Probably because this specific sample of Samsung LH351D is 80CRI, which means less medium blue, cyan, and bluish green is emitted compared to the 90CRI 219C.
Indeed, a lower CRI emitter can be seen as more yellowish (and same time, more purple) because of the cyan deficit. In these cases, being way under the BBL strengthens the purple look, closing in to the BBL or going above it strengthens the yellow look (but this is also dependent of the equivalent CCT).
This will be a cool flashlight to welcome and celebrate the year 2020. We are less than a year and a half from there. Star Wars IX is coming out on Dec. 20, 2019. We’re almost there gang!
2020? It could be out in a few weeks maybe. IDK for sure, but not too long.
Bombay says about July 20th, but that seems too soon. I will not complain if it’s true. I would just like it tested and working good instead of it rushing for a fast release.
That is true. But if somebody want modding the mini GT driver is glued and special. in a sofirn you can build what you want so I will keep pushing that idea to them
I just got my C8F host in from Mountain Electronics, man this is a great looking light :heart_eyes:
I have a question for y’all though. This is my first time installing a driver into a light with a side switch, so I’m wondering where the leads get connected for the side switch. Reading around I think this is correct.
Under the green circle it says “OTC,” but it didn’t come with that resistor. Is this the correct place for the e-switch leads? I’ve read you can also connect the + to the MCU #2, and the - to any ground. But the OTC pads are supposedly better to use. I’m fairly confident that was what Richard was explaining over on his thread here: Comment #7944
Also, the driver didn’t come with any of the resistors under the yellow circle. I complicitly trust that Richard left them off for a reason. Just out of curiosity, what are they for?
R1 and R2 are typically the low voltage protection circuit. If you have Guppydrv or something like that which doesn’t use low voltage protection there’s no point in having those on there.
I usually solder one of the e-switch leads to pin 2 on the MCU. (The MCU is marked with a triangle or recessed dot at pin 1 , the board has an asterisk there, numbered 1-2-3-4 on the left in your picture, going around the clock to the other side is 5-6-7-8 with 8 being up on the inside) There is no “+” and “-” by the way, you’re just interrupting the circuit. The best ground (as if it mattered here, is the outer 3 legs of the FET, lot of space there anyway for a ground point, you could also use leg 4 of the MCU, or that OTC leg closest to the ground ring, just check for continuity with your multi-meter for ground.
FWIW, under the green circle OTC means Off Time Cap, the brown capacitor. Above it, the smaller black component is a resistor that is used to keep spikes down, this helps keep the light from flashing when entering the FET mode.
Dale, thank you so much for the info man! I was hoping to get this C8F together tonight, but I seem to be out of 20awg wire. 18 gauge fits, but 22 gauge is too big for the center hole on the driver. I definitely want the least amount of resistance on this powerhouse so I’m going to assemble it tomorrow when I get some 20 gauge. :+1:
Edit: Reverse the 18/22 gauge wires and it’ll make more sense :person_facepalming:
Yourrid, I just bore the center hole out a little on the driver to accept the 18ga. just make sure the via is staying intact so the MCU can get power from the spring on the battery side, that’s how it works after all.
Alternatively, you can strip and tin the end of your 18ga wire and solder it into the via, then do a more traditional spring bypass on the other side of the board. That will work as well. Even a 22ga spring bypass will work in conjunction with the gold plating on the spring, should net just about the same as if the 18ga wire were run straight through. Very short span we’re talking here, shouldn’t make a lot of difference.
Or use the 20ga wire Richard put on the driver for your spring bypass.
Or remove the driver spring and solder a brass button (copper button) on the driver for a direct contact to the positive terminal of the cell used. Be sure to have a good spring on the negative end in the tail cap with at least a 20ga bypass there.
