Another thought… If I could get the input capacitor to hold it’s charge when the flashlight is turned on, perhaps it could be used to handle the ripple during startup as the flashlight is switched off? If hooked up correctly, placing a transistor between the input cap and VIN could do this, right?
Another theory… some (most?) of these chips will pass current through the chip if the Chip Enable pin hasn’t reached the turn-on voltage (0.5V?). The TPS61221 is this way (“Pass-Through Function during Shutdown”). Perhaps on the flashlight’s low mode, the voltage reaching the PMIC is low enough that it’s not tripping Chip Enable and is instead just passing current through the IC.
Some PMIC’s have a “Load Disconnect” feature that essentially disconnects the IC if the Chip Enable is too low. Maybe that would force the main driver to shut down, giving the tailcap an opportunity to start up? I see TPS61261 has Load Disconnect (also something called “soft start” that may be helpful?), but unfortunately it’s only rated up to 4.0V in.
Edit: I just tested voltage being leaked through the tailcap. It’s 0.40V on NiMH and 0.42 on Li-Ion, just below the Chip Enable requirement. I think I may finally be onto something!
Excellent! :+1:
Ok, potential candidate(s) has been found: the TPS610993 (3.0V out), TPS610994 (3.3V out), or TPS610995 (3.6V out). The TPS61099x series appears to be great for ultra-low loads and features both Load Disconnect and Soft Start. And available at Arrow in 1pc increments for $1.34.
My quandary now… the output voltage is regulated up to VIN >= VOUT + 0.5V. Once VIN is 0.5V over output, it switches to a Pass-Through mode where VOUT correlates to VIN*resistance. Going with a lower output chip like the 3.0V TPS610993 will likely gain marginal efficiencies on NiMH, but it will only regulate Li-Ion at 3.5V and below - anything above that is just VIN*resistance.
Honestly though, according to the datasheet, the efficiency of input = 1.5V and 0.1mA current is ~88% for the 3.0V chip vs 86% efficiency for the 3.6V chip. It might be worth the loss of efficiency to gain the extra consistency in output regulation for NiMH vs Li-Ion and just go for the 3.6V output chip (TPS610995).
The only real downside I see is that this is a BGA (ball-grid array) package which will require reflowing - no hand soldering. You can get it in a WSON package; Arrow doesn’t carry it but Mouser does.
PS - sorry if it seems like I’m talking to myself. Sometimes I feel that just writing down my ideas helps out a bit… and gives you an insight into the wild@$$ thoughts running through my head.
I'm digging the way you and other contributors are posting. I'm learning and it might trigger a helpful idea in someone out there. This is a pretty cool thread.
I don’t understand most of it but I agree with you ImA4Wheelr!
Ok, a new board and components have been ordered. Holy cow this IC looks TINY. Just to be clear - this is completely untested.
It seem to be nearly impossible to solder such small contacts for the IC. I think It will be very hard.
I agree, those contacts are super small. I’ll be reflowing it, but even then, I’m not sure if bridging will be an issue.
Just for fun, I put together an update of the v1.3 board, but using the WSON version of the IC instead of the tiny BGA version. Still really small pads, but it looks more manageable.
Wow, looks like you’ll need a sewing needle to apply the solder paste. I’d like to try it, just for the challenge.
Looks good gchart. :+1:
Happy Dance!
My v1.3 boards showed up today and I put some together using the TPS610995 (YFF package, a tiny BGA). It works flawlessly on both NiMH and Li-Ion and seems to be really efficient, though I still need to run some final numbers (which I will share later). I tested it in both the Sofirn SF14 and the Tool AA. No bleeder resistor needed in either! Though I did notice that efficiency in the SF14 on NiMH without the bleeder was worse; it’s like the main driver was trying to operate alongside the tailcap, though the main LED fails to illuminate. Adding a bleeder put efficiency back where it should be. The Tool AA did not exhibit this behavior.
This YFF (BGA) package is tiny and was a pain to prep. Going forward, I think I’ll be using the DRV (WSON) package.
:+1: :+1:
You did it, Awesome job gchart! :+1:
Wow!
Sweet! :sunglasses: :+1:
Thanks guys!
For a little perspective of size, here’s a couple between a 0805 LED and an XP-L HI.
Some rough math says efficiency is running about 80% with either chemistry.
:exclamation:
Wow! You reflow these in an oven or hot air by hand?
Impressive work sir.
Edit I see above you’re doing it on a hot plate, EXTRA impressive!
Sorry gchart, but I can’t see your pics.
Weird. I use a public Google Drive folder. Maybe I should just start putting them up on my server.
