Hello my dear friends!
todays menu:
Wuben A21
Aluminum rechargeable LED flashlights-4200 Lumens
Amutorch AL1 only US$ 28.91
XPL HD 1100LM Stepless Dimming Memory Function L-shape Corner Light LED Flashlight
use my code: MTLA1
todays menu:
use my code: MTLA1
Amutorch AL1 - does this light have a section that one removes to run it on a 16340 cell? Confused.
Skilhunt PL1 - confused again, sorry. Does this light come with a primary white light and then a choice of a 2nd color emitter?
thanks.
nice lights!
have you visited the shop?
on the AL1 you need to decide which battery tube you want (16340 or 18650) before buying
on PL1 you need to choose from white + 4 colors
I guess the short variant is not 18350 compatible?…
I have an AL1 which came with both battery tubes- the smaller one works fine with a 18350 battery.
The one shown on the Bang good website looks identical so you should not have a problem.
The only hitch I’ve encountered is the ‘stepless dimming’. I can only get five steps on the UI- low, medium, high, turbo and strobe. I assumed stepless dimming meant that by holding the switch it ramped up and down, but if it does do this then I’m too dim to work it out. The light came without instructions and everything I’ve discovered about the light on the web is in Chinese.
I would however recommend the light, it is unusual and seems well made, its quite bright and the beam has no nasty tints. The beam is a good compromise between throw and flood and does not have any rings. I’m not convinced by the AL1 logo on the head but I guess that’s down to personal taste. Incidentally both battery tubes are quite short and would not fit any of the protected batteries I tried but it works fine with unprotected.
Thanks for the info.
thanks cloggy
Thanks for the info on this! I was looking for it too, to see if I will get one or not!
is the tail cap of AL1 made out of plastic?
if so then it wont last long if you drop it :zipper_mouth_face:
Many thanks for the UI diagram MascaratumB, unfortunately it confirms my fears that either my light is defective or my understanding is. It seems simple enough but will not work on my light.
I have mastered theNoctigon meteor without difficulty so I am at a loss.
Below is a translation from a description of the light on the Taobao website concerning the tail cap.
‘Imported Japanese Mitsubishi resin to do the tail cover, high and low temperature, strength and toughness and good, is not general plastic comparable, transparency, the bottom can also diy luminous paste added fun. (for this material, we have been used in industry for many years, used in flashlight, we should be the first, for his strength, you do not need any suspicion, as long as it is not to take a hammer to die in the lane, normal use You are not bad, with bad I faulty products!) ’
Take it as you will!
Amutorch AL1 XPL HD 1100LM glare Stepless Dimming L-shape Corner LED Flashlight Aluminum +Titanium +Resin 18650/ 16340 /18350
Here’s the exact tutorial:
Switch and mode:
Regular Mode: Onefold click to turn on . Onefold click to dimming:Low 0.1A-Med 0.7A-High1.5A,Turbo3A(quick double-click),Strobe(quick triple-click).
Stepless Dimming:it can customize the brightness, long click to turn on the light, then long click to increase the stepless brightness, release to lock and remembered the mode. then long click to decrease the stepless brightness. Minimum luminance mode is 20mA.
Long press for 1 second to turn it off at any luminance level.
The turbo mode can be activated by quick double click at any luminance level. quick triple-click to strobe.Fourfold click to lock or unlock.
Flashlight protection function explanation:
(1)Mode memory function: if the flashlight is turned on more than 3seconds ,current mode can be memoried.Turn it off and then turn it on ,still the original mode.
if less than 3seconds ,Turn it off and then turn it on ,it goes into the next mode.
(2)Battery reverse protection:if your battery is reversed,dont worry ,no any problem will happen.
Hey
MF02s deal available :)
Is it already in your list? I couldn’t find it yet.
i just added a new deal to my list
Specifications
Product name: | Astrolux MF02S XHP70.2 Floodlight Flooding Flashlight |
Brand: | Astrolux |
Model: | MF02S |
Emitter Type: | XHP70.2 |
Light Color & Color Temperature: | Cool White (CW): 6500K Natural White (NW): 5000K |
Peak Beam Intensity: | 270000 CD (Max.) |
Max Output: | 6000 Lumens (Max.) |
Range: | 1039 Meters (Max.) |
Mode: | Low, Medium1, Medium2, High, Turbo, Strobe, SOS, Beacon |
Lumens: | 35LM, 508LM, 934LM, 2800LM, 6000LM, 6000LM, / , /. |
Runtime: | 194h, 5.49h, 3.48h, 2.3h, 2.46h |
Battery Configurations: |
2x 18650 or 4x 18650 Li-ion Battery (Not included) ( Samsung 30Q 20A 18650 Power Battery Recommended) |
Switch Type: | Clicky |
Switch Location: | Side of the flashlight |
Material: | Aerospace grade aluminium alloy |
Impact Resistant: | 1 Meter |
Waterproof: | IPX-7 Waterproof |
Lens: | Toughened ultra-clear mineral glass with anti-reflective coating |
Reflector: | Smooth Reflector |
Carrying Strap: | Strap |
Color: | Black |
Weight: | 818g without battery |
Size: | 189mm x 84mm x 54mm (Heightx Head diameterx Body diameter) |
veröffentlicht am 16. July 2018 in Allgemein, banggood, Coupons und Codes, EDC, flashlights von m4d m4x
banggood surprised me with some very nice deals – i hope so are you….
great colors
rechargeable
find this deal in M4D M4X deals
bright
find some videos on my channel
a NW version is availabnle also, but from another source
Lumintop ODF30C
ON/OFF: Single press for on, press and hold for 2 seconds to turn off.
I find everything over 1/2 second nerve-wrackingly slow.
2 second shut-off makes me fantasize about taking a sledge hammer and pounding the flashlight into scrap metal. :partying_face:
Every time. :disappointed:
TIP copper deal available ;)
and i updated my list so yesterdays announced items can be purchased - sorry for that mistake!
Grabbed another Wuben A21, CW this time from banggood with your coupon. I just had to have two of these they’re so nice. Thanks again for the original group buy and the banggood coupon! :+1:
Probably going to get the new Lumintop ODF30C as well. I already have the original. Love that light too. Should have had USB charging on the original, but at least they have added it now.
