KD (kaidomain): Deals and new products thread
That sure puts a crimp in your choices keeping it under 22 euros. Maybe that is a good thing? :money_mouth_face:
+1 to this.
You can usually get most seller to write a dodgy amount on the box. I have items worth like 20-30 AUD and the seller will quote like 5AUD.
I bought this: http://www.kaidomain.com/p/S025680.Nichia-CRI92-NVSW219BT-V1-5700K-LED-Emitter-with-14_5mm-x-1_5mm-Aluminum-PCB-5pcs
Not so great of a deal compared to the LH351B that I bought from AEDe but in case anyone wants to try them they're not that bad dedomed. The CRI doesn't really matter when its tint is so white IMO.
Not bad, but not great either.
Any idea when I will be able to check-out with Pay Pal, been unable to check out for a number of days.
BanL - do we have so sign up again for the new system to work? ps: the new design looks great.
“Warning: No match for E-Mail Address and/or Password.”
That was related to a shipment I received from Arrow (USA) via FedEx.
I could not recommend kaidomain - I ordered a torch in November 2017 and it failed to arrive,I have message 9 times from blf and a huge number of emails. Still no decision on whether they will send a replacement. I won’t use again.
Hi duramax
Sorry for any inconvenience cause to you.
As you can see, the new system is totally different from the previous once.
I will sync the data from the old system in the later time.
As this stage, i will try to post all the items asap first.
Please don’t worry. I will keep to improve it.
Best regards,
Ban
Thanks! Looking forward to see all the data coming to the new platform. Good luck with all the changes, so far it is very fast.
Please make sure links to specific products on the old site work when you are done. :face_with_monocle:
Infrared LEDs are in wrong cathegory other LEDs and infrared empty
Wow, just visit KD and it has new design :+1:
Thanks Lexel
I will take a look in it.
Thank you
Sure
All the SKUs are the same between the new and old system
Thank you
Hey Ban when i am scrolling it lets me only select LEDs by category say XML will show only XMLs. Are you going to allow all LEDs and or other items to be viewed at once like a home page for each category? Say a page where i can view XML,XP,Nichia LEDs in one place?
I am not sure if i am explaining this right.
The website looks nice and is quicker then the old site :smiley:
BanL,
I go to bare leds category, choose XP-G2 3A, add to chart, and force to choose the mpcb board (16mm/20mm) which is adding the cost. Does it have to be like that or is there a mistake in web programming? because when I try the other led (Nichia 219C) there is no option to choose the mpcb. Please confirm this. Thanks.
I wanted to see the new site but I keep getting “Not found” using http://www.kaidomain.com/
Your link is fine. I just check that.
Yea worked on mine also maybe clear your history and cache and try.
