KD (kaidomain): Deals and new products thread
Is it possible to buy this without led and driver? I only need de drop in as a host, for a custom build
http://kaidomain.com/p/S024795.KDLITKER-P6-XPLHI-Cree-XP-L-HI-NW-800-Lumens-3V-9V-2-Groups-of-3-to-5-Mode-OP-P60-Drop-in
Hi Ban,
I see on your website that the payment system is worked on (so I sent an email for an order). Do you have any idea when the website is restored?
Are these fees tariffs?
From the other thread:
Yes. I believe that is due to 12% import duty + 21% IVA (VAT) + whatever FedEx charges you for the paperwork.
In the meantime I've got informed and now I know I can avoid that by staying below €22 per order shipping excluded.
That sure puts a crimp in your choices keeping it under 22 euros. Maybe that is a good thing? :money_mouth_face:
+1 to this.
You can usually get most seller to write a dodgy amount on the box. I have items worth like 20-30 AUD and the seller will quote like 5AUD.
I bought this: http://www.kaidomain.com/p/S025680.Nichia-CRI92-NVSW219BT-V1-5700K-LED-Emitter-with-14_5mm-x-1_5mm-Aluminum-PCB-5pcs
Not so great of a deal compared to the LH351B that I bought from AEDe but in case anyone wants to try them they're not that bad dedomed. The CRI doesn't really matter when its tint is so white IMO.
Not bad, but not great either.
Any idea when I will be able to check-out with Pay Pal, been unable to check out for a number of days.
BanL - do we have so sign up again for the new system to work? ps: the new design looks great.
“Warning: No match for E-Mail Address and/or Password.”
That was related to a shipment I received from Arrow (USA) via FedEx.
I could not recommend kaidomain - I ordered a torch in November 2017 and it failed to arrive,I have message 9 times from blf and a huge number of emails. Still no decision on whether they will send a replacement. I won’t use again.
Hi duramax
Sorry for any inconvenience cause to you.
As you can see, the new system is totally different from the previous once.
I will sync the data from the old system in the later time.
As this stage, i will try to post all the items asap first.
Please don’t worry. I will keep to improve it.
Best regards,
Ban
Thanks! Looking forward to see all the data coming to the new platform. Good luck with all the changes, so far it is very fast.
Please make sure links to specific products on the old site work when you are done. :face_with_monocle:
Infrared LEDs are in wrong cathegory other LEDs and infrared empty
Wow, just visit KD and it has new design :+1:
Thanks Lexel
I will take a look in it.
Thank you
Sure
All the SKUs are the same between the new and old system
Thank you
