Low-cost copper pills, spacers, optics, drop-ins. Custom parts.
1662 posts / 0 new
Chatika vas Paus
Last seen: 7 min 3 sec ago
Can I buy a custom RR only? I mean without pill. Would like to buy 9pcs.
kiriba-ru
kiriba-ru's picture
Last seen: 17 min 42 sec ago
Yes you can. I need to calculate stocks and will pm soon.
Chatika vas Paus
Bought a long time ago. I forgot to upload photos.
P1D with nichia 5000k cri 90+
S2+ with triple nichia 5000k cri 80+
The copper pill is still waiting for triple xpl hi
johnkey68
Last seen: 16 hours 48 min ago
delete
joker145
joker145's picture
just wanted to say thank for quality parts, just finished putting together my c8+ triple.
20180630_200416
The Best Revenge Is Massive Success
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 hours 53 min ago
May I ask what parts your C8F consists of? The host seems brand new with its sand colour but I don’t see the side switch that all new C8F hosts have right now. What kind of TIR lens did you use and what emitters are in your light? Looks like XP-E2 red with these red-coloured reflections. I’m really curious.
joker145
joker145's picture
LEDIL CUTE TRIPLE LED LENS (purchase through kiriba-ru)
Nichia 219C
FET + 7135 Driver – 17mm – MTN
Noctigon XP32 32mm Copper MCPCB
Agro
Agro's picture
Last seen: 1 hour 36 min ago
This is not Sofirn C8F but Convoy C8+.
Chatika vas Paus
joker145 wrote:
just wanted to say thank for quality parts, just finished putting together my c8+ triple. 20180630_200416
When did you buy this spacer? Recently, kiriba wrote that they are no longer available. I also wanted to build with C8+.
kiriba-ru wrote:
No. I was not sure that there is any need in spacer since cheap triple sofirn host is available. Also I dont think internal rivalry with C8TT is a good idea.
kiriba-ru
kiriba-ru's picture
More than 6 month ago?
I dont see C8 spacer reasonable if you can get C8F with reflector and dtp pcb for $14.
For those who want to make unusual build I have C8TT.
vinte77
Last seen: 15 hours 3 min ago
kiriba-ru wrote:
More than 6 month ago? I dont see C8 spacer reasonable if you can get C8F with reflector and dtp pcb for $14. For those who want to make unusual build I have C8TT.
I think some of us like options when it comes to hosts and e-switch/tail switch. Plus the increased costs isn’t always a deal breaker.
kiriba-ru
kiriba-ru's picture
One blf member will have more interesting option for C8 soon.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 5 hours 12 min ago
Yes, I read it from Neven, that he will sell spacers, MCPCBs for 6 LEDs and a lens for 7 Emitters, the middle optic is not used.
SKV89
Last seen: 13 min 48 sec ago
If the lens is for 7 emitters, why not make the MCPCB for 7 emitters?
kiriba-ru
kiriba-ru's picture
Because you need hole for wires.
Lux-Perpetua
kiriba-ru, do you have more of these good copper-made spacers for Convoy S2+ with triple emitter for sale?
kiriba-ru
kiriba-ru's picture
Spacers in stock.
No emitters in stock.
Lux-Perpetua
Do you think the Small Sun ZY-T43 would also be a good host for Neven’s new option? 2 cells in parallel would be a good benefit, wouldn’t it?
https://www.fasttech.com/product/5523400-small-sun-zy-t43-led-flashlight...
kiriba-ru
kiriba-ru's picture
It is too rare.
Lux-Perpetua
Sorry for being so inquisitive. Blushing What do you mean with “too rare”? Do you mean the flashlight is too “unknown” to say if it’s appropriate for Neven’s new option?
kiriba-ru
kiriba-ru's picture
Nobody would invest in mod part for the light with unknown manufactured quantity.
There is probability that you will have more mod sets than hosts available on the market.
will34
will34's picture
Last seen: 2 weeks 3 days ago
I’m interested in the C8TT head but do you have the updated version of SS bezel? With sharp crenellations instead of wavy. Like in the C8+.
Thanks
kiriba-ru
kiriba-ru's picture
You can pm me, I will combine set without bezel for you, if you can get bezel yourself.
johnkey68
It’s hard to unmount the driver
The head and body of the lantern are glued together
Very thin layer of aluminum on the head, thickness less than a millimeter
During disassembly, I broke the head of the lantern
Do not waste time on it
kiriba-ru
kiriba-ru's picture
If somebody will be able to supply 17mm boost drivers, I would make S2+ pills for single led.
The_Driver
The_Driver's picture
Last seen: 2 hours 27 min ago
kiriba-ru, the C8TT looks great! I will probably order one in the next few months. It’s too bad that there is no compatible 26650 (or at least 21700) body tube.
I read that you mentioned soldering a 17mm driver to the retaining ring. Will it only be fixed by the solder then (not good for mechanical stress…)? Is there no way to use a 20mm to 17mm ring, maybe one from Kaidomain?
kiriba-ru
kiriba-ru's picture
C8 heatsink head was developed to use with current regulated drivers. Actually, this is test bench for those who want to confirm or dispose any supposes about flashlight cooling. Surely you can put 3 (4 with upcoming led4power boards) modern leds with fet and get 50-60W, but this power is not best idea to show difference between thermal transfert ways. I could not find solution to fit 22mm driver, so it was mainly supposed that it will be used with 20mm boost driver from KD (modified to 3S). I had to make custom retaining rings, same time wanted to avoid problem that I met with S2+ custom rings. Milling grooved after turning threads put up some burrs and I have to calibrate every single ring with die to remove them. So, I added a lip without threads.
After I imaged all this on drawing, I realized that if I change ring inner diameter to 17.0mm, there will be a chance to use same ring in same head but with 17mm driver soldered to the ring. I think I left this opportunity for myself, probably didnt have any 20mm drivers atm lol. Dont think anyone have tried this solution.
You cant use driver adapter. With 20mm driver (1.5-1.6mm thick), you have retaining ring (threads part) almost flat (-0.2mm) to the top of battery tube. Any existing adapters are thicker, you wont be able to screw retaining ring down in its place so battery tube also wont be able to screw all way down (19mm battery tube can fit lip with grooves but cant fit 21mm threads inside). Also, ring is 17mm id, so it is not able to fit 17mm driver negative contact surfaces (outer ring), so you will need soldering even with adapter.
Im not sure youve ever pass solder mechanical properties in the config we are talking about. Driver weight is 3-10gr, damaging solder will require several hundred g acceleration.
The_Driver
Thank you for the detailed answer. I will solder the driver then.
What you mention is actually exactly what I want to do (led4power driver + 3x Luxeon MZ). The DD-mode is too much for this host, but that is the case for every 1× 18650/26650 host. For practical lighting the led4power drivers offer lower modes.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 7 min ago
Those would run XHP Leds? I would buy driver and pill Evil
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Lux-Perpetua
kiriba-ru wrote:
Sometimes I recieve PMs with request for cheaper parts (or asking very big discount). In most cases this is not possible, but now I can offer such deal. I have some P60 quad shells that dont fit retaining rings (neither custom or convoy) so you will have to use solder to fix driver in place. $7/piece valid until stocked
I’m interested. How many have you got left on stock?
