These two choices almost seem like trick. Option B uses two different fonts that donāt even match each other. So the only other choice is to choose a slightly less unattractive option A.
Hopefully they can make it very small and not take up the whole flat area on the battery tube. Maybe they can put all logos on one side?
A is the best of the two because its all the same font. Rabbit addition would be good.
I am still purchasing either way and can live with whatever is decided.
It looks like there is room to put both āLumintopā and āGT miniā right here. That might look good. Maybe do the āGT miniā slightly smaller than āLumintopā.
The original example is wrong, so wrong.
B is wrong wrong wrong, justā¦so, wrong.
A is less wrong, but folks, āGTā and āminiā are not in the same āfont.ā They are both sans-serif though (in B, āminiā has serifs.
I donāt know what the āGTā is, but the kerning (spacing between the letter) doesnāt look right.
If I get one of these, I may do what Iāve done with lights Iāve modded and want to get rid of the original (often hideous) engraving: Strip the anodizing from flat spot, file them down just enough to get rid of any trace of engraving, and then polish them out.
Yepā¦. I really donāt care what they doā¦. as long as it looks professional & they just do it.
No need for this to get bogged down in a multi week āBLF opinion festā.
