Hopefully we can get the bag n lens cap offered with it and no extra $20 shipping to Oz!
