These two choices almost seem like trick. Option B uses two different fonts that don’t even match each other. So the only other choice is to choose a slightly less unattractive option A.
Hopefully they can make it very small and not take up the whole flat area on the battery tube. Maybe they can put all logos on one side?
A is the best of the two because its all the same font. Rabbit addition would be good.
I am still purchasing either way and can live with whatever is decided.
It looks like there is room to put both “Lumintop” and “GT mini” right here. That might look good. Maybe do the “GT mini” slightly smaller than “Lumintop”.
The original example is wrong, so wrong.
B is wrong wrong wrong, just…so, wrong.
A is less wrong, but folks, “GT” and “mini” are not in the same “font.” They are both sans-serif though (in B, “mini” has serifs.
I don’t know what the “GT” is, but the kerning (spacing between the letter) doesn’t look right.
If I get one of these, I may do what I’ve done with lights I’ve modded and want to get rid of the original (often hideous) engraving: Strip the anodizing from flat spot, file them down just enough to get rid of any trace of engraving, and then polish them out.
Yep…. I really don’t care what they do…. as long as it looks professional & they just do it.
No need for this to get bogged down in a multi week ‘BLF opinion fest’.
