Small flashlight with red light
Is there a small AA or 18650 light with red light and at least three modes with moonlight (for the red light)
I need one but I think I’ll have to build one using a S2+ host or similar
What’s your budget, and your definition of small? What form factor do you want?
Zebralight makes the H502r . There’s also the Armytek Dobermann in red, and the Jaxman E2L color . You could also order a red build from PFlexPro, but at that point you could save a lot of money building your own.
Nitecore EC21 might be a possibility. I found one for under $30 a year ago but they seem to be going for $60 on most sites now.
my budget is very small
I found a deal for a eagletac D25A Ti with xpl HI, I could order a red XP-E2 from kaidomain and swap it
It has moonlight mode and always start in the lowest level, which is fine
just received the D25A Ti, but it’s so nice that it’s a pity to mod it to red light only. I think I’ll swap the emiter to a NW one and keep looking for a cheaper host
Maybe a P60 drop-in would work for you.
Just pick up a cheap 501B or whatever.
Red p60
Not sure what you’re expecting from the red light but the nitecore EA 11 and EC 11 both have a multiple white light mode’s as well as a single red light mode
BE CAREFUL trying to swap a red LED where a white one exists now.
The voltage drop for a red LED is around 2V, and about 3V and change for a white one.
If the driver is linear, and has, say, a bunch of 7135s which have to eat the excess voltage and burn it off, you can cook them. 4.2V from the cell minus 3.2V from a white LED means a 1.0V drop. 4.2V from the cell minus 2.2V from a red LED means a 2.0V drop, or the 7135s will have to burn off twice the voltage, thus twice the wattage.
If the driver is cheap and just has a bunch of parallelled resistors as a ballast, then twice the voltage difference means the red LED will be hit with twice the current of the white LED. Ouch.
It sounds like a simple swap, but there are lots of potential problems doing it. Best to either get a drop-in made for a red LED, or just get a light with a red LED designed-in, or make your own drop-in from scratch. Even a simple contact board with a hardwired resistor would be better than cooking a driver or the LED.
What about something like this? Doesn’t have 3 modes, but it’s variable brightness…
https://www.amazon.com/Orion-5755-RedBeam-LED-Flashlight/dp/B0000XMUZA
I use red flashlights for my astronomy hobby. They don’t kill your night vision.
I have too many hobbies…
I didn’t know this, I thought they were 3v leds
So if I put a red led to a normal light like the sofirn SF10, lumintop tool AA, etc it’s bound to fail someday? I think the lumintop uses PWM
why not just tape a red filter on it?
Not cheap, but you could get an Acebeam UC15. It’s powered by 2x 10440 and is about the size of a small 1x 14500 light.
Comes with a very bright red LED with one mode. Also has a white LED with several modes (max 1000 lumens), and a UV LED. Interface is quite nice.
I have one, but the red is too bright
Yup. You could get a red diffuser cap for less than $2.
About 2.0V-2.2V or so. Old-timey red LEDs were about 1.6V.
It probably wouldn’t be too happy.
PWM still would send high-current spikes to it, and accidentally hitting “turbo” might fry it.
Are you sure you need a red light? I remember a thread on here, where in testing a low luminar white light was better at persevering night vision and gave a more usefull light than using a red light or red filter.
Cant find the thread at mo
