Nonsense, I was able to lead a group of 7 mountain bikers home in pitch blackness with one 18 lumen Petzl headlight. My first maglite was a AAA solitaire with 2 lumen output, in candle mode it could light up a whole room once your eyes were properly adjusted.
Now here is a war story, years ago I was out with my ski club (actually my sailing club, we did this every year), last day, we had booked an evening at the top mountain hut after the lifts closed. A fondue evening, to be followed by a run back holding flaming torches. 1.5 Km down, 7Km distance. Red and black.
Then the proprietor offered around his home made schnapps. So we imbibed (would have been rude not to).
By the time we left it was past midnight, we were all inebriated, a storm had blown up, the flaming torches blew out instantly. So we had a discussion. The decision was to go off-piste, directly down, 2.5 Km. the snow crust had frozen hard so we thought even those without powder skis could do it.
I was the only one with a decent head torch, so I lead from behind. Our guide led from the front, she had double ended skis and could do a black run backwards faster than any of us forwards, as for the snowpark…)
So we got all of us back with just my crappy head torch, a “1W” led powered by three duracells.
And the sweeper-up on the snowmobile (we did do some risk assessment) didn’t have to work, nevermind calling in a piste basher to take more down.
So, hundreds, or thousands, of lumens are an extravagance. Keep it real and let your eyes work.
Looks interesting if it does require minimum shaking and the size is about right.
I still have 2 of the original Shake Lights from I’m guessing around 20 years ago. They were quality built but required too much shaking for the minimal light they produce. They were around $40.00 back then and I got the pair for next to nothing as people who originally paid the big bucks found out fast they were more hype than anything and let them go for cheap.
They did spawn a slew of imitators that were cheaper but were absolute junk. Guess I’ve kept these around in case the apocalypse comes to fruition.
Good luck with your project.
P.S. These original Shake Lights are good for arm exercise!
Here’s an idea, make an inductive docking station to charge it up usually. You have the coil already, it just needs another one in the dock, like an electric toothbrush.
Like the emergency torches that you can buy already. Some of them switch on automatically if the mains power goes.
One thing i’m worried about is i’ll never use it… unless i ran out of every other possible light source, including a lighter or matches. And then, years after, i fear the Li-Po battery will be dead from aging when i finally need it. How long will the battery last unused? In most situations i’d rather carry a couple AA lights and spare batteries rather then this somewhat big light.
Still, if i was stuck in a remote cabin for days and was out of every other power source, i’d be glad to have it.
Eternal flashlight? Will it be serviceable to change parts or upgrade it?
Considering this shake-me light dimension i’m sure some 3D printed add-on/sleeve could easily turn it into an eco adult toy… Love is energy! :heart_eyes: Don’t forget to remove the add-on before going out with your light during a blackout though… :person_facepalming:
If a lithium battery is left attached to a circuit for extended periods of time, even if the circuit is off, it will slowly discharge and drop below minimum capacity causing permanent damage.
Hopefully the flashlight has a physical battery disconnect or that lithium cell will be dead long before 5 years pass.
That’s a good point. Hopefully the parasitic drain is very low. It could be very low; I have a Zebralight that has a parasitic drain of only 2.4uA. That would last for decades, depending on the size of the battery (it’s probably something like 300mAh).
How long do glow sticks last in storage? It seems that a bunch of those might make for useful emergency light, when every other light source is dead. They’re about 10 cents each on Amazon. But if they only last a few years before the chemical breaks down, then that’s not much use.
Or a road flare. Good for light, and scaring away bears and wolves and zombies.
Sorry about being the cynic here but I have yet to see a Kickstarter project that I would put a dime toward. Sometimes it just that they are a solution in search of a non-existent problem, sometimes they are an overly complicated solution for a very simple problem, and often the eventual price is way out of line with the value received. Sometimes it is even a well known company that doesn’t want to put their own funds toward R&D but go the the public instead. I admit that I don’t purposely go to Kickstarter but have followed a number of links to the site.
I tried at least two Faraday lights that I picked up cheaply at garage sales or second hand stores. Both were conventional flashlights with LED bulbs. The most recent one actually had two lithium ion batteries in it but they were two rechargeable 40 mAh button cells. I have no idea how long it would power the light before needing to be recharged as I gave it away. It did put out a decent amount of light. The most annoying thing was the slide made the flashlight unbalanced, much heavier at one end than at the other. When I want a flashlight, I use a cheap XML-T6 LED flashlight which sell for less than $8 and is powered by a single 18650 battery. Cheap, lightweight, bright, rugged, and feels right in my hand. The flashlight, two high quality Panasonic batteries, and the charger were way under $25. If I want something small it is the 100 lumen chip-on-board key chain light that operates on three AAA batteries. It is lightweight, compact, runs for hours on one set of cheap carbon batteries and cost me about $2.
