Yeah, the MF03 never got off the ground, I was wanting that to be my first real monster light beyond the Q8. This would be an opportunity to leapfrog the market on that concept, perhaps with a more budget friendly version, 3x XHP70 but not all reflectors the same, and selectable between them or all 3 at once, to give flood, throw, general purpose beam, or all 3 at once for raw power, run on 26650 series tube instead of multi-cell carriers.
21700 will be the future. But so will be 18650. Itâs not going anywhere, there are no signs of it becoming obsolete.
Quads use less empty space in a circle than triples do, so they are more space-efficient in general.
I actually did some calculations of it, but I have lost the spreadsheet. Anyway the result was that quad 18650 simply offers more mAh/mmÂł than triple 21700. And thatâs my point.
What about 3x21700 in series instead of 4x18650? I wonder if that would make the battery tube slightly smaller in diameter for a more easy carry? As it stands I think tubes that hold 4x18650 are slightly too large to be considered comfortable to hold.
1x26650 tubes are very comfortable to hold, and I find 1x18650 tubes slightly too small to hold.
As far as I know, there are no really good 32650 cells in production, so I would also prefer 3Ă18650 flashlights.
It is a very handy format, and I think, Sofirn could develop awesome models of it.
My detailed proposal (I could not determine, in what extent I am off topic, but I need to spread words ;) ) for one possible model:
3Ă18650 in parallel configuration
3 separate XP (3535) footprint emitter on d=16mm copper boards each (high CRI emitters would be welcomed - LH351D !)
one separate TIR optics per emitter (essential part!)
spacers and bezel should be designed for super easy optics swapping
efficient mass and some fins for heat spreading
don't have to be super bright, but around 2-2.5A sustainable current per emitter would be good (I am not expert at the driver part)
Once this would become alive, I think, it should be super awesome - and this wouldn't be something extraordinarily bright and heavy, just very practical.
(I think, it would weigh around 280-350 g without batteries.)
Btw, I had some of these optics installed already in one of my lights, and had very interesting results.
After some thinking I like that idea a lot, though I would do it with a factory-shaved dome and quad 18650.
I wonder what current did you really meanâŚ
because 8-9A 6V wonât deliver 7500 lm even on the LED. 8-9A 12V would, but thatâs quite a lotâŚ.7-8 would be more like it.
High power and high CRI with a focus on good tint would be nice. Being able to swap the head for flood/throw and the tube for different size cells would be pretty sweet too. Add a special anodizing colour option like dark blue or bright green, with tubes/heads to match.
triple and quad optics are manufactured with very few possible beam patterns (mostly one or two), and if you look up the optics, which I have linked, they offer way much better beam shape customization (regarding hotspot size, hotspot to spill transition, spill brightness - I can include my observations, if you are interested) - which would really shine, when it would be used in the 2000-3500 lumen range.
because of the 3535 format, anybody could source his own preferred emitters - even attempting to mix tints
Considering how popular the BLF Q8 form was, sticking with 4x18650 batteries and an XHP70.2 LED would make for a very nice light. 4 cells in series matches the 12v needed for the LED (with a buck or linear driver), much better than a 3-cell version would.
Just a single XHP70.2 would probably be enough, and be well matched to what the light could maintain without overheating.
You could distinguish the light from the Q8 by including a diffuser cone to make it a nice optional lantern.
I know a lot of people here want to see the 21700 and 20700 cells being used, but IMO we all have a lot of 18650 cells already and Iâm not ready to make that jump quite yet. Iâm not convinced theyâre a better cell than the 18650, especially in multi-cell configurations (due to heat, spacing, and energy density).
The 2S 28650 will offer more natural in the hand not too fat like 4x18650 also the classic look of old Maglite and the good cell like Lii-500 or Shockli 5500 is cheap and provide decent current/capacity. Today we have plenty of 4x18650 light to buy in the market but not many good 2x28650 the L6/S70s were couple years old and not powerful enough for 2018 âŚthat my idea.
You are correct, the 8-9A was for the 12V situation, in 6V it needs quite a lot more current, like 15A (and very good heatsinking but that should be possible with a host this size)
Please, no. Just because you can, doesnât mean you should.
Weâll get a better light, sooner, for less money, by not going for stuff like this. The fewer bespoke parts, the lower the cost and the easier it is to build in quantity. Plus, if the light has a plausible market beyond BLF, one an order of magnitude larger than the BLF, then the fixed costs can be planned to spread over a much larger volume, again leading to a cheaper light and a happier manufacturing partner, one who will want to do more projects like this.
Actually the fact that thereâs a large market beyond BLF speaks for factory shaving.
Because shaved dome makes a much better thrower and few non-BLFers will be able to shave LEDs themselves. So this would be a much better stock product for not much higher price. With 9 cm reflector it should outthrow BLF GT with domed XHP70.2 while providing not much lower output. Similar performance, 2/3 size, half price.
I thought this âK70â dealy was to essentially be a revamped L6 of sorts.
If so, Iâd recommend no tailswitch. Tailswitches are fine for one-hand-hold lights, so you can hold it and operate it on/off/momentary with your thumb (icepick grip), but just having one to use the switch instead of a tailcap lockout unnecessarily adds resistance (no matter how good the switch). Worse, with a 2Ăwhatever cell tube would make it really unwieldy to try to operate it one-handed by pretty much holding it by the tail and having a really nose-heavy head pulling it down.
As much as I prefer FC switches, something this big would probably be best served by a RC sideswitch like a 2D Maglite or something. Or have an e-switch with a UI that could be switched (haha) between EDC mode (standard half-click to change modes UI) and âtacticalâ mode (simulate a momentary-on for flashânâdash ops).
Replacing a mechanical switch with an e-switch also gets that pesky switch-resistance out of the way and lets the FET do the heavy-lifting.
If youâre going whole-hog anyway, why not do the UI right and get rid of the weak-links?
No, that would not be realistic. The stock L6 at about 3200 lumen just barely is sustainable. The temperature gets way up beyond safe levels, but it does not destroy itself. For an L6 sized light, about 2,000 to 2,500 lumen might be sustainable without burning anyone.
