cool, the clip is also identical, pretty weak on the tool, will wait for your report, good price tho. From having/using the tool for about 5 months that’s the first thing I thought of, tail, clip and diffuser are the same, not sure about the sofirn, these may all be coming from same factory with 3 different lathes doing the knurling, not saying its a bad thing, I use the tool a lot cause of the diffuser, makes a great nightlight, this one may be a home run at that price.
Light Modes
The default mode is LOW when you just turn on the flashlight, No Memory Function.
When use a 14500 battery, the brightness can be Low(20LM) - Medium(280LM) - High(600LM);
When powered by AA battery, the mini light gives out Low(1LM) - Medium(30LM) - High(220LM)
How to Use UltraTac A1 Mini Flashlight?
Unscrew the flashlight head or tail-cap;
Insert the battery with the positive side towards the head;
Reassemble;
Click the tailcap switch to turn on / off the light;
Press the switch when light on to switch mode between Low, Medium, High.
No clue. I am assuming the driver characteristics increase output with the increased voltage. Current draw with a LiIon cell would also make for more output I am assuming as well. I am by no means a electrical engineer so I am just using the simplest answer that my simple little brain can manage.
This Charles BridgTec review provides a 10% discount code SS6TRV2E for the UltraTec A1 on Amazon. So, I cancelled my original Amazon order and repurchased one for $10.75. With Prime, it will arrive Tuesday.
I also ordered one with the discount code. I had wanted a Nitefox K3, and a Tacteagle E09. With the discount and Amazon Card cashback cost was $14.68.
Jerry
The Sofirn SF14 would be my first choice as an alternative to UntraTac 1A because the two are functionally similar, and the Sorfirn SF14 is a good value. The Lumintop Tool AA is another contender, but the SF14 is less expensive. You can purchase a SF14 from the Official Sofirn Store on AliExpress for $11.90 right now, and I've seen it on sale cheaper. You can sometimes find the Tool AA on sale for around $16.
The table below provides an output comparison of the three flashlights:
Flashlight
Battery
Lumens
Low
Med
Med
UltraTac A1
14500
20
280
600
AA
1
30
220
Lumintop Tool AA
14500
8
95
550
AA
7
25
110
Sofirn SF14
14500
5
110
600
AA
3
33
230
All three flashlights have
A tail switch
Three modes: Low -> Med-> High
No mode memory. They always start out on Low.
No Strobe mode
Solid aluminum construction with an IPx8 rating.
The utorch ut01 is really not my type of flashlight (because it had a side switch and mode memory), so I'm not a good person to give you any advise about it.
According to 264's BLF review, the Sofirn SF14 has, "No pulse width modulation. White color beam tint. No purple-blue-green hue". To me, the SF14 output apears to has about a 5500 color temperature with no noticeable blue or green tint. But I may not be sensitive to these aberrations and they go unnoticed. Nevertheless, they are not an issue for me. Let us know what you settle on. Thanks.
I had one in my account cart yesterday at the 11.95 price. Came back this morning to complete the order and discovered the price has increased. Bait & switch? Greed in prep for Prime Day? Skirmish in trade war?
I've never had any UltraTac lights and likely will not in the future, based on their behavior. Reaching into my account cart to increase the price is shady & underhanded, to say the least. No different than being in the grocery store with a gallon of milk in my cart at, say, $1.99, then having a clerk pass by and place a price tag of $2.99 on it when I'm not looking.
For a society that supposedly is concerned with "saving face", these people sure aren't thinking about how their actions look to the rest of the world. Fake cells and wildly overstating cell capacities come to mind also.
I wouldn’t call that bait&switch nor shady. That is just how internet stores work - you can’t just put stuff in your cart and expect it to still be there at the same price tomorrow. Amazon prices change quite often - sometimes multiple times a day. But again, this isn’t something specific to UltraTac or even Amazon - most online stores work this way.
