Yep, his light is very close to the final production version minus the exact LED spec.
Although keep in mind that the readings done like this are lower since some of the light escapes around the edges. I measured this exact light on my sphere using an L6 reflector so that I would capture all of the light and the numbers were about 10% higher.
Yes sir. I may not get the best accurate reading… my light tube is a little bit too small… this light is definitely the best xhp70.2 without spending $600-$700.
This blf gt is a perfect host for the single xhp70.2. You will get plenty of runtime and excellent heatsink…
Can you upload new pictures to the same link by chance? If so then you could simply upload updated pictures and it would automatically update the OP as well.
Ok, it seems that the server, where I keep my images on, assigns random directories. I uploaded a test image from my computer and then uploaded a different version of the image by the same name and it didn't overwrite the initial uploaded image. I guess they do this so that people don't leech other images out of the entire directory. Not sure if the forum allows multiple Admins but if granted to me I could upload the images directly if you want and if not, I'll just keep posting them in the thread. My pleasure either way.
1x Giggle Monsters
2x extra cell carriers
Neutral white - 4000k - 5500k
Would you want a spare Lens if offered for sale? maybe
Would you want 8x 30Q cells if offered for sale? yes
