Just like to mention regarding anodization quality of Sofirn flashlights (I got a number of Sofirn flashlights by now, although the only one I more regularly use is the SP32A)
So far, my most often used EDC flashlights are the pair of Astrolux S1 (3D tint) and Sofirn SP32A.
I’ve had the Astrolux S1 much earlier, but the anodization is still good.
The Sofirn SP32A is newer, and yet it seems the anodization is fading already (see the white specs on the main body tube in above picture).
So I would rate the anodization of the Astrolux better than the Sofirn.
(I also have the Convoy S2+ Desert Sand, but I rarely use it; I would rate the Convoy S2+ Desert Sand’s anodization to be a bit better than the Astrolux… though I could be biased since I more rarely bring out my S2+ Sand…)
Would a comment from a naysayer be a real downer here? I received an SP32a a couple of days ago, and I’m not as thrilled by it as I thought I would. The ramping function may not be as useful for my purposes as I thought. I change light levels frequently, and as fast as it ramps, it’s hard to get it just right each time. The leap in lumens in the programmed mode is odd. Does it seem strange to you, the big jump from 160 to 900 (from med. to high)? Also, having the moonlight mode in the regular rotation is kind of annoying (I must not have paid much attention when I read the specs!). If I need ML, it’s at a time when I don’t want to turn the light on at a higher level. So I have to remember to put it in ML mode before shutting it off. This was bought as a replacement for my Thorfire TK15 which is acting up. I like the UI on that light better.
Do you have v2.0 which takes about 4 seconds to ramp? I would not think of that as being too fast. I’m used to NarsilM which takes only 3 seconds so 4 seconds seems like a good thing.
Or do you have v1.0 which ramps over 8 seconds? That is pretty slow, but it seems like you can stop it exactly where you want. Except at the lower levels maybe.
I notice v1.0 goes from 160 to 900 lumen. (4, 43, 160, 900, 1550)
V2.0 goes from 130 to 500. (5, 50, 130, 500, 1300)
Judging by the lumens, I have version 1. But it doesn’t take 8 seconds to get all the way from lowest to highest. With practice I might be able to hit the right spot when I’m ramping very easily and then change directions to make it dimmer or brighter and hit the spot I want. I don’t know that I would be worth the effort. But I’ll give it the ol’ college try. The spread between medium and high in version 2 makes much better sense. But I’m stuck with the one I have. I bought it from China; it wouldn’t be worth the cost of sending it back.
Selling it would be fine, but I don’t know personally anyone who would be interested. If I did, I would have already tried to sell the Wowtac A3s. Maybe I’ll put them on 5Miles. But I don’t want another of these Sofirns if the moonlight mode is still in the regular rotation. The Thorfire UI makes better sense to me; it goes to ML with a long press from off. If not for the switch acting up on the TK15, I’d be happy with that one. At least now I know some things to look out for in the future.
Sofirn is working on a new UI. Right now it looks like they are willing to remove the moonlight level from the rotation and have it accessible only from off with a 1 second press and hold.
The newer ramp speed is about 4 seconds and smoother. They wanted to include turbo in the normal cycle, but I’m trying to tell them to leave it out. Keep turbo with a double click.
So the new UI has 5 levels. Moonlight and turbo are hidden. It cycles low, med, high, low, med, high. I also would like a single click on and off. You press and hold the button to go through the 3 brightness levels.
That essentially describes the UI in my Olight, sans the ramping mode:
L-M-H in normal rotation, hold to cycle. Single-click on/off.
ML = when off, long press to on.
Turbo = double click from any state.
Strobe = triple click from any state.
ML is memorized. Turbo is stepped down to H in memory. Strobe isn’t memorized at all.
It works well, isn’t complicated, and the “special” modes come into play only when called upon.
IMO, ideal for a single-switch, general purpose light, with no need to reinvent the wheel like some try to do.
At some point during the SP32A production run, the firmware was quietly updated with improved ramping speed. An unofficial “v1.1” if you will, not v2.0, which is an official new model.
Continuous improvement is fine, and welcome, but the manner in which some of these companies (fail to) document changes and market their products does no favors to consumers. I get that these are small entrepreneurial enterprises where labor of love plays a big role, but that doesn’t preclude a considered and consistent approach to the marketing as well.
AFAICT, there have been four versions of the SP32 thus far:
SP32 - the original. An evolution of the SP31 as a new model, with single side-switch.
SP32A - new model with ramping mode; lower modes slightly adjusted, higher modes significantly bumped up
SP32A “1.1” - “later production batches” with quiet running update for improved ramping speed
SP32A v2.0 - new model, with power indicator, temp regulation, mode adjustments, and other minor changes.
Given the notable changes in the v2.0, I don’t know why they abandoned the previous practice, and just iterate the suffix, and call it the SP32B, instead of the less elegant and confusing addition of yet another suffix. Or maybe it could have gone down the other path and just been the SP32 v3 or v4 to begin with.
I agree. They should stop calling it SP32A. During this time of changing the functions, how is the buyer to know which he/she is getting? Businesses could keep selling old stock for awhile.
I ordered the v2.0 to act as a “beater” version of this light. Something I won’t worry about losing, or having disappear; a throw-in-the-bag kind of thing. The mode spacing is very similar, with slightly higher levels.
I like and don’t regret the Olight, but I can get three Sofirns for what I paid for it, on sale.
In the Sofirn AliExpress store, the SP32A and SP32A v2.0 are listed as different items (and different prices).
Now the SP32A ‘v1.1’ (faster ramping) — it’s not mentioned, but since I ordered SP32A around Feb 2018, and another time around April or May 2018, the earlier SP32A I got has the very slow ramping (about 8 seconds from low to high) whereas the newer SP32A was faster ramping (about 4 seconds; although still ‘linear’).
I’ve also ordered the SP32A v2.0, still waiting for it to arrive… as it’s said to have logarithmic ramping (smoother visual brightness).
