The first XM-L T6 bin flashlights and P60 modules. This is the beginning
Just for kicks... from CPF group buy thread:
T5 050 tint: 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D for exactly BIN > Cutter's mail
T6 053 is 2S
yea id be happy with a 2s color. a little green but im more interested it overall output, and the fact that ill be outside neways. that greenish tint will go away
Well darn you guys! :) I just bought the KD C8 CREE XML T6 1000 Lumen. You're right... its all about output so who cares about tint! Hey, at least its a good excuse to buy. I have the similar SpiderFire SSC P7, which is my overall brightest 1 x 18650 light, so this should be a good comparison.
my brightest modified flashlight is my MTE-p7.
i had to change the driver, with 2 cr123's it draws exactly 2.8 amps, HOWEVER, its a C bin, so im lucky to get 500 lumens out the front!!!!
my R5 V6 is about 3/4 the light output on one 18650!!!! (1.4 amps vs 2.8 lol)
let me know if that C8 has proper heatsinking or if its a drop-in style light
also, check my thread on p7, i want to upgrade my MTE to a Dbin asap, so i have a good baseline uber flashlight to compare to!
Thanks for bringing that up XP. I just assumed that since my Spiderfire has a brass screw-in pill that the C8 would also. Has anyone seen one that is drop-in style or are all C8's screw-in pills?
I bet I'll have to upgrade the driver but maybe not...
I agree, its going to be interesting to see how they compare in similar hosts with well driven LED's.
yea, let me know when you get it, i have to save some money neways lol
So what would be a good driver for one of these then running it at full output ? I would prefer to install one in my Surefire l2x extended 2x18650
well not to many drivers will take 8.4v.
the shiningbeam 2.8amp driver only takes 6v
2 more ultrafire light with XM-L
Ultrafire 501B Cree XML T6 1000 Lumen 5-Mode LED Flashlight $24.19
http://www.kaidomain.com/ProductDetails.aspx?ProductID=11098
Ultrafire 502B Cree XML T6 1000 Lumen 5-Mode LED Flashlight $25.51
http://www.kaidomain.com/ProductDetails.aspx?ProductID=11099
Couldn't resist. Went ahead and bought the drop-in. I have a couple of empty P60 hosts that needed a little buddy.
Me too, but I ordered the C8, and I'm looking around for some XM-L LEDs now. The P7 drivers and a possible hoist are on the way ...Oh my, I hope my bank account will stand all this "Iwantone-mania" these days...
My pending orders:
DX, 5 orders
LT, 2 orders
KD, 2 orders
My new meditatation phrase: "I have all what I need, I don't need to order anything now."----- "I have all what I need, I don't......"
It turns out they don't survive de-doming but when properly heatsinked - in this case to half pound of copper, they can take 4 amps.
ttp://flashlightnews.net/forum/index.php?topic=2395.msg30348#msg30348
Thanks for the link. Thats some good reading. It seems that the XML will probably survive 3A dedomed if well sinked and 4A with the dome. Im very impressed with the 95,000 dedomed lux as apposed to 50,000 with the dome (@3A). As prices drop, this is going to make for many interesting mods. I just might have to buy a lambda 3D mag or one of his proposed kits. How's your 90 holding up Don?
That's not how I read it - I think he's saying that dedoming will kill it as it does for XR-Es.
But it wouldn't be the first time I've been wrong.
This seems wrong, that's not how I understand the optics. Most likely he had the wrong focal length with the dome on.
I think the dome is at least partially a beam spreader to get the125o beam angle. Like the SST LEDs the "intrinsic" beam is narrower.
this may explain some of the dumping that's been going on .
An LED that may make everything else look lame .
didn't expect that
Yes, but even with a wide beam, it only means a larger hotspot (to the detriment of spill), not a brighter one, similar to xp-e vs xr-e. It does, however, change the distance to the image of die.
Get a deep enough reflector of appropriate diameter and focal length and you'll focus anything,
I was already assuming optimal focus for the remarks about hotspot/size. I said that he got the measurements he did because it wasn't focused as well for the domed measurement as the de-domed one.
The other possibility is given the measurement are made at non-infinite distance, one is focused to the meter better to provide the larger number.
