Wow. 40. If that is true then I am going to have to rethink a lot about manufactures numbers. I was under the impression (perhaps falsely) that the zebralight calibration was one of the more premuim methods. It was for that reason that I assumed Acebeam L16, X45, X80, all of my olights and many other top brands were within about a 10 margin of error from the truth. Most often with those brands I would get just under or just over the rated output.
I have ordered a set of Maukkas lights and could hardly be more excited!
About the GT MINI. I get why 18650 was the choice. That said if 20700/21700 options come available I would be crazy over that.
So I’ve been on the fence with ordering this. The glued in driver is something I’ve never had to deal with. Does this make it extremely difficult to modify? I mean, if I wanted to throw a different driver in there later on… is that even possible or would I have to glue it back in?
Think we need clarification on the driver design. I can’t tell if they mean the driver retaining ring will be glued or it doesn’t use a retaining ring and the battery tube is what presses it into place.
It looks like the switch might be attached to the driver and that is why the driver has ears on it to keep it orientated in the right direction.
Then it looks like the battery tube is what pushes against the driver. If that is the case, they might be gluing the battery tube into place. It would also mean you can’t swap drivers.
This picture is what is giving me doubt in the overall design; there’s no retaining ring. Nor is there one on the tailcap
I’ve see this on cheap xxxFire flashlights mostly, it seems weird to have it on such a nice light. What holds the tailcap spring in? If this light was $20-$30, I wouldn’t mind it. But for the price, there should be retaining rings.
To me, it seems like they cut corners yet still want to charge a premium price.
Edit: Has anyone seen what the LED/MCPCB and the back side of the driver actually look like?
As there is no tail switch, the tail cap’s PCB only has to transfer ground between the battery tube and the spring, gluing the PCB into the tail cap is a fairly normal procedure and doesn’t hurt anything at all.
Many a light has had the driver held in by the battery tube, a great many have had a spot of glue on em to keep the driver from shifting about during battery changes should someone wish to pull the entire tube instead of the tail cap. Seen it a lot of times before and it’s not a testament to quality or lack there-of, just a different way of doing things. The glue that’s usually used is a sort of clear-white bonding glue something like Elmer’s. Easily defeated and I’ve never bother’ed to glue it back in when making driver or component changes. Nothing to worry about, just different is all.
Premium price this one is not. $100 and up lights are at premium’s. $300-400 are exotic, and $500 and up are just getting out of hand, usually custom with a lot of man-hours involved but not always.
Yeah…. I went ahead & ordered one, but those pictures gave me pause also. I don’t quite understand why they did it this way…. I guess they have their reasons…… just wish we knew what those reasons were.
. EDIT: I just read Dale’s post. What he said make sense.
Usually it’s a matter of maintaining a compact nature and probably also keeping costs down. The light was targeted to look like a smaller version of a BLF Group Buy light, hence, it was also targeted at a budget crowd. Make it a little longer here, a little bigger there, a little more complex at that junction, a few more machined pieces, the cost goes up and up, sales get iffy….
Emisar lights are made the same way. The small Thorfire TK05 has a glued in tail-cap pcb. Fenix small lights have glued in tail-cap pcb’s and nearly impossible to reach drivers. This has been going on for a long time, nothing new here.
A Fast Freddy’s burger is very similar to a McDonald’s burger, yet the price is not comparable. My cousin’s Cessna flies, but the resemblance to your ride stops pretty much right there. lol
Convoy makes a really nice light at a very attractive price, perhaps ruining the whole deal for a lot of people. Get a new C8+ if the price point is that unattractive, this GT mini is not especially adept at being an impressive light solely based on it’s performance. But for those of us that just love how much it resembles the cumbersome big daddy, it’s already on order.
There are a lot of tricks that can be employed to talk someone out of something, similarly there are a lot of ways an addict can talk himself INTO something. Perspective rules. Me personally, I really liked the idea to minimize the GT, that got me right there as I’ve always been a sucker for a miniature version of a known larger product, especially if the miniature is well made. If they took it a step or two further and kept the full scale, so the lights look identical, but in a 10440 size light, yeah, I’d be all over that one too.
I totally agree that there are much higher priced lights out there. And the price would be a drop in the bucket when considering my collection. I really wanted 2 of these, as I already have the GT. I just want to see what the internals look like so I can plan ahead on how I would like to mod it in the future.
I’m not trying to talk anyone OUT of buying this, by no means. I just need a little more info so I can talk myself INTO buying 2
Well, if it’s an XP-L HI running on a FET style Narsil driver then it should be performing at a nice peak value to begin with. Plug an XP-L2 in place of the HI and gain output with some throw loss, or use a Samsung LH351D for similar results with a purer higher quality tint. Slice and dice the XP-L2 to maintain throw, with some admitted loss in beam profile quality, or slice and dice an SST-40 for max power and still great throw.
Lot can be done, much more than those examples, but those are easy improvements anyway…
