No, I would go with what TA measured on the actual light which is about 500kcd dome on and maybe 780kcd dome off.
It’s possible a CW emitter will bump up both numbers, but I’m not sure TA has measured this combo yet. If he has tested it, I’m sure he will mention that later. (He might take a day off on Sunday)
It was either TA or DB Custom (one of these Texas outlaws) that was planning to make a 4 emitter version using 4 C8 reflectors. I have not heard anything about it recently, though.
Requesting 1 GT70, batteries (price dependent), & 2 lenses. I assume GT70 is delivered with battery carriers installed & extra carriers would not be needed to make light functional? Thanks team.
I haven’t heard the official price on the batteries as it’s still early days, but they should be about the same price as the 35E from the GT group buy which is $40 for 8 button top 30Q. Later on I’m sure we will get more exact info.
Yes, the GT70 comes with two battery carriers and the long battery tube. If the batteries are bought at the same time as the light (and they need to be) they will ship inside the light. If they are bought seperately they may not be able to be shipped to the USA. This is a newer development. It used to be easy for Lumintop to ship batteries seperate, but not any more.
Technically this light will be the same as the video you saw minus the exact LED used. So it could in theory give you the same type of numbers if you de-domed the LED.
I have not tested a P2 emitter dedomed yet so I am not sure what it will do, the 750-800kcd is a conservative guess because it is always easy to raise the numbers later but very hard to lower them.
This applies to all the official ratings right now, they are all quite conservative compared to what I have personally measured even.
Until we find the production LED it is just impossible to know for sure what the numbers will be.
All of that said, if you swapped the LED for the same one VOB used (think he got it from kaidomain.com), then it would be exactly the same as his light.
At this pace we will need battery tube couplers in no time. Especially if there are real plans to make a GT with four or five xhp70.2s :smiling_imp: Will there be a poll how many emitters will be used in the next BLF GT project? :smiling_imp:
