ordered HI CW blue
Ordered one HD in brown
Do we have any idea when these will ship out from Banggood?
Where can I get a good price on 26650? Should I get unprotected or protected? Thanks.
interested
This application is not especially high drain for a 26650. At full output it is going to be right around 7 amps. The choice of protected or unprotected is up to you, but in general unprotected cells will provide higher output because there are some losses in the protection circuit. Any 26650 cell from a respectable manufacturer should have no trouble delivering 7 amps, so avoid the ultrafire, trustfire, or any other name ending in fire, you are probably going to be OK. Generally the very high current cells sacrifice some capacity to be able to deliver 20+amps so the 5200 and 5500mah or even higher capacity cells from reputable vendors should be fine. If you want delivery in the immediate future, buy from someone based in the US. I’d recommend Mountain Electronics, they have an excellent reputation and good pricing, www.mtnelectronics.com. They also offer the 23650 cell, which allows you to operate the SC26 in a short form factor, or perhaps higher output using a pair of 23650 cells and the longer form factor.
Thank you.
I ordered one HD NW in brown. Thanks Freeme.
Interested.
The preorder page says that there are 26 days from today left in the preorder so that puts it right around the late first or early second week of August.
Interested
Just keep in mind what happened last time someone tried to guesstimate shipping dates for this light. At least the BG order page is reliable with regard to back ordered vs shipped status.
KuoH
Valid point. Just because the preorder ends doesn’t mean they are going to immediately be sent out.
Hi
What is the beam profile difference between the HD and HI. Any pics would be helpful.
Thanks
interested!
I ordered one HI CW in green. Thanks Freeme.
Little Fatty Pre-Ordered (again?)
(But this time with XHP35 and an effective driver, hopefully good things come to those who waited from failed GB)
Thanks FreeMe.
! Clip removed to avoid confusion.
^ That’s the old version with XP-L btw.
Still waiting for the PM or email. Everybody else waiting?
