2 mode groups (only 2 groups is their idea. They might be limited in storage space for coding).
Group 1: 5 brightness levels.
Single click to turn on/off, press and hold to choose mode low-med-high-low-med-high cycle.
Moonlight and turbo hidden. Turbo is a dbl clk. Moon is press and hold for 1 second from off.
To switch mode groups, something like 6 fast clicks or press and hold for 3 to 5 seconds from off. Something a bit unusual so you don’t accidentally switch groups, but easy enough to remember.
Group 2: Ramping.
Click to turn on/off, press and hold for ramping. Changes direction similar to Narsil. Dbl clk to turbo. Moon is press and hold for 1 second from off then click to turn off.
Does the above sound okay?
I don’t know if strobes are necessary since they are not on the C8F. They can probably be added and activated with a triple click. (I never use strobes)
Is there a need for electronic lock out or is mechanical lockout prefered? (I always go for mechanical)
It’s important to get a good UI into place as they may use this on other future lights.
The ramping mode with extra standard modes sounds good its got every thing we need with out being overall complicated.
So if this light has a tail cap any way they can program a standby mode into the side switch? This will give us the best option for one handed operation. I think the S70 has a standby mode ill have to check mine.
Have they mentioned a price or do they want a parts list?
Hey Chris, how’s it going. I’m glad somebody likes this.
All lights have a tail cap, maybe you mean tail switch?
This UI will be usable on either style. A single click of the side switch is on/off. If a light using this UI happens to have a tail switch, then that will just be for mechanical lockout. You don’t control the UI from a mechanical tail switch.
No prices have been mentioned, but I assume they want to keep prices in line with the competition or maybe better it. I think if they can come up with a better product (updated emitter, SMO reflector, better UI, maybe higher output) at the same price as the competition, it will be a winner. Even if it costs a bit more, you won’t have to swap a bunch of stuff to upgrade it so you still come out ahead.
I can say for sure they will not want to use heatpipes and stuff that would just raise the price and add complications.
Yea I mean switch. Some side switches don’t have a standby setting when using a tail switch they rely on the on the tail switch as lockout. But looks like this ui does have the ability to turn the light on/off with the side switch.
You can also program the mechanical switch to change modes if you wanted duel switch controls.
Yea the easier the light the better it will be cheaper and easier to make. Does sofirn have access to the S70? Or will they build the light from scratch?
What’s the kcd numbers on your modded L6 Jason? The S70/k70 has the same size smo reflector. Probably no shaved LED on this project. I think we need to wait and see what sofirn can do.
Maybe we can suggest a 80mm ish reflector?
Jason, I’m with Chris; I like the UI. It has all we need. Personally I have no interest in strobes and such. I can take them or leave them… but if it does have them, hide them away. I like & use manual lockout most of the time. Switch lockout is OK too if you want to add it… your call. I’ll still use mechanical to most of the time… I always do.
I agree…. keep this one a simple & to the point ‘workhorse’. Good UI & components without unnessary bells & whistles. :+1:
If sofirn want to keep the size and 2x26650 series form factor I think put in a smooth reflector that 5mm bigger than L6 or S70S and put in an XHP70.2 and give it 10-12A current in turbo and about 3000 lumens in ramping max. No need tailcap switch bacause it is uncomfortable. Only side switch with a good lockout (NOT long press to unlock) triple or quad click. Lighted bitton which show battery level with two colors. 8mm thick led shelf or more. Use 25mm DTP copper MCPCB so a 25mm Maxtoch is an easy replace if somebody want it. Big heat fins on head.
Edit:
Just saw in OP that you want to keep the tail switch and use a 9A switch. But if you leave the switch out then no need to worry and make the light drain 12A from batteries. And it is more simple and cheaper.put the switch parts price in a more better driver.
I have a stock L6 and like the side switch very much. Sometimes in the dark, it takes me a minute to find it. With gloves on it’s even more challenging.
A lighted side switch would help, but that would also add cost and drain the battery.
Is it possible to make an obvious way to find the side switch by feel alone?
My L6 with 70.2, FET driver doing 17A (5,750 lumen @ 30s) and SMO reflector got 172kcd or 830 meters. I predict with a sliced dome it would do about 1100 meters.
VOB’s L6 with the same parts measured closer to 1000 meters. With a sliced dome his should be around 1300 meters.
His lux measurements are always higher than mine for some reason even though we use the same model lux meter (LX1330B).
Keep in mind that the stock L6 CW measures about 3200-3300 lumen and the S70 about 3700 lumen. If the Sofirn can do 5000 lumen it would be a big boost over the older lights. It’s still unknown what kind of driver they would use. I think a FET would be possible as long as they had good working thermal protection as it will get hot very fast.
Basically, I’m not sure if this light would hit 1000 meters stock. The stock L6 is only 530 meters. To get 1000 meters might require a sliced dome.
These numbers sound great to me! Also a very well hidden strobe.
As long as it has ramping, I’m happy. These 2 groups would make everyone happy I think
Side switch (no tailcap button) with a UI lockout would be awesome
Lighted side switch would be perfect
I agree with Caleb. One drawback to the L6 is the area where the button is placed is really hard to find in the dark. I think the fins around the neck of the light are too close to the button… so its easy to skip over the button trying to feel around for it. Whoever draws this thing up, try to include a more obvious button area. Maybe make a slightly larger flat area with the button so its easier to find. Lighted switch would pretty much make finding it in the dark a non-issue.
The K70 and L6 use a 75mm head, so 15mm more should not upset anyone. Plus it gives a bit more throw. I am okay with this.
The 9A tail switch I assume is “125v 9A”? The Convoy switch is 125v 10A and it has held up to 17A FET drivers, so this 9A should be okay, too. I assume the tail switch is for lock out only. It is not practical for turning the light on/off. I just want to be clear on that.
The 2 mode groups sounds acceptable as well. It just needs to be well thought out so it does not annoy people.
I like lighted side switches and have one on my L6. It helps me see if it is mechanically locked out or not. I don’t know if Sofirn can do a lighted switch. Maybe?
If it’s not lit, having it raised a bit would definitely help to find it in the dark. It may be too early for these small details, but it’s still a good idea.
Maybe if they put a tripod mount on the other side of the head where the switch is you can put in a little lanyard attachment thing like the one on the GT and Astrolux MF02. And with that you can easily feel where the button is. Also the lighted button helps a lot. I don’t think 0,5mA for button lighting will affect much on main led performance and output
Why not dual switch? How many BLF members have a light that functions off both switches? You can choose to use the tail cap or not and it still functions as a lock out. I have several LD-2 driven lights and find that it suits both uses more than having just a side switch. Specially if it is bezel down and you need it quick, quite intuitive.
